Question about RCA OPAL M4001 MP3 Player
RCA Opal i have a RCA Opal my keys wont work altough its not lock axcept some time when i tape it on his back a little
  • 8,596 Answers
OK - just hold the Hold -> switch
Posted on Jun 18, 2008
Keys locked
you go to whereever u got it and ask them
Mar 01, 2010 | RCA OPAL M4001 MP3 Player
My Opal RCA MP4 player will not play. it keeps
Assuming the lock key on the back of the player is in the unlocked position, it sounds like there is a corrupt firmware file. This should just need a firmware reinstall.
Download the firmware install from the RCA website: http://voxrightnow.custhelp.com/app/answers/detail/a_id/2558
Follow the on-screen instructions to perform the install.
Be sure to back up any important media before performing this install.
If your computer does not recognize it, press and hold the play button while connecting the device for upwards of 30 seconds.
Nov 20, 2009 | RCA M4204 MP3 Player
Computers wont read my RCA OPAL mp3
download the update it will fix your problem mine did the same thing.....the RCAeasyRip program should install off the opal and if not then id say exchange it....i bought one and it has worked great
Nov 24, 2008 | RCA OPAL M4001 MP3 Player
RCA Opal MP3 player stuck on "keys locked"
Push down the key lock switch, I think on your model it is on the side of the unit.
If it does not work, try performing the reset procedure below, From
ThaMp3Doctor
I quote
"Opal has a reset hole on the back of the unit in which atoothpick (non metallic) can be inserted to reboot the player. If thisdoes not work, I suggest that you reformat the player by using theWindows format command on the unit. To reformat the memory:
Right click on the device within the Explorer or My Computer window
Select the format command (full format) to reformat the internal memory of the device. "
If it still does not work, then the lock switch is probably faulty or stuck inside, in this case you need to take apart the unit, to fix it.
Try playing with the lock switch, or resetting the unit, that should unlocck your MP3.
Oct 07, 2008 | RCA OPAL M4001 MP3 Player
How do i put music,videos and pictures in my opal
Most laptops do not have a USB port that is powerful enough to fuel an mp3 player.
This player is not compatible with Vista or Mac
Make sure the hold/lock key is not engaged
Make sure your laptop USB port is enabled
Make sure you have Windows Media Player 10
Sep 27, 2008 | RCA OPAL M4001 MP3 Player
Keys locked.
The user's manual is available from RCA's website - it will show you the location of the lock switch.
Jul 03, 2008 | RCA OPAL M4001 MP3 Player
Mp3 player says key locked system shut down
I had this same problem on another RCA player.. with no instructions manual it was hard to figure out what keys locked meant. Then I noticed a little slider on the side of the player, it has a little icon of a pad lock on it. Once I slid this back, the keys lock problem went away and I was able to listen to my music once again.
My best guess of what keys locked means.. you don't want you mp3 player to turn on when you put it in your pocket with your keys, so you change the slider to be locked, when your sit down and your keys are pressing against your on button, the mp3 player will shut off... as we all have experienced in frustration.. saving your battery.
Perhaps RCA should make this slider bright orange so it pops out and does not blend in so much, or they should put it right next to the on button.
Apr 30, 2008 | RCA OPAL M4001 MP3 Player
Keys locked on a M4002A RCA opal
On the side there is a switch try pushing tht DOWN and it might help ......... If it doesn't work I am really sorry ! :)
Oct 04, 2007 | RCA OPAL M4001 MP3 Player
RCA OPAL M4001 MP3 Player Logo
51 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
