Question about Roper RGX4634KQ Gas Dryer
The dryer was not blowing hot air, only cold and never turned off. Now after I opened the door, it won't even turn on again??
High limit thermostat is a god posibility hard to say with little info but try this link
http://www.appliancepartsoutlet.com/appliancerepairhelp.html
Posted on Oct 15, 2010
3 Suggested Answers
  • 52 Answers
SOURCE: dryer does not blow hot air
If this is an electric dryer, it could be the heating coil is broken or burnt through, you may have a restriction of built up lint in the vent hose, or one leg of the 220 volt breaker tripped. Please rate my solution.
Posted on Apr 21, 2009
SOURCE: Dryer blowing cold air only
older homes with fuses can have to fuses on the dryer circut-1 could blow and the dryer would run without heat
Posted on Jun 20, 2009
No heat blows cold air, what is problem?
Check circuit breaker box Turn your dryer breaker off and then back on (reset) . If this doesn't help, does the dryer light go on
when opening the dryer door? Could be the High temp cut out
safety device because it's getting too hot.
Mar 16, 2015 | Estate Dryers
My freezer frosted over everything because the door was not shut tight and now it will not clear.
take out all the food out of the freezer,unplug the fridge and get a hair dryer and start melting out all the ice in the freezer,then blow the hot air into the vent holes on the back wall until you don't see any more water dripping down through the slots in the back wall.turn the machine back on,open the fridge door after around 5 or 10 minutes and if you feel cold air blowing into the fridge you fixed the problem,if you don't feel cold air keep hitting the inside back wall with the hair dryer and keep blowing the hot air into the holes in the back wall.all that it does is the freezer gets cold and there's a fan behind the back wall in the freezer,the fan blows the cold air into the fridge side,if the air ducts are frozen the air can't circulate into the fridge section so you have to melt the ice out so the cold air can blow from the freezer to the fridge.good luck,if you have another fridge remove the food and unplug it and leave the doors open for a day and it will melt out.good luck
Jun 16, 2011 | Kenmore 65234 Bottom Freezer Refrigerator
No air blowing into fridge, although we can hear blower. Freezer is working
if you can hear the fan still blowing but no cold air coming up to fridge section a common problem with bottom mount freezers is the door gets left open and the air ducts freeze up and the air can't blow up to the top.turn the control off in the freezer.remove the top shelf and the door,check to see if there are any screws one on each side of the slide arms,if there are remove them and lift the door up and out,with a hair dryer melt out the ice by blowing the hot air up each side of the back wall,also if the back inside wall of the freezer is covered with ice or like snow then you have a defrost problem but if there's no ice on back wall do what i said and blow the air up the sides of the back wall through the vents until no more water is seen dripping through the vent holes,then turn the freezer back on and check to see if you feel cold air blowing in through the vents in the fridge section,if you feel cold air then you're all set,if not keep blowing the hot air up the sides until it's melted out.let me know what you find,you'll know if the door was left open,ice will be on the ceiling near the light switch and sometimes on the top of the freezer door
Oct 25, 2010 | Amana ABB1927DE Bottom Freezer...
2004 mercury mountaineer.heat problem When turning ac knob to heat clicking sound like door opening and closing repeatedly sounds and air blows cold instead of hot.
Sep 13, 2010 | 2004 Mercury Mountaineer
Dryer jus blows cold air on heat cycle and i replaced thermal fuse
either you have an open limit or your element is bad . thermal fuse if bad won"t even let dryer turn on
Jan 25, 2010 | Whirlpool LGR5636L Gas Dryer
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
Heater wont blow hot air in my 1998 Lincoln Navigator
the computer that controls the deflector motor are not responding and opening the door for heat, I'm sure you have climate control,check the temp setting sensor to the computer input first
Nov 01, 2009 | 1998 Lincoln Navigator
Conia CCD4501 cloths dryer not blowing hot air anymore
If you can turn it on and have the door open, hold the door switch in and see if you have a glow from the heating element. If not, your element is broken. That is if it is an electric dryer. If it is a gas dryer you need to check the pilot light or the thermo sensor.
Jan 13, 2009 | Conia DVD8500 DVD Player
Roper RGX4634KQ Gas Dryer Logo
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
