Question about V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series
Starter does not engage - V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series
Arctic cat 2000 300 4wd starter would not engage. I pulled starter tested on bench engages ok. where starter mounts in hole feels like gear in there turns free what does starter engage into help
did you test the battery on the cat low battery will cause engagement problems ---starter damaged or weak my be good under bench test with out a load --or miss aligned and wasnt meshing with flywheel
Nov 10, 2016 | Cars & Trucks
Wiring diagram 1999 buick century. Starter engages when battery cables are bolted to battery.
-the wires are not correctly re-installed for the starter.
- u may need wiring diagram
Did you take pictures before you took it apart, or did you tag wires before unconnecting them.
Mar 12, 2015 | 1999 Buick Century
When testing starter out of truck works fine, put starter in truck and under load starter stays engaged, rip
Either the solenoid is getting power when it should not be, or the starter drive is not aligned with the flywheel.
Jan 18, 2014 | Cars & Trucks
Starter not engaging
The starter solenoid mounted on top of the starter has two functions, as the key is operated the solenoid slides the starter pinion to engage the flywheel, THEN operates heavy duty contacts to power the motor. The solenoid is not engaging the pinion.1726daf9-e191-4168-8e99-cab63cae5995.gif
Jan 05, 2014 | 1994 Plymouth Voyager
I just replaced a 1979 shovelhead starter (and new housing gasket and oil deflector plate) and the starter just free spins, Help!!
What ever it is it sounds like the starter Bendix isn't engaging. Need to know if it is engaged by a solenoid or centrifugally engaged.
Gillight
Jun 22, 2012 | Motorcycles
2003 dyna starter turns but wont engage, new battery fitted
Hi Anonymous, lift up rubber boot on positive cable to starter, unplug starter relay wire usually green, with a jumper wire connected to positive battery cable starter stud, touch blade connecter on starter where starter relay wire was removed. If starter engages and turns over engine then your starter relay is bad. If starter activates but does not engage then your starter drive/clutch is bad. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 22, 2012 | Cars & Trucks
Put in new starter it just spins doesnt engage motor
The starter engages with the starter clutch, normaly when the starter spins and doesnt engage, it is because the clutch bearings within the clutch have worn the machined surfaces causing the clutch to stick and not engage when the starter is pressed
Aug 26, 2011 | Yamaha Road Star Silverado Motorcycles
03 Oldsmobile Silhouette 3.4L Starter stays engaged at times.
Sounds like time for a new starter. While it could be electrical, in that the starter circuit is remaining engaged, more than likely it is mechanical. As the starter wears, you get play in the starter gear. Replacing the starter should take care of it. If you have recently had the starter off or replaced it, it could be misaligned, causing a similar problem.
Mar 27, 2010 | 2003 Oldsmobile Silhouette
Starter does not engage. I replaced the battery
You can remove the starter and bench test it on a vise. You will need your battery or a charger to test the starter with. The trick to do it is simple. The grond is the vise and the positive is the battery cable lug to the starter. Have a small wire to jump the positive and simply touch the solenoid connector to see if the starter engages
Sep 19, 2009 | 2000 Nissan Maxima
97 fatboy starter engages but will not stay engaged.
I would check the starter clutch its self first. It is a one way clutch so if you remove the starter and disassemble it to the starter clutch and hold the starter clutch in one hand and use your other hand to turn the starter clutch gear, it should only turn in one direction.
Mar 30, 2009 | Harley Davidson Harley-Davidson Motorcycle...
V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series Logo
26 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
rlev_7
Level 1 Expert
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
