Question about Tatung V30DMTT 29.6 in. LCD Television
Emprex Hd3201 LCD TV turns with audio but not video, I need a parts to fix please help Toshio
  • 11 Answers
SOURCE: 26" LCD TV is broken
rerplace the 1000mfd capacitors in the secondary of the psu..... is advisable to replace primary caps as well as they cause similar problems.
Posted on Mar 11, 2009
  • 8457 Answers
SOURCE: I have sound but no video on my LG LCD TV 32lb9d
Replaced the LCD inverter board.Will get the picture back.The board usally a long board.Tries Shopjimmy.com,Ebay.com to buy the board part.
Posted on Feb 16, 2010
Testimonial: "Thank you very much!"
budmrtn
  • 11361 Answers
SOURCE: I have audio but no video on my Sharp LCD TV?
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 28, 2010
jhuncruz2007
  • 5 Answers
SOURCE: emprex hd 3201 no video but i have audio
Replaced the INVERTER Board. This board is located on the eft side if you open the unit from the back. Get the Board number and order from ebay.com. I hope this helps you and nice to hear from you soon.
Posted on Oct 16, 2010
I have a emprex wt323 that won't turn on I was
It most probably is the power supply board. There is a repair service which addresses any problem with the power supply board, not just bad capacitors: http://www.coppelltvrepair.com/p/779/emprex-wt323-power-supply-board-repair-service-no-power-shutdown-etc
Mar 11, 2012 | Televison & Video
Digital lifestyles tv wont turn on
Sounds like a bad power supply board. There is a repair service which addresses any problem with the power supply board, not just bad capacitors: http://www.coppelltvrepair.com/p/777/starmen-tom202cabb-power-supply-board-repair-service-no-power-shutdown-etc
Nov 21, 2011 | Digital Lifestyle FA1B32Z 32 in. LCD...
Hi my emprex 17" lcd
Look for bad caps with domed tops, if you have bad one, you should repalce them in a set.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 19, 2011 | Emprex LM1704 17" Monitor
Vertical lines on my Emprex 32" monitor
That menas you have failing T0con BOARD, part of the LCD panel assembly, not much you can do, new LCD panel needed, it will get worst.
May 16, 2010 | Emprex LM2201 22" LCD Monitor
Emprex model wt323 no picture but have audio
Hi, I'm no expert but I've read alot of these posts. Also I do have that model too. Mine is totally dead, the p/s board.
Anyway get a flashlight and shine it directly on the screen with the tv on. Do you see a picture at all? Then the flourescent bulb is off. Could be the bulb, ballast or something like that. If no pic, maybe the inverter or something, now I'm just guessing.
I'll do some research for you. contact me at ray157@comcast.net
Apr 15, 2009 | Televison & Video
REMOTE CONTROL CODES FOR EMPREX TV
Emprex uses the Memorex codes. They are 1002, 1004, 1005, 1010
Apr 03, 2009 | Proton SRC-2010 LCD Touchscreen Remote...
When I turn on the TV, the white has flickering patches of teal and black has flicker patches of red. In fact, almost 3/4 of the white is covered in teal and the black has about 1/3-1/2. I am using a...
It seems as though you are using the component video inputs. If you are then more than likely you have bad connections between your peripherals(dvd, xbox, etc.) and your TV. Just make sure that all the connections are tight/pushed on to the terminals all the way and that you don't have bad cables.
Dec 11, 2008 | Insignia 37" LCD Flat-Panel HDTV
Tatung V30DMTT 29.6 in. LCD Television Logo
79 people viewed this question
Top Tatung Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Josh Whitehead
Josh Whitehead
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
