Question about Konka Televison & Video
Hello, I am trying to repair Konka TV, Model KP21SA601L1, the set has good sound, no picture. If I use the DVD input there is good sound and picture. I have changed N103, LA76931H7N58T8E. Your help with this matter will be appreciated.
  • Konka Master
  • 6,993 Answers
If your TV is having a goo sound and picture using DVD player, the it means there is nothing wrong with the TV, the problem should be from, the receiver (decoder) or the device connected to the TV.
It might simply be a bad wire or fault from the video board.
Try using another wire to connect the device that is not having picture on the TV.
Good luck.
Posted on Oct 15, 2010
Hi, What is the procedure[using remote]to go between TV signal and DVD signal on a Konka model KL22ES62Q TV set cheers John.
Your TV does not appear to be with in inbuilt DVD.
So you must use
(1) TV remote to select input as DVD
(2) Operate your DVD using the DVD remote for eject, play, FF or rw etc.
If you have a universal remote and the codes for the brand of TV and DVD are programmed, you can control using one remote.
Oct 13, 2016 | Konka Televison & Video
Hi, I have a Konka TV hooked up to a DVD player,and the decode.they were both running fine until I hit the wrong button on the remote,now I can`t get a picture on the TV at all John
You've probably changed the input port by accident. Look for the "source" button on remote. may be called something else but it's the one that selects which port you want to activate, like..HDMI2 or Skart1 etc....whichever port your DVD player is plugged to, select that one on remote.
I have a 14" Konka
Hello
Look close to the input sockets, for which they are marked for. They may be for audio out from the TV. Red will be Right and White will be Left. It is meant for taking audio out from that TV, which in turn can be fed to any other external audio equipments, like amplifier or so. As there is no yello colured sockets in it, this TV is not meant for any other external inputs to be fed in. OK.
Jun 25, 2011 | Televison & Video
I HAVE A KONKA TV MODEL KLC1508U THE BLUE SCREEN COME ON AND THEN GOES BLACK. I TRIED THE DVD AND THE SOUND COMES ON BUT NO PICTURE. PLEASE HELP ME.
Make sure that your audio input is the good one that corespond to your video input. After that if the audio input is good, try to disconnect all your video wire and reconnect it,check if the blue and green wire are not swap or try to used an HDMI wire if your DVD have a blug like that. Or if it not possible try to change your input on your tv set.
May 13, 2011 | Televison & Video
How to access the video input channel for my Konka tv?
press menu twice and once + or - volume. and tv will enter in video imput mode.
Jan 27, 2009 | Konka K1398U 13" TV
No Konka TV Codes on Uni. Remotes
Hey everyone if you are trying to find the code for your konka tv on philips universal remote it is : 0208. My fiancee just played around with codes and figured this out. so your code is 0208..
Good Luck!!
Sep 10, 2008 | Konka FL2792U 27" TV
Connecting dvd?
If everything is connected and dvd player is on, make sure you have the proper input selected on the TV. Input2 on this model TV. Try switching between the inputs.
An important thing you need to do is set the RGB input signal from PC to YUV or you won't have a good picture. This is done through the menu system
Jul 01, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
Hook up dvd to Konka tv
Keep in mind that there is only one set of RCA (or composite) inputs to this tv. For the video, you have the option of using the RCA jacks OR S Video input. When using the composite set of inputs you are using set of jacks (looking from the back) to the right of the tv that are furthest away from you. The audio for this set of jacks are the second and third composite jacks (counting from the right).
Jan 18, 2008 | Konka KDL32AT23U 32 in. LCD Television
Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Jun 23, 2007 | Panasonic PT-53WX42 53" Rear Projection...
MY KONKA MODEL KLC 1508U
My Konka model KLC-1508U tv will not come on there is no red light that shows it is off
May 11, 2007 | Konka K2001UM TV
Televison & Video Logo
98 people viewed this question
Top Konka Televison & Video Experts
Arnel
Arnel
matt martin
matt martin
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
