Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Set your Ref/Freezer per the following:
Refrigerators: 36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
You have to wait about 4 hours for everything to stabilize. If you are still having ice forming inside the freeezer then the rubber seal around the door is probably the problem. If they have a split, tear or crack, etc. it will let warm moist house air into the freezer and turn to ice as it cools. If this happens in the refrigerator it'll turn to water and collect in the bottom of the frig. New seals can cost around $60 per door.
If you pack too much food in the unit it may also cause freezing because the air needs to move around in there and food shouldn't block the vents in the back walls of the unit.
Hopefully this helps..
