Question about Garmin GPS
I just purchased an Approach G3 Golf GPS.. I have used it 3 times and it performed well. However, I tried to use it Tuesday and it told me the batteries need charging even tho' I had just charged them. Took it out again yesterday and it would not find the course I was on and then the unit went completely black. I turned it off and tried again this AM with the same result. I'm using re-chargeable NIMH batteries. Hope you can point me in the right direction to get this issue fixed. I bought the unit at Golf Galaxy in Roseville, CA.
    Genius:
  • 1,478 Answers
I suggest you reset your GPS, to reset your gps, follow this steps, turn off your device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press ?Yes? to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Once the GPS unit is reset, remember to place the device outside where there is a clear unobstructed view of the sky for 15 ? 30 minutes in order for it to requires fix to GPS satellites. with this, this should fix the problem.
Take care.
Posted on Oct 15, 2010
My sd card is missing on my Garmin Approach G5 Touchscreen Golf GPS. What do I do
You almost certainly do not need it. If your map list is not showing or if it locked try this:
Firstly, please connect your device to a computer. You will find a folder in the device called 'Garmin'. In this folder will be multiple files that start with the phrase 'gmap'.
Please delete the files starting with 'gmap'.
Once you have done this, please re-load the courses on your device using the Garmin CourseView updater which can be found here:
http://software.garmin.com/en-GB/courseview_updater.html
Oct 25, 2013 | Garmin Approach G5 Touchscreen Golf GPS
Hi, I just purchased a Garmin Approach G3 in New Zealand. My local course, Rangitikei Golf Club, should be loaded according to the Garmin web site but its not showing on my unit. Tried finding the course...
  • you may have to upgrade map data........how old is this unit?
  • have you loaded current firmware upgrades? more info would be appreciated......meder's tv service
Sep 24, 2013 | Garmin Approach G3 Golf GPS Receiver
Garmin Approach G3 screen freezing
Try loading or reloading the latest system software using the Garmin WebUpdater program.
The WebUpdater program will resolve most issues.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
You may also want to contact Garmin Tech Support for assistance.
1-800-800-1020
Feb 27, 2012 | Garmin Approach G3 Golf GPS Receiver
I need an instruction manual for a garmin G3
go to static.garmincdn.com. you get one free download there
Jan 11, 2012 | Garmin Approach G3 Handheld GPS Receiver
GARMIN S1 GOLF GPS WATCH. I WOULD LIKE A LIST OF THE GOLF COURSES I CAN VISIT WITH MY GARMIN S1 WATCH. MY EMAIL: BRAEM.FRANCINE@SKYNET.BE THANK YOU
A list of the European golf courses for the Approach S1 Golf GPS watch can be found on Garmin's website.
http://www8.garmin.com/intosports/golfcourse.html
Sep 20, 2011 | Garmin GPS III Plus GPS Receiver
My G3 does not start - it shows the word Garmin and the screen flashes every 5 seconds but that is all. It will not shut off unless a battery is removed. Connecting to a USB port on my computer and no...
Hi, According to your problem, first check the battery status. recharge the battery or replace it. Make sure that your GPS device is updated. Check the software update and the firmware update. You may need a master reset for your GPS device. But first make sure the battery is OK or replace the battery.
Jul 28, 2011 | Garmin Approach G3 Golf GPS Receiver
Recently bought a Garmin G3 approach - only turned it on in the garden but i dont get a GPS signal and its not as if i am surrounded by high rise buildings !!.
Initially a GPS may take 20-30 minutes to obtain satellite lock, try leaving the unit powered on in a window or something of the sort. If you are still unable to achieve a lock try giving the unit a firmware update using Garmins Webupdater Software. Here is a link to the necessary software http://www8.garmin.com/products/webupdater/howtoinstall.jsp.
Hope this helps!
May 10, 2011 | Garmin GPS
When i turn on gps message reads no gps signal if you continue search results may not be based on your current position. ok or cancel
Your GPS MUST have line of sight to the satellites.
Are you in the garage or is it a very cloudy day.
Also tall buildings can block some sat view the GPS must have at least 3-4 to work most link to 7-9 all the time. GPS do not work well in metro areas too many tall buildings.
Jun 02, 2010 | Garmin Approach G3 Handheld GPS Receiver
Can i down load golf courses to my garmin 260 i was told at the store this was possibble but i cant find any info on the garmin 260 gps on the garmin web site to tell me that i can do this. Or do i have to...
It's "possible" to use the 260 as a golf GPS unit, but it probably isn't going to be the golf tool the guy at the store promised.
1. There aren't any golf maps available for this unit, other than ones that have been created by users. 2. The 260 displays distance in feet or miles: is that a 5-iron? 3. The battery life is about 9 holes on the Nuvi series.
On the other hand, if you want to have a navigation GPS and also use it on the golf course, then you can check out the details on this website:
http://www.wideopenwest.com/~don_barger/nuvi-software.html
There are free maps for download and a web-based tool for creating your own golf maps.
Don
Mar 06, 2009 | Garmin n?vi 260 GPS
GPS Logo
80 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
