Question about Samsung SMT-190 19" Flat Panel TFT LCD Security Monitor
I want to view my DVR over a network & internet. I had in the past, but I needed to replace my router. Now I cannot connect. Can you help me?
    Master:
    Sergeant:
  • 381 Answers
You will need to enter the settings for the connection
Posted on Oct 15, 2010
How to find dvr ip address
what do you want the DVRs local IP address on your LAN or your internets public IP address?
to see the local IP that the DVR is on, check the menu's in the DVR as if configured properly you should have it set up as a static IP on your LAN...
if you can not find it there, you should be able to log into your router and view connected devices... some routers are better than others, but you will probably only be able to see devices that are connected and assigned an IP address from your routers DHCP table..
if you want your public internet IP address then go to http://cmyip.com but in order to view your DVR from a different location on the internet you will need to set up port forwarding on your router - the DVR manual should show what ports need to be forwarded...
you may also want to consider using a dynamic DNS service if you do not have a static IP from your internet provider... most DVRs that I have encountered provide a dynamic DNS service..
Thanks,
Sep 15, 2014 | Computers & Internet
I cannot access my internet viewer
More details are required.
The Samsung 'SmartViewer' program starts up on a computer. You can access it whether you have a recorder or not.
The Samsung 4 channel DVR has a menu to set IP address & ports to use and a netjack to connect to internet. You can access the DVR from any computer connected to the same router as the DVR by inserting the same correct info into 'SmartViewer' as in the the DVR.
Once you open the required ports in your router, port forward the router to the DVR, any incoming requests from the internet to view should connect and with the correct password you can view your security cams.
With minor adjustments..that's it.
What didn't you do?
Dec 25, 2012 | Samsung 4 Channel Dvr
I have a H.264 DVR with system V2.00.R05. What app or system can I use to view on a iPhone 4S?
IP CAM VIEW found in the Itunes Market: http://itunes.apple.com/us/app/ip-cam-view/id471794610?mt=8# should work as long as you have the network settings properly configured in both your DVR and Home Network. I recommend setting a Static IP for the DVR on your Home Router. After you have assigned the IP goto the network settings on your DVR and input the IP Address you assigned, the SubnetMask of your Home Router(usually 255.255.255.0 or 255.255.252.0), and the Gateway of yourHome Router.(i.e. 192.168.0.1/192.168.1.1/192.168.1.254). While you are on your Network screen I recommend changing your default TCP Port andHTTP Port to something that is not commonly allocated. As with most Routers you must Create a pinhole in the firewall to allow the outside traffic in. Select your DVR's IP on your Router and Create Definitions for both Ports that you set on your DVR's Network Menu. If your DVR and Router didn't reboot after saving these changes reboot.On the phone ap I found the following two cameras to work with the H.264 DVR System V2.00.R05:
  • Make: Unknown Brand Model: DVR-9008HV
  • Make:A.V.Sistemi Model:A.V.Sistemi 61xx DVR
For the Host/IP field, You use your Home Routers Internet IP. TCP port is the number you set on the network menu of your DVR. Ch.# is the Channel Cam (1-8, and 9 being a single feed of all 8 channels)user names and passwords are case sensitive.
I hope this helps
Jul 07, 2012 | Apple iPhone 3G
Samsung SHR-1041K. Cannot connect to DVR system "Unknown Error"
Samsung 1041k DVR - Camera Web Server Solutions. ' UNKNOWN ERROR' OR 'CANNOT CONNECT TO SERVER'
Holy Smokes! Can't anyone write a simple solution? The manual totally sucks. It tells you everything except the details that will complete the puzzle. The answers here, so far, are written by gearheads who can't write an easy sentence.
1. The user name is case-sensitive. So if you program the DVR with a user name it will only take capital letters by default ... so when entering the user name (USER ID) in the web setup ... It MUST BE CAPITAL LETTERS otherwise you will get an 'unknown error'. There is no mention of this important little fact anywhere....
2. Use Internet Explorer ONLY (becase of old Active X controls), not FireFox, Chrome, or Safari...etc...etc. IE9 doesn't like it either .. just goes white for the most part or flickers ..so IE8 seems to work best.
3: When programming the DVR Box using the MENU button and the 'NETWORK OPTION ...Use Port 6100 in the NET CLIENT PORT. In the WEB SERVER PORT use port 80. The difference is ... port 6100 is used for the basic connection of the network to the DVR device and camera hardware and software ..... and port 80 is for viewing through Internet Explorer. (Port forwarding in the router must direct those ports right back to the IP address of the DVR (whatever you set it to). TCP and UDP together work just fine... not necessarily one or the other . I tried it both ways .. they all work.
4. If you are lucky enough to finally get Internet Explorer to hit the DVR software via the correct IP address and port of the DVR.... then it will prompt you to install the Active X control software embedded in the DVR. You might hae to refresh the screen a couple of times for it to download and install. If indeed it does then you will get a blank box that will wait for you figure out you need to click on a little wrench to configure the DVR connection. Add the DVR (give it a name). Enter the IP address it was configured with .... and set the port to 6100. Remember to capitalize the User Id and put in the password and save .. Completely IGNORE the confusing little matrix boxes that are used for setting up multiple DVRs and cameras. Save the setup, it wil take you back to the blank Samsung box interface and wait till you figure out to hit the connect button in the center. If you did it all correctly then you should connect to the camera views..
4. If you are going to view the cameras from the home network .... then enter the IP address assigned to the DVR PRECEEDED by http:// . Believe it or not it seems to make a difference. If you are viewing from ..say .. your work.. put in the numerical address of your home IP address and if you have the port forwarding set up correctly you will be forwarded directly to the DVR camera software where you can sign in and see the screens.
I have set up many, many IP cameras and various DVRs and software packages professionally.. I must say that this DVR and software is not very intuitive and was very difficult to get past some of the issues. The included instructions were of little help. I hope this helps somebody else.
Gary
Jun 28, 2010 | Samsung 4 Channel Dvr
I have a shr 1041, I can view on computer using network cable but do not know how to view off site. any help? Thank you
Your DVR has a built in webviewer. Connect the RJ45 network cable from DVR to your DSL router. Now the IP address of the camera is all you need to type in the browser to see it.
Let me know if you want to broadcast it over the internet as well.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 21, 2010 | Samsung 4 Channel Dvr
I have a sentient 4 channel cctv DVR with networking. It works ok locally but, I am having problems setting it up to view via the internet. I have a wireless router with a static IP address. I have tried...
have same unit colin and was a nightmare to sort but finally did it.
you need to set up port forwarding on your router and set up dydns account and switch on the service on your dvr. enter details on dydns page on dvr.
if you cannot log in via web address provided by dydns try entering your ip add with port your forwarding like this 89.79.89.87:9950
hope this helps
Mar 21, 2010 | Computers & Internet
Actiontec MI424 and Direct TV DVR
Your DVR need to be set at 71.182.140.***  *** meaning an available address.  Then they will connect.
What is make and model number of the DVR?
Sep 10, 2008 | Actiontec (GT704WG) Router
CCTV-DVR
Have you given this computer Permission for you to remote connect, let me know?
Aloha
Bob
Jan 13, 2008 | Computers & Internet
Q-See System Not Listed in available computers
http://www.portforward.com/qsee/
Choose the model of your Q-See DVR and then select the model of your router.
Nov 11, 2007 | 2wire 2700HG-B Router (2700HGB)
Samsung SMT-190 19" Flat Panel TFT LCD Security Monitor Logo
128 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
