Question about Toshiba Satellite A135-S4527 Notebook
What is the difference between formating drive and f sweeping it?
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 77 Answers
F sweep will keep all your files , formatting will clear the intire harddrive
Posted on Jun 02, 2008
What is the difference la78040n and la78040a
Slightly different in design but should be interchangeable---usually the last letter denotes a different version of same part.
Got no sweep or sweep with foldover and trace lines at top?
May 21, 2012 | Televison & Video
My flash disc is unrecognized by the pc
Try inserting it into a different USB port, or try one on a different computer. If that doesn't work, you'll have to resort to formatting the disk to continue using this flash drive. (Formatting deletes all the data on the disk though).
May 04, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Polaris 380 sweep hose isn't moving -- i have checked the sweep hose adjustment screw and it does't make a difference. the polaris unit is moving and vacuuming and there is water going through the sweep...
There are a few things to check with these pool cleaners. Make sure the opening at the end of the sweep hose is not blocked by the sweep hose scrubber. If you have any sweep hose weights, you might need to remove or adjust them.
Jan 10, 2011 | Polaris 380 In Ground Pool Cleaner
My sandisk 8 gm is not open , when i try to open it as me that the disc drive is not formatted, do you want to formatte it now ?. what i will do. please help me becouse it inculded important office file...
The reason for which you are not able to open the pen drive is that Pen drive was formatted on a different computer with a different file system from a different OS and then the file was copied into it. And the computer on which you are trying to open the pen drive is having probably different OS which does not support that file system Pen drive was formatted with.
So all you have to do is to open the Pen drive on a computer that has OS same as on which file was copied into.
Thanks
Dec 08, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I cnt format my pendrive do not show properties i can format my pc with pen drive what can i do solve it
Format your drive using a different operating system such linux or use the command prompt to format it. Just type format x and the drive letter of the drive. x represents the drive letter of your pen. Change x according to the current drive letter of pen drive.
Dec 18, 2009 | Computers & Internet
Webroot spysweeper won't sweep
Dear Sir/madam,
Reinstall it with different drive before u delete the folder of spysweeper. If you have using pirated version mean it will become problem. so get some other programs of full version. ok
thanks
good luck
Aug 07, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Jpg files corrupt
After you've donloaded your pictures, have you tried formatting your card in the camera? Press the Menu button, then go to the settings (tools) menu. Go down to the Format option. Select "Low Level" format if available in your menu. Again make sure that you have downloaded your pictures first as this will also erase your card.
If the above doesn't work, have you tried using an SD card reader? If so, the next thing to try would be a different card reader. And finally, have you done a recent sweep for spyware on your computer. Spyware can cause temporary hangup/hiccups that could potentially corrupt your download.
May 27, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Electrolux central vac, floor sweep malfunctioning
For 9.99 I'll tell you how I did it. Thankyou very much.
Mar 08, 2008 | Electrolux Centralux Vacuum
Toshiba Satellite A135-S4527 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
