Question about Lexmark C772dn Laser Printer
Colour lines appear when printing a document - Lexmark C772dn Laser Printer
    Scholar:
  • 126 Answers
I've seen alot of problems with this series with color lines on printouts. pull the cartridge(s) out that are making the colored lines, it's usually the PC drum (The roller on the bottom of the cartridge) has become defective, look for the rust/ bubbles on the roller. Sure sign it's the cartridge(s)
Posted on Oct 15, 2010
Bizhub c200 printing with streaks of red and blue lines what to do
If that lines are consistent with the red and blue and it does not appear during black and white print that means the cleaning blade in the affected color units need to be replaced
May 16, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
My cyan colour is finished, i have to print a black colour documents, printer is not allowing to print, please help
switch to black and white on the printer settings.make sure ignore colour warnings are turned off
if that doesnt work youll need to replace the cyan,get it refilled for less or order online to reduce cost
Mar 07, 2011 | Epson Office Equipment & Supplies
Failure to print from computer in colour
I have a similiar issue that just started happening recently - the printer shows FULL inks but the PC thinks it has empty inks. I tried the * #, 123 reset hardware failures, but that didnt help. Printer run self diagnostics says all is fine....
I am using USB connections - and this has been fine for years, until now. Maybe a microsoft patch issue?
Jul 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
I'm out of blank ink. Can I print document with colored ink only? How?
If you want to print text & documents with a colour other than black then for MS Word and many other applications:
  1. Highlight the whole document by either pressing [Ctrl A] or use the mouse to highlight everything by right clicking 3 times rapidly or pressing the left mouse button down at the start of the document then scrolling to the end of the document while holding the button down and then releasing at the end of the document.
  2. Then go to the FORMAT tab and selecting FONT from the drop down list.
  3. Then select the colour you with to use from the FONT COLOUR box drop down list. Just be sure to choose a readable colour and not choose automatic or pure black.
  4. Once this is done you can print.
Note that images that use black will still print but will look strange without the pure black content but muckhof what appears to be black acually isn't and is a combination of the 3 / 5 or 6 other colours inthe printer so may print normally.
Sep 12, 2009 | Dell 942 All-In-One InkJet Printer
Lines in the print
Nozzle check perfect? No ink drop outside lines? Cyan lines is random position. Print blank pages. It is still appear cyan lines? If yes, it caused by waste ink at bottom plate. Print blank pages more, it will clean itself.
Jun 29, 2009 | Epson Stylus CX9400 Photo Printer
Red and blue lines across printouts
open printing preferences and click on maintenance. Run the print head alignment utility. Sometimes this will remove the horizontal banding. I had this same problem and had to uninstall the printer and reinstall just like it was new, running the alignment feature before it was corrected. Worked ok for a few days then started again. I assumed that the printhead is bad. To costly to repair and bought a new printer.
Jun 27, 2009 | Epson Office Equipment & Supplies
How to print text using red or blue ink
I would just set the text color to red or blue in your document.
Depending on the program that you use it could have different steps.
Here is steps in Word:
You can change the Colour of your text by highlighting the text and then clicking on the 'A' symbol on the toolbar. This will change your text to the Colour which is underneath the symbol 'A' on the toolbar. To change the Colour, click on the arrow next to the symbol and select one of the colours from the small box which appears. This will change the Colour of your text as soon as you click on the Colour.
Another way of changing the Colour of your text is to go to 'Format' and then click on 'Font'. The font window should appear. Select a Colour from the 'Colour' section. You can see a preview of what the text will look like in the box below. You can also add various effects to your text by using the options in the 'Effects' section. This will also allow you to see a preview in the box at the bottom of the window.
Hope this helps. Please remember to rate this information.
May 03, 2009 | Office Equipment & Supplies
My printer is not printing the right color
chose print option, then chose properties. on the top you will get colour option chose it and chose print in colour option. and apply it. right now you can continouing with your colour printing.
regard
priyabrata (Be. in it)
Feb 16, 2009 | HP Deskjet 2460 InkJet Printer
Line across the page
  1. Make a copy by using the platen mode and ADF.
  2. Send a print from your PC or print out the Counter list from User tools/counter button.
  3. Try printing one colour at a time - Black, Cyan, Yellow or Magenta.
If when printing, there is no line across the pages, so you need to clean the optics mirrors and exposure glass.
If the line appears in both 1 and 2 mentioned above, you have the fuser roller or drum damaged.
If the line appears in all colour prints, check the fuser or transfer belt.
If it happens only with one particular colour, check that drum unit.
Good luck and please rate me, thanks.
Feb 02, 2009 | Gestetner DSc328 Copier
Print is missing along a one inch width patch for the entire lengh of mdocument
try a new toner cartridge
if it doesn't fix your problem then you willneed a new fuser
it is probably delaminated
Dec 22, 2007 | HP LaserJet 3055 All-In-One Printer
Lexmark C772dn Laser Printer Logo
102 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
