Question about Stanley Garden
How do i cut floor trim with my stanley mitre box
  • 843 Answers
To do the job right, you make a miter cut, then a coping cut. There is an excellent article on this at:
http://www.wikihow.com/Cut-a-Coped-Joint-in-Wood-Trim
Getting a nice-looking coped joint is very satisfying, but takes a bit of practice. But it's worth it. Miter joints are great for picture frames and trim on furniture, but not for trimming a room.
Posted on Oct 15, 2010
I have a stanley mitre box it has a crack in it how do i fix or find someone who can fix it.
Most manual miter boxes are made of aluminum. A good welding shop should be able to repair your box, or you can get "aluminum brazing rods" at a home center; you'll use a propane/butane torch to heat the rod and flow it into the crack, similar to soldering.
Nov 29, 2017 | Saws
How do I cut the the corners(miter) of Polystyrene cornice.
Try making the cut with the rear of the cornice against the rear of the miter box rather than the front as you would for cutting regular (not crown) molding. I hope you are not using a circular saw to cut polystyrene.
Dec 05, 2014 | Saws
How do I clean the dust off a Stanley floor fan?
Unplug it. Carefully take off the grill and use a vacuum and/ or a damp cloth to clean the blades etc. Do not soak with water. Just a DAMP cloth on the blades only!!!!
Sep 10, 2014 | Lasko 655702 Stanley Blower Floor / Box...
Armstrong commercial flooring instructions for F-5061
I use a sharp Stanley knife when cutting rubber stair treads and tiles,and a straight edge.
Apr 04, 2014 | Armstrong 12" x 12" Intaglio Gray Speckle...
Mastercraft mitre saw
with regards to the stanley power stapler gun............replace the micro switch
Dec 02, 2013 | Hand Tools
Need to know how to use this tool Stanley 5-1/2in sliding t-bevel, I am cutting trim molding around the top of my bathroom and i know this will give me the angle but do not know how to transfer the angle...
Hello. It may be simple, but the transfer part catches everyone - yes even me at first. For your application, the trick is to:
  1. pull the slide as far as it will go and match the round-to-round end and match into the angle to be cut/trimmed-out.
  2. transfer the angle to a protractor, and match the angle (now a number) to the scale for "blade angle" on your saw.
  3. should your saw's scale be suspected as inaccurate, match the angle visually with the blade to the item's work surface.
Good luck, and if this helped please vote a four thumbs-up.
Thank you.
Mar 24, 2011 | Stanley Tools 5 - 1/2IN Sliding T - Bevel...
Mitre saw laser line off by 2 mm
Can't be shimmed on the arbor?
Jul 20, 2009 | Tools & Hardware - Others
What do i do to cut inside/outside corners for crown molding
It is very hard to make proper cuts with one of these.
You may want to buy a power miter saw.
You would be better off marking your 45 degree angle and cutting it freehand.
If you angle your saw a little the face will look like it matches up better.
If you need more help post a comment.
Tim
May 03, 2009 | Stanley Tools/Goldblatt Tool No.20 - 600...
Cutting resin tile
You need a tile saw that uses water to prevent sparking. Home Depot, Lowes..........<$100
Apr 24, 2009 | Daltile Bathroom Accessories Resin Soap...
Garden Logo
95 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Jim Goldsmith
Jim Goldsmith
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Stanley Garden Expert? Answer questions, earn points and help others
