Question about Samsung Televison & Video
Wehre can I found the programm Samsung Channel list Editor v0.72?
On my 7" wide screen model TL7001-TP-ASC with ATSC Tuner. When I change the channel it wont tell me what channel the tv is on and the tv guide wont show. The tv does not show no numbers or letters
LG LED TV won't show program information or channel name ...
www.tomsguide.com/.../54774-4-show-program-information-channel-na...
Oct 18, 2011 - 17 posts - ‎7 authors
I will get the picture/sound (up to 1080i) but i can't get the TV to display the information (What I'm watching and the channel's name). It used to ...
ChanSort download ' SourceForge.net
sourceforge.net > Browse > Multimedia
Rating: 4.5 - ‎23 votes - ‎Free - ‎Windows
Jun 5, 2015 - ChanSort Channel List Editor for Samsung, LG, Toshiba and Panasonic ... ChanSort allows you to organize your TV's channel lists on your PC.
Jan 13, 2016 | Televison & Video
When I hit the info button, the program listing does not show. How do I set this up?
Info doesn't bring up the program listing. It just tells you about the current programme. You'd know this if you read the manual.
If you watch a list of the TV programmes, then you need to press the buttons listed on page 57 of the manual.
LE32R41BD LE32R41BDX XEU Support SAMSUNG UK
Sep 14, 2014 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Dose not turn on
have you tried pressing a channel button?
Get a cheap programmable multi remote and programme that until the TV responds
(You have this problem listed under TV's (CRT) but its not a CRT :))
Mar 09, 2013 | Televison & Video
Auto set up finds only some of available programmes. Only ITV channel found is ITV 4. cHANNELS 4 AND 5 not found. Very good reception on programmes it has found. Full range of programmes viewable...
It maybe that the TV needs to be completely reset. in the menu somewhere should be a setting to "restore factory settings" or "reset to default" something like that...
Try this and post the results...
Aug 27, 2010 | Panasonic (TH-50PZ700U) Television
Need to know what frequency locql chnnels like channel 11 wink cbs zip 33955 lee county Punta gorda, fla
These are assigned by the FCC. Google search "ntsc channel frequencies" and you will find what you are looking for. The first site I found listed (matrixtest) listed the channel and frequency. For Example, I found on their chart that CH 11 operates at 199.25 MHz or 199250000 Hz. I hope this was helpful, best wishes.
Apr 18, 2010 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Can`t retune samsung le 37 r88.
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Oct 01, 2009 | Samsung LE37S71 37 in. HD-Ready LCD TV
Samsung le26r74bd won't retune digital channels
Sep 30, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Samsung LE32R7 will not retune since switchover
Sep 30, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
I have purchased a Teac HDR2500T video recorder. I can set up to record television programme through EPG or PVR. I can see in LIST that the programme is recording, however when the programme is finshed,...
The part re the other channels having no signal....I had the same problem with mine and that was because the small loop cable in the back wasnt right. I could watch all channels, press record and still watch that channel but try to watch a diff channel while its recording and they were gone. As soon as I had the loop cable in properly it solved the problem. Hope this helps....
Sep 06, 2009 | Televison & Video
Televison & Video Logo
597 people viewed this question
Jerry Greenberg
Jerry Greenberg
