Question about Brother MFC 210C All-In-One InkJet Printer
I replace all four ink and it keep saying no cartridges i make sure there are in properly
    Genius:
  • 1,018 Answers
Did you use Brother factory new cartridges?
If you used refilled cartridges, third party cartridges, then that is more than likley the cause of your failure.
Posted on Oct 15, 2010
Install ink cartridge after the installation
INK CARTRIDGES ARE TIME SENSITIVE, check if the date in the box was current or expired.
Nov 19, 2013 | HEWLETT-PACKARD HP 2140 Fax
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Printer will acknowledge only 3 of 4 new ink cartridges - keeps saying change LC51M
doesn't LC51M refer to Magenta(red) not Cyan(blue). on my J435W the colors goes as follows: BK Y C M LC71 Series cartridges. Maybe you have them switched around? just a thought.
Sep 17, 2012 | Brother MFC-5460CN InkJet Printer
I need to make the ink carriage move over so I can replace the ink cartridges inmy workforce 840. Online here it says "hit theink button" what the heck does that mean? Where is this ink button?...
this is out of the manual
Replacing Ink Cartridges
Make sure you have a new ink cartridge before you begin.
Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are
vacuum packed to maintain reliability.
Leave the expended cartridge installed until you have obtained a replacement, or the
ink remaining in the print head nozzles may dry out.
1. Turn on the product.
2. If an ink cartridge is low or expended, you see a
message on the LCD screen indicating which
color to replace. Press OK.
If you're replacing a cartridge before you see a message on the LCD screen,
press Setup, select Maintenance, then select Ink Cartridge Replacement.
3. Raise the scanner.
4. Open the cartridge cover. Then squeeze the tab on the cartridge and lift it up.
Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets
into your eyes, flush them immediately with water. Keep ink cartridges out of the
reach of children and don't drink the ink.
5. Before you open the new cartridge package, shake
it gently four or five times. Then remove it from
the package.
6. Remove the yellow tape from the bottom of the
ink cartridge.
Caution:
Do not remove any other labels or seals, or ink will
leak. Do not touch the green chip on the front of the
cartridge. This can damage the ink cartridge.
Sep 01, 2011 | Office Equipment & Supplies
Since I changed the black ink cartridge it keeps saying missing
did u change / replace the cartridge with original spare or refilled it??
this kind of problem often follows with an unbranded cartridge change and or refilling..!!
it also can be the defective cartridge itself causing such problem..!!
well if u r a professional then just dip a cotton into isopropyl alcohol n gently rub the connector sensor/ contact surface, n reinsert it properly, gently rub on the head too n make sure ink is coming/flowing, make sure the toner is not jammed or dried up, also have a glance on the 'carriage' n see that no sensor pins are broken and or bend..!!
..if u r not an professional, make sure it is properly inserted and the ink-spill protective/head covering is removed and call ur system admin....
if all the above fails, then it may b a defective cartridge..!!
Oct 25, 2009 | Lexmark X4270 Printer
Printing problem
The printer determines the amount of ink left in the cartridge by counting the number of ink "shots" when printing, head cleaning etc. This information is stored in the "chip" on the cartridge. Thus, it is not an actual measurement of the ink left, but an estimate calculated by subtracting the total shots from the original full ink quantity. This estimate can sometimes be grossly in error, usually due to a cartridge replacement not being carried out correctly, or a cartridge that wasn't, in fact, properly filled. In other words, your cartridge (or cartridges) may actually be empty, even though the Status Monitor says there is ink in it/them.
You do not say if this problem is one cartridge, or all four. If it is the latter, then something is clearly amiss, since it is unlikely all four would be erroneously reported as containing ink when actually empty.
However, the first step is to buy a new set of cartridges - you can get a set of compatible cartridges from E-Bay very cheaply. You can save the old ones - tape up the nozzles to keep them from drying out - you may be able to use them again when you know what is going on.
Make sure you go through a proper cartridge replacement process so that an ink charging cycle is carried out.
If the new cartridges produce no printing, try a couple of head cleans and nozzle checks. If this still produces no print, report back with a new comment on what you have done so far.
Apr 26, 2009 | Epson Stylus C63 InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
26 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
