Question about Remington MPT-3000
I cant figure out how to put the blades back together after cleaning..help!
KVD Quantum kinetic PT baitcaster reel, problem is I took it apart to clean it and couldn't figure out the right way to put it back together with all the spacers please help
I know how much everyone loves those reels They are great when they are new. But the truth is They are made to sell and they do sell. But I will bet a dollar to a donut that You would have 300% less trouble out of a Shakespeare Reel with less trouble and 70% less on cost and you cant wear them out.
Mar 31, 2013 | Fishing
How to put my wahl 5 star detailer back together
my back piece where the scruess atach broke help please where can i buy a new back piece
Sep 26, 2012 | Wahl 8081
I took the bladeoff to oil and now can't remember how to get it back together.
i needed to replace my blade - my husband replaced it but it would not cut so we took it apart and cant figure out how to put it back together. nothing helpful on line.
did anyone have a link how to put all the pieces back together to create the blade? thanks
Jan 16, 2011 | Oster 76076-010 Hair Trimmer
Can't put blades back
mcdevito75 here, Bring the shaver to any drugstore in your area they should be able to help out.
Jun 24, 2010 | Igia AT7352
Filter
If this one is like mine (and it looks just like it except my Lasko doesn't have the wood grain on the front) there is no filter inside. It is just a fan inside a plastic case.
If you want to clean it, you can try blowing it out with compressed air if you have a powerful enough compressor. If you really want to clean it, you will have to take it apart and that isn't as simple as it sounds if your unit is just like mine.
There are a bunch of screws on the back, which isn't too bad except one of them is a triangle headed "security screw" that is probably there to keep you from taking it apart. I looked at several stores and couldn't find a screwdriver to fit the stupid thing. So what I did was that I took out the rest of the screws, pried the case open as far as I could with my hands and cut the support that the last screw was attached to from inside with a strong pair of wire cutters.
I figured that when I put it back together, I wouldn't miss that one screw and I wouldn't want to deal with a triangle head screw every time I took it apart in the future anyway.
Once the case is apart, I found the best way to clean the blades is to remove the whole blade assembly and just wash the thing out in the tub and let it dry thoroughly before putting it back in. There's a metal brace (Held on by two screws) at the top the top spindle goes into and there's a single screw on the shaft of the motor that hold the bottom spindle in. It probably sounds more complicated than it is. It's pretty simple when you see it.
If you put it back together right, you almost can't do anything wrong. You might want to take a damp cloth and wipe down the interior of the case and the shrouds that surround the blades as well. If you've had it a while, they'll be dirty. You'll see/feel the dirt wherever it is. This thing is a pretty simple machine and is easy to clean once you figure it out. I put a few drops of oil on the top spindle when I put mine back together.
May 21, 2010 | Lasko 2554 WIND CURVE Fan
Forfex blade reinstall
I have the Forfex babyliss 720 and I can't get new blades installed in it. I have tried 8 times and someone else has tried 5times. Do you have any instructions on this model.
Thanks
lchardt@embarqmail.com
Dec 16, 2009 | Forfex BABYLISS Pro Clipper/Trimmer Combo...
I took the blade apart and can't figure out how to put them back together. Can you help.
the oster clippers are usually mounted with spring tab to remove blade.Should be no reassembling. If there is, it should be a couple of screws that you screw in
Oct 23, 2009 | Oster Golden A5 2-Speed Universal Motor...
Remington MPT-3000 Logo
43 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
