Question about Epson Stylus NX400 InkJet Printer
My epson NX400 is telling me I need ink but not telling me which color ink I need? How can I get to give me the cartridge color?
    Genius:
  • 1,011 Answers
Open the top cove and look at the ink cartridges.
Usually the ink cartridge that needs attention will be blinking.
Posted on Oct 15, 2010
My Epson Stylus NX400 won't recognize any of the ink cartridge after I performed a head cleaning and nozzle check option. There are still ink inside and they are original genuine ink. What should I do?
Did you remove the ink cartridge when you did the head cleaning and nozzle check, if so, did you touch the copper circuit chip on the cartridge? . . The chip is normally what tells the printer how much ink is remaining in the cartridge and if it cannot read this, it may not recognise that the cartridge is genuine and still has ink remaining inside. . . .You can try cleaning the chip with a soft dry cloth otherwise you may have to install a replacement cartridge. . . See http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=106004&prodoid=63075469 for the User Guide showing how to replace ink cartridges for this printer.
Sep 19, 2011 | Epson Stylus NX400 InkJet Printer
Have changed all cartridges on epson nx400. test shows 3 ink cartridges printing, except for the black ink. have run clean head utility, ink has charged. downloaded and installed printer driver. Found an...
Hi
The ink reservoir doesnt have to be completely empty to fail. Replace the cartridges. Some of the jets or all of them may be clogged especially if you have not used your printer in a while. If there are cleaning instructions in the manual clean the jets and then try to print from the printer's self test
Goodluck
Mar 09, 2011 | Epson Stylus NX400 InkJet Printer
I refilled empty ink cartridges and it is not printing right now. HELP?
If you refilled these yourself you will need to go to google.com and serach how to make refill cartridges work on epson stylus NX400 there is a little computer chip that tells when the cartridge is empty you will have to disable this before it will work
Jan 22, 2011 | Epson Stylus NX400 InkJet Printer
Cartridges are expensive and I either have to refill them or change to another brand of printer that has refill friendly cartridges. My question is this, how do I refill the T08 series of cartridges? My...
Do a search in Ebay for "Refillable ink cartridge for EPSON NX400" and you'll see replacement cartridges that are refillable and have an auto-reset chip.
Dec 20, 2010 | Epson Stylus NX400 InkJet Printer
How do you replace and ink cartridge in the epson nx400
This link will give you a PDF file with instructions and images on how to replace ink cartridges in the Epson NX400:
http://files.support.epson.com/pdf/nx400_/nx400_bb.pdf
Jun 03, 2010 | Epson Stylus NX400 InkJet Printer
My NX400 doesn't print. I changed original 69 type cartidges with bought on ebay self-resetting 88 type.Printer did resetting but doesn't want to print, actually prints but without ink, copies without ink....
Do not use Resetter.......
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 07, 2010 | Epson Stylus NX400 InkJet Printer
Epson TX100 won't recognise ink cartridges.
Yes, Genuine Ink Cartridges.
Did you use Epson Genuine Cartridges?
Feb 05, 2010 | Epson Stylus NX400 InkJet Printer
My father received the "replace ink cartridge" message on his Epson NX400. He replaced the black cartridge and now it says to replace "cartridges" (s). He didn't replace anymore because he didn't have...
Epson printer only work if there are all ink tank installed, and one of them not reach zero ink level (ink out in program). After replacing black ink, may be the other ink tanks reach zero level, so message to replace ink tank appear again. You can use the used ink tank (by refilling) if you don't reset ink level counter. Better you use the CISS ink tank (with or without outside bottle), that have autoreset function.
Oct 18, 2009 | Epson Stylus NX400 InkJet Printer
How do I replace ink cartridge?
you can use the maintenance utility on your driver to perform ink cartridge replacement. or you can perform this method should you be using it stand alone:
Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
1. Turn on the Epson Stylus NX400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus NX400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement.
If you’re replacing a cartridge before you see a message on the Epson Stylus NX400 Series
LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
follow on through each one of the inks and it should be good there on
Sep 23, 2009 | Epson Stylus NX400 InkJet Printer
My Epson NX 400 is giving me this error message:Error B88/69/68 C
Try to run the ink pad reset utility software.
Please log on to epson.com. The software runs on win xp and win vista.
Mar 31, 2009 | Epson Stylus NX400 InkJet Printer
Epson Stylus NX400 InkJet Printer Logo
60 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
