Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
Every time I go to a new page it causes static on the picture for a second then disappears. When I stay on one page it is fine...whenever I change web pages, it flickers for a second or two again. Reloaded driver, changed power cord, changed DCI cord, but still no help.
    Scholar:
  • 85 Answers
Sounds like a video connection problem. It is either your video connection on your PC or the monitor. You can try connecting it to a different video connector on your PC; there are normally a VGA and one other connector. If that doesn't work, it could be your monitor. Try taking it to a computer store and having the techs plug it into floor models.
Posted on Oct 15, 2010
When I turn on my Vizio, the picture is "squished" and the bottom 1/3rd of the screen is white static. The TV is only 6 months old.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 22, 2014 | Vizio Televison & Video
Toshiba sl738b
- Flickering screen
- Dim screen
- Slow start
?Check the cables, connectors and connections.
Apr 11, 2014 | Toshiba Televison & Video
Change the combination on a DHo74E
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777).
You should set the lock to your own unique master & manager code immediately.
Please keep your codes in a secure location. You may also register your codes on our website at www.sentrysafe.com.
A single signal (LED flashes and beeps once) response from the lock indicates valid entry.
A double signal (LED flashes and beeps twice) response from the lock indicates an invalid entry.
• If three incorrect entries are entered in a row, the keypad will shut down for a period of five minutes. During this shut down period you will not get a response from the keypad.
Changing the Master Code
(Code length: 1 to 10 digit code) Always perform this operation with the door open.
1. Enter: # - Existing Master Code - #
2. The set light will stay orange for ten (10) seconds.
3. Enter: 1 - * - New Master Code - # - New Master Code - #, before the orange light disappears.
If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3.
Test the new code several times before closing the door: Enter: * - Code - #
• The lock will indicate a valid code change with a single signal.
• The lock will indicate an invalid code change with a double signal and the old code is still valid.
Changing the Manager Code
1. Enter: # - Master Code or Manager Code - #
3. Enter: 2 - * - New Manger Code - # - New Manager Code - #, before the orange light disappears.
Activate user codes
3. Enter: User ID Number (3-7) - * - New User Code - # - New User Code - #, before the orange light disappears.
If a mistake is made during the activation, wait thirty (30) seconds and repeat steps 1 thru 3.
• The lock will indicate a valid code entry with a single signal.
• The lock will indicate an invalid code entry with a double signal and the old code is still valid.
Example: # - Master Code or Manger Code - # - 5 - * - New User Code - # - New User Code - #. This will activate User Five (5).
Changing the user code
1. Enter: # - User Code - #
3. Enter: New User Code - # - New User Code - #, before the orange light disappears.
The Master and Manager can also change the user codes by following the "Activate user codes" section steps 1 thru 3.
Deleting user codesAlways perform this operation with the door open.
3. Enter: User ID Number (3-7) - * - # - #
Programming your lock codes
Dec 17, 2012 | Sentry Safe Dh-074e Solid Steel Depository...
I want to change the combonation
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777). You should set the lock to your own unique master & manager code immediately.
Activate user codes
How to get rid of static
Your radio allows you to listen for weak signals on
the current channel at the press of a key.
To turn ON the Monitor Mode:
• For brief listening, press MON button. The RX
icon blinks.
• Press and hold MON button for 2 seconds until
two beeps sound for continuous listening. The
receiver circuit stays open, letting both the noise
and weak signals to be heard.
To turn OFF Monitor Mode:
Press MON button to return to "Normal" mode,
and the RX icon stops blinking and disappears.
Dec 28, 2011 | Uniden GMR22382CK Two Way Radio
Tv turns on, picture disappears after a few seconds, turn off tv, and then on, same problem picture is fine, the disappears after a few seconds
You may have either failing 24vdc power supply or the backlight inverter board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Aug 07, 2010 | Televison & Video
TV works fine for a while, then the picture disappears.
I would just replace the TV, the parts are not going to be made to repair this. The set is just to old.
May 12, 2017 | Mitsubishi VS-5077/78 TV
Tv sound works but there is no picture
adjust the video IF,it is rectangular metal with a small gray crew inside .it is beside the jungle IC,they had 3 pcs. there adjust it one by one and observed the effect while adjusting.
NOTE: don't use precetion screw ,use plastic or wood stick.
Oct 13, 2008 | Televison & Video
My panasonic palmcorder is having video problems
First of all, try using a head cleaning cassette. Secondly, it is now 24 years old - I am surprised it is still working at all (or maybe you are having it serviced annually ?)
Apr 19, 2017 | Panasonic PV-D308 VHS-C Analog Camcorder
STATIC CHARGE
First thing I'd check is the powerbar. Did you plug the TV into the outlet direct? What caused the breaker to trip? If it was an overload by using too much current, there is a possibility that there is a loose connection in your house wiring causing arcing and the interiference lines you're seeing on the display. You may even want to try the set in a different outlet if the powerbar checks ok, and if the set then works fine, get an electrican ASAP!
Dec 19, 2006 | LG 42PX3DCV 42 in. Plasma EDTV
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
61 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Dudeman321
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
