Question about Apple MacBook Pro PC Notebook
Usb port problems - Apple MacBook Pro PC Notebook
  • 36 Answers
Reinstall you motherboard drives to rectify usb port problem or install usb drives or check weather the device you are connecting to usd is right one or wrong......
Posted on Oct 22, 2010
Why won't the right USB port recognize when I plug in my mouse?
Your USB ports on your computer are plug and play. If you have issues with your USB port, it is port related, driver related or device related. The following solutions will help you identify the problem to resolve your USB port issues.
To Identify a Working USB Port
Begin troubleshooting your USB ports by checking Device Manager to see if your USB ports or hubs are working properly.
  1. Click the Start button. ClickControl Panel.
  2. ClickSystem and Maintenance.
  3. ClickDevice Manager.
  4. Double-clickUniversal Serial Bus controllersand check to see if all your USB ports, hubs and controllers are functioning correctly. Any devices not functioning will have a yellow exclamation mark in front of them.
  5. If Device Manager shows any USB ports, hubs or controllers are not functioning, check for updated drivers.
To Update the USB Port Driver
An out-of-date BIOS driver can create issues with your system recognizing the USB port.
  • Watch a Video on Steps to Update Bios on Your Computer.
    1. When the update process is complete, your computer will restart again to load the operating system with the new driver version installed.
Sep 16, 2014 | Dell Inspiron Computers & Internet
Printer not talking to desk top.
Please check usb cable first, make sure that it is ok. Then check usb port,move the usb cable to other port. Then check if usb cable and port are ok, try to connect other printer or device by using that usb cable and port. If works well means the usb port on printer got a problem. But if still not work the problem could be on usb cable or usb port on computer.
If you are sure that both the printer and computer are ok, try to reinstall the printer driver. Good luck!.
Source: Printer Clinic - Where printer problem get solved
Sep 18, 2012 | Canon Pixma MX310 All in One
I have no PS2 but i have USB keboard and mouse ports, how can my USB mouse and keyboard problem at boot up can be solved?
What is the problem? Do the usb ports work? Try different usb ports. If you can get into the Bios or System Setup check to make sure the USB ports are enabled.
Apr 28, 2012 | Computers & Internet
My mother board gigabit 61pme s2p series mother board.with amd althon 3ghz processor.the problem is when i connect the usb pendrive to back of the usb port...if i send data 1 or 2gb data to pen drive.the...
your problem is kind of complicated. Check if you have a defective usb flash drive or an usb connector by doing so:
  1. Try other usb flash drive. If it solves the problem you have a defective flash drive
  2. Try to plug in to other usb port. Observe each port. If you see that you have a problem with your usb ports, buy a new usb port card
Aug 01, 2011 | Intel Motherboard
Problems with the front usb ports
Hello!
I see many comp. with problem on front usb port. In some case USB port isn´t right plug in motherboard, or is everything OK but they don´t recognize USB stick.
Only one, don´t lose you time with that, don´t use that USB port.
Oct 30, 2009 | Antec Computers & Internet
One of the USB devices attached to this computer has malfunctioned, etc.
This problem is caused by a USB ports of the motherboard. Try to insert the usb devices in the different usb ports and if all ports you inserted encounter the same problem then probably the ports has technical hardware problem. To solve this, buy an expansion usb card to your computer. Be sure also that the usb devices you inserted in your computer in properly working and has no defect to determine that the ports are the problem and not the devices. Please don't forget to rate me..Thanks..:-)
Oct 26, 2009 | HP LaserJet P2015 Printer
Problem with USB port on Asus P5KPL-AM SE Motherboard
Older motherboards have USB 1.1 ports;
newer motherboards have USB 2.0 ports,
which are over 10 times as fast.
It is Windows (not your motherboard) that should do the "Plug-and-Play" thing for devices connected to your USB port(s).
Note that some devices are USB 2.0, and will *NOT* work when plugged-in to a USB 1.1 port.
Either get a newer motherboard, or get a PCI add-on card that adds USB 2.0 ports.
Sep 10, 2009 | ASUS P5KPL-AM SE Motherboard
Power Surge on Hub Port
Some USB devices draw excessive power from the USB port, especially USB scanners. When this happens you need a powered USB hub, connect this to your computer's USB port and connect the USB device into the powered USB hub, you should not have any further error power surge problems.
Apr 27, 2009 | Compaq NX6110 TFT XGA Notebook
USB port problems with hp printer
use 2.0 ports and not less than that.if still nothing works out,check your port connections or that of ur printer.
Jan 03, 2009 | HP DeskJet 3745 Printer
Apple MacBook Pro PC Notebook Logo
55 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
