Question about Kitchen Ranges
Whirlpool oven model number SF362LXSY, and the bottom broil and bake oven not working. Need a fix
  • 126 Answers
SOURCE: Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Posted on Dec 10, 2007
  • 184 Answers
SOURCE: Broiling works but baking does not work
CHECK FOR 240VOLTS AT THE TERMINALS OF THE BAKE ELEMENT. GAIN ACCESS BY REMOVING THE BACK PANEL OF THE RANGE. SOMETIMES THE TERMINAL WILL BURN OFF OF THE WIRE GOING TO THE ELEMENT. THE WIRE WILL JUST BE HANGING THERE. BE SURE TO UNPLUG THE OVEN BEFORE REMOVING BACK PANEL. IF THE WIRE IS BURNT, REPLACE THE TERMINAL AND REATTACH TO THE ELEMENTS TERMINAL. IF THE TERMINAL IS DAMAGED, REPLACE BAKE ELEMENT.
IF THERE IS NO VOLTAGE TO THE ELEMENT, REPLACE CONTROL.
Posted on Apr 04, 2008
SOURCE: Whirpool electric oven replacing bake element
In addition to what aborcass stated, I just had to fix the same problem. Remeber to turn off the power before you do this. On my stove the element acess is behind the side panel (right side when facing the stove). You remove two screws on the back and one underneath at the bottom, (you need to pull out the drawer). Once screws are out, slide the side panel forward gently about an inch and it should just drop off.
You should see the wires for the element level with the bottom of the stove. The wires will guide you to the element. And you should see that the element is screwed in with two screws to the stove. This is the tricky bit, to remove the element follow the metal piece holding the element to the right until you see a third screw. Remove this screw and the whole thing will come out. Take off the wires, replace the element on the metal strip, slide the element and metal strip back into the stove (take care to ensure the left side of the metal strip slides into the proper position under the metal clasp. Re-attach the screw, plug the wires onto the element and turn the power back on. You should have heat.
Good luck.
Posted on Apr 05, 2009
SOURCE: Whirlpool GS563LXSS: bake and broil doesn't work.
Oven suddenly stopped to work.
After trying to turn on "bake" or "broil" I can hear couple clicks but nothing else happens.
No flame/no gas is coming out.
Posted on Jun 11, 2010
heatman101
  • 43501 Answers
SOURCE: top oven not heating up on BAKE, broiler gas and
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Jan 09, 2011
Both Oven elements do never come on Together, Top Works When turn on Broil and Bottom when On Bake & Auto. Pls help.
that's normal. The top element is meant for broiling only while the bottom one is meant for baking.
Mar 11, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Auto clean problem
You say you checked the thermal fuse but did you check the broil element for continuity. Most ovens use the broil element for the clean function. The thermal fuse will shut off both the bake and the broil element.
Feb 16, 2014 | Whirlpool GBD307PR Electric Double Oven
Whirlpool oven WGP30801
Your model suggest a gas unit on gas units only bottom burner operates in bake on electric bottom elements heats broil cycles.
Feb 12, 2014 | Ovens
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
RBS305 replaced thermal cutoff twice and again it won't come on bake or broil
Good Evening!
The self clean feature is causing your thermal fuses to fail or open. This is a safety mechanism that when open (bad) won't allow electricity to pass through any longer. The temperature in your oven exceeds what the components in your appliance can handle. If you want your oven to last it's longest, I would discontinue using that feature. If ever the control board or keypad on your oven by way of the self clean feature, we can help you with that. Fixyourboard.com can help. Send all inquiries to info@fixyourboard.com . Thank you!
Jun 05, 2017 | Whirlpool RBS305PD Electric Single Oven
Need schematic to hook up my new oven control on a whirlpool wrp 37680 stove ,,kids screwed up my set up over the week it took to get part
Could not find that model. Please check on machine, Does the control have 6 connection points on it? 2 on top sides 2 bottom sides and 2 on bottom? If so The top two are the power Bk and Rd. the left bottom is bake and pilot. Bot.left is broil Bot rt is the other bake Left bot is broil and pilot.
Nov 22, 2010 | Whirlpool Kitchen Ranges
Kenmore Oven
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
PS go to searspartsdirect.com, type in your model number for the exact replacement part number.
Oct 27, 2008 | Stoves 500SIDL Gas Kitchen Range
Oven or broil does not work
hi thanks for the question . the control board seems to be defective the clicking noise is the relay .but not letting power to the elements thanks the appliance doc
Sep 28, 2008 | Whirlpool GY396 Electric Kitchen Range
Broil turns ON when pressing BAKE button on RBS275PD Whirlppol oven
Our Whirlpool oven just started doing the same thing!!!! The Delay Start Time (setting it for one minute ahead) and then Start works just fine.  But we fried the tops of three loaves of homemade bread!!!!
Is Whirlpool just a bad brand for ovens?
Dec 07, 2007 | Whirlpool RBS275PD Electric Single Oven
Maytag oven will not light
Have you tried to broil or bake? if only one of them work you have a bad ignitor. let me know and we can go deeper
Aug 23, 2007 | Maytag CWG3100A Gas Single Oven
Kitchen Ranges Logo
122 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
