Question about GPS
Magellan gps 1430. boots up OK. but touch screen does not respond.
  • George Inglessis Oct 15, 2010
    it's about a year old. Hasn't been used much.
    I think it's a mechanical problem--not software.
    George
  • 4,472 Answers
How long have you owned the unit? First thing I would try and do is update the unit:
http://www.magellangps.com/support/magellan_software_download.asp
Once I know how old the unit is I can give you the best course of action.
Thank you,
Lee
Posted on Oct 15, 2010
  • Lee A.
    Lee A. Oct 15, 2010
    If you've owned it less then a year then the unit is definitely under warranty and I would have it repaired/replaced under warranty by Magellan. If it's close to a year I would still complain as you shouldn't be having these kind's of issues and the problem should still be covered by them.
    http://www.magellangps.com/support/warra...
    Follow that link to get warranty repair information or start the repair process.
    Thank you,
    Lee
I have two Promark3rtk receivers, one of them have stopped responding to tuouch screen commands? what can i do?
there is a Magellan support group on Land Surveyors United which should provide some solutions with your problems with touch screen on Promark3 http://landsurveyorsunited.com/group/magellansupportgroup
Nov 29, 2010 | Magellan Triton 500 Handheld GPS Receiver
Navigon 1200 screen cracked,can you buy a replacement,if so where,thanks
Hello a new screen would cost just as much as replacing the unit.
Check out Magellan roadmate line the 1430 and 1470 sell for under $150 and have excellent maps, smart touch screens for entering addresses and more sensitive GPS receivers than even just two tears ago.
If you are set on staying with that model I would try finding a used one on ebay or craigslist.
Dec 30, 2009 | Panasonic Navigon 5100
My touch screen is not working. The GPS is on but whenever I touch the screen, tt doesn't respond. I own a Magellan RoadMate 1412
As the touch screen is not working,then you only need to replace a new working touch screen for Megallan RoadMate 1412,you can try to contact:
MSN/EMAIL:kingyijin@hotmail.com
SKYPE:keyudakim
Probably she will give you a good solution for that touch screen.
good luck
Dec 20, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My magellan mastro gps touch screen will not respond. less than 4 months old. magellan wants me to send the unit back to be replaced by a refurbed unit with a 3 month warranty. i would like to know how can...
turn it on, make sure the battery has a good charge on it, then locate the reset hole on the left side near the bottom and use a paper clip to depress the switch...youll know its reset if the unit goes off and reboots....if that fail, it needs a digitizer (the part that lets you navigate your magellan) its the upper layer over the touch screen.
i buy broken magellans off ebay if i need a digitizer or screen..normally for under 20.00
bill
Nov 17, 2009 | Magellan Maestro 4040 GPS Receiver
Can you download an update for a magellan roadmate 1430?
Yes you can: Enter your info here http://www.magellangps.com/support/
English Manual: http://docs.google.com/viewer?url=http%3A%2F%2Fwww.magellangps.com%2Fassets%2Fmanuals%2Froadmate_1430_manual_en.pdf
Magellan® RoadMate® 1430 Software Update Version 3.12: http://www.magellangps.com/support/chooser.asp?prodid=2056&supportid=806
2009 Spring Map Update: http://www.magellangps.com/products/map.asp?tab=0&PRODID=2194
As for connecting it to the computer, you'll need the usb cable that came with it. Then you'll want to do this:
Follow these steps to connect your Magellan RoadMate to your PC.
  1. Turn ON your Magellan RoadMate.
  2. Touch "Map" to display the map screen.
  3. Connect your GPS to your PC using the USB cable.
Oct 19, 2009 | GPS
After startup, the screen stops responding in about 1 minute. It appears that the system is still running, but screen does not response to touch. I can reset it and everything will work again, for about a...
install the latest update (2.36) its another common problem in the 4XXX series magellan. you can get the update at the link below. you must register your 4000 on the magellan website before you can download the update.
let me know if you need further help
Aug 08, 2009 | Magellan Maestro 4000 GPS
Magellan roadmate 1430 no sat signal
replace the or recharge the battery to capacity and see if that helps usually low battery, incorrecty baud rate or port out cause no satellite connection, unless you are under a thick concrete or tin roof. take it outside and show it some sky and see if that help
Jul 23, 2009 | GPS
Magellan roadmate 1430 calibration is wrong
try a hard reset again using a paper clip, insert it in the little pin hole on the side to reset the unit. if that fails, get the 3.12 update (if you havent already) off the magellan site..you must register the unit with magellan before you can download the update.
Jul 02, 2009 | Magellan RoadMate 1430 GPS Receiver
Magellan GPS
Like a computer, it isn't "booting". Try phone support at Magellan.
Aug 23, 2008 | Magellan Maestro 4040 GPS Receiver
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
