How do i change my move ratings setting? - Audio Players & Recorders
    Problem Solver:
  • 11 Answers
Connect it to a computer
Posted on Oct 15, 2010
How do i change the tax increase rate on my sharp EL-1197pIII
Move 'GT' '.' 'RATE SET' selector to 'RATE SET'
Tax / discount rate: • Press the TOTAL key twice, enter the tax rate, followed by the TAX+ key. •
Press the TOTAL key twice, enter the discount rate, followed by then TAX- key • A maximum of 4 digits can be stored (decimal point is not counted as a digit). Note: • Be sure to set above noted selector to the "•" position after storing an each rate. • For the conversion rate and the tax / discount rate, a single value can be stored for each. If you enter a new rate, the previous rate will be clear
May 27, 2016 | Sharp El1197P111 Printing Calculator
Acer P223w blurred screen looks like it is moving
The only way you can fix this is by changing or altering the refresh rate of your monitor on the laptop. Right-click on the desktop and go to properties, the go to the settings tab, then Advanced tab, the go to the monitor tab. Make sure the refresh rate is the one the your monitor can display. Probably put 60Hz and then you can check the box that says Hide the modes that this monitor can not display. This should fix your problem. If it does not, go back to the desktop properties and got to the settings tab and change the colour quality to 32bit instead of 16bit and again you can play with the screen resolution
Feb 21, 2012 | Acer P223W 22 inch Monitor
How to reset a password
Set up blocking schemes to block specific channels, ratings, and external viewing sources.
A password is required to gain access to this menu.
Setting up Your Password
For USA
LOCK Move Enter
Lock System : Off
Set Password
Block Channel
Movie Rating
TV Rating-Children
TV Rating-General
Downloadable Rating
Input Block
For Canada
LOCK Move Enter
Lock System : Off
Set Password
Block Channel
TV Rating-English
TV Rating-French
Downloadable Rating
Input Block
Close
Enter Password
Select LOCK.
1MENU
ENTER
Input the password.
2 Enter the password as requested.
The TV is set up with the initial password
"0-0-0-0".
Hope this helps
John
Sep 17, 2011 | LG 42LG50 42 in. LCD HDTV
Hi,how can i change font ( big size )in Nokia N900
hello,please kindly move under your settings,you will then see display settings and click on font,there you can change it to whatever font you desire.
please kindly rate the solution if it's helpful,
take care.
Jun 09, 2010 | Nokia N900 Smartphone
Can not change time!!
Press mode key at any time to exit.
Press mode, then press adjust to change time zones.
TO SET TIME AND DATE:
Press and hold alarm on/off for about 5 seconds until hour flashes.
Press adjust to change hour.
Press alarm on/off to move to minutes. Press adjust to change minutes
Press alarm on/off to move to seconds. Press adjust to change seconds
Press alarm on/off to move to month. Press adjust to change month
Press alarm on/off to move to date. Press adjust to change date
Press alarm on/off to move to day of week. Press adjust to change day of week
Press mode key to save to exit.
TO SET ALARM:
Press mode to go to alarm screen (AL shows above temp)
Hold the alarm on/off button for about 5 seconds and the hour will flash.
Press the adjust button to change the hour.
Press the alarm on/off button again to move to minute
Press the adjust button to change the minutes
Press the mode key to save and exit
Good luck and please rate 4 thumbs up for the free answer
Apr 22, 2010 | SkyScan 86709 Atomic Wall Clock
I can't reset the time on my clock
TO SET ALARM:
Good Luck aqnd please rate 4 thumbs up for the free answer
I need to adjust the breaker setting on my generator. I have a Sace 7s ABB Sace 7 breaker that is rated at 1250 amps and I need to adjust it down to 600 amps. Which setting do I need to move to get this...
Most of those breakers are universal and can easily be replaced. Unless it's a special type of breaker, you can't change the amp rating, you have to get a new breaker with the amp rating that will fit. I can help you better if you explain the reason you want to change the amp rating.
Sep 17, 2009 | ABB Sace Isomax S6d 630 Circuit Breaker...
How do you set the tax rate
Example: setting 5% tax rate
1. move mode switch to 'rate set '
2. press 5 (for tax rate ) followed by TAX+ button
3. Move mode switch to GT
to add tax to e.g 200 type:
200 TAX+, the result is 210
Feb 16, 2009 | Sharp EL-1197PII Calculator
Samsung sync master 510 monitor display problem
It may be that the LCD monitor will not display all screen resolutions so you may need to change your resolution to match the desired resolution and refresh rate of the LCD. In your case the computer should be outputting:
1024x768 pixels
60 Hz
You can change these settings by right clicking on the desktop and clicking properties and they're under the settings tab. Change the screen resolution by moving the slider to the recommended setting (1024x768)
and
under the advanced button click the "monitor" tab - make sure the screen refresh rate is set to 60 hertz (60 hz)
May 21, 2008 | Samsung SyncMaster 510N 15" LCD Monitor
New flat screen monitor humming noise
This could well be your refresh rate. Move your mouse pointer over any blank area of the screen and right click. Highlight and click on properties.Click on the settings tab, then on advanced then on to the monitor tab. You should see a setting for refresh rate eg. 75 Hertz. Change the refresh rate and the noise should disappear.
Jun 30, 2007 | Samsung 920BW (Black) Monitor
12 people viewed this question
 Grubhead
Grubhead
