Question about Konica Minolta magicolor 2400 Laser Printer
How do i remove the driver, i have tried everything
    Scholar:
  • 192 Answers
Go to the Control Panel and click on Add/Remove and find the item and then click remove, this will take it off the system. PLEASE let me know if you still have problems, I would be glad to assist you further..... Take care, Guy S. :)
Posted on Oct 16, 2010
How to disable alarm on a 96 honda accord
you can try this
Open hood ensure new battery is disconnected.
Open main fuse panel cover under hood and remove horn relay (so you don't have to listen to the horn).
Use the key to lock the drivers door.
Connect the positive battery terminal.
Connect the negative battery terminal (security system will now activate, hazards lights will flash and horn would be going off if the relay was not removed).
Use the key to unlock the drivers door.
Get in, close drivers door.
Use the key to start the engine.
Security system will deactivate.
Get out of vehicle, reinstall horn relay, replace fuse panel cover, close hood. girls can do it too!!
Nov 17, 2017 | Audio Players & Recorders
Was trying to repair my google tool bar
Ok first thing to try would be to use F8 and then choose "Last known good configuration"
If that does not work boot in safe mode
Then rollback the driver you updated in the device manager
From what you say it sounds like the driver is the issue
Mar 29, 2009 | Computers & Internet
Laptop running very slowly
TRY TO INSTALL CCLEANER FREE VERSION AND RUN THE CLEANER..AND FOLLOW INSTRUCTION..U WILL BE SHOWING MUCH RUBBISH U HAVE IN UR PC...AND DELETE EVERYTHING...ALSO RUN REGISTRY...AND DELETE EVERYTHING..
ALSO INSTALL SLIM DRIVERS..FREE VERSION AND SCAN IT..AND NEW UPDATED DRIVERS WILL BE INSTALLED FREE..JUST FOLLOW THE INSTRUCTION...U ALSO CAN PUT THIS PROGRAM ON AUTO RUN,,AND IT WILL CHECK AND UPDATE UR DRIVERS ON A DAILY BASIS...
ALSO REMOVE ALL JUNK PROGRAMS U HAVE FROM ..CONTROL PANEL..AND GO TO ,,UNINSTALL PROGRAM AND REMOVE WHAT U DONT USE ANY MORE
GOOD LUCK..CHEERS
Aug 23, 2013 | Toshiba Computers & Internet
Repeated message "windows cannot load OmnisuperCam" Followed instructions and reinstalled carefully twice. Photo Impression 6 loads and is active. OVT does not appear in control panel 'scanner and camers'
Hi.
This often happens because Image Copier installation must be done in exact order as described in the instruction manual. To fix the problem you need to uninstall and reinstall everything back in right order.Also remember to restart the system when required.
  1. Unplug the image copier
  2. Uninstall the driver (remove from installed scanners and remove driver files).
  3. Uninstall PhotoImpression6
  4. Restart your computer.
  5. Install the driver,.
  6. Restart computer
  7. Reinstall PhotoImpression6 software.
During installation ensure that you authorize the system changes when asked. If possible disable any security software.
If that does not fix the problem, then the registry must be cleaned of any entry related to the scanner software. This is rather difficult to be done manual. You can try doing a system restore to a recent date before the problem started after uninstalling everything, and then uninstalling again if needed (application and scanner are there after SR), and finally reinstalling everything in order. If that does not work you can try a registry cleaner or reinstall the system.
Here a copy of the manual.
Jun 22, 2010 | Computers & Internet
Tried to download new driver for Windows 7 to let my Dell AIO 966 printer work. It says everything is ok but wont print Do i have to uninstall something?
First remove old driver and new from add and remove program and unplug the usb cable and turn it off.Restart computer and redown load driver before plugging in printer and turning it on.Good Luck !!
Nov 11, 2009 | Dell Office Equipment & Supplies
5300 printer is printing everything pink
try to check the ink maybe the color black ink are empty.. or something one of the ink color are need to refill or try to remove printer driver using ad and remove program and re install again
how to do this? go to the control panel click the ad and remove program when you see the printer driver uninstall it.. thank you hope i can help you,, have a good day!!
Jul 06, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Problem installing driver lexmark x2580 in vista home premium
first remove the usb cable attached to the pc, try to download the driver from official printer website complete file. then setup the installation when it ask to attach the usb cable attach to the pc
Jan 26, 2009 | Lexmark X8350 All-In-One InkJet Printer
"service this device" service
The feature isn't a driver it's a program. In Add/Remove, remove the HP printer stuff, then reinstall everything from scratch. Let it install everything.
Sep 10, 2008 | HP Deskjet 5440 InkJet Photo Printer
Mp600 can't load drivers
Try deleting any previous drivers installed,unplug the printer USB from the computer. Restart the computer run the driver CD leave the printer unplugged then when the cd asks for the printer,power it on and connect it to the computer let it install automatically see if that helps good luck.
Nov 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Konica Minolta magicolor 2400 Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
