Question about Toshiba TW40X81 40" Rear Projection Television
I suddenly lost the color on the screen and no manual adjustments seem to work to restore it.
  • leonardmb Oct 15, 2010
    It couldn't possibly be the tuner. I'm not using the tuner, only feeding a DVD (and I've tried more than one player). I'll try the reset solution. What about the projection system?
  • Toshiba Master
  • 11,800 Answers
I'm assuming that you have tried all the color temperatures, the full color setting, the full tint range and the correct input/colorstream to no avail. The only thing left that you can do then is to try to reset it - Menu, Picture, Reset button on the remote.
If even this has failed then the defect is in the tuner - you will have to call a repairman to replace it.
Posted on Oct 15, 2010
  • Azrael SRL Oct 15, 2010
    Your tv uses an LCD panels block - 3 LCD panel for the 3 colors and an optical engine. They can't cause what you describe - if they would have been faulty the image itself would have been messed up.
    If the reset doesn't work then the image processor (the one that converts the Component/Composite source in the raw data used by the LCD's) is defective and for that you will gonna have to replace the entire image board. It will be very expensive, over $600.
Toshiba laptop M105-S3051 screen strange colors: marbelized and pixalated?
http://www.youtube.com/watch?v=XVSRm80WzZk
"Consider a journey through time and space................"
A) Let's discuss why you performed a System Restore in the first place.
1) Screen resolution seemed to be messed up?
2) Thought you picked up a virus?
3) Will Biff from Back to the Future, ever find true love?
NO...............just wanted to see if you were following along, lol!
Suggest you go to Display Properties, and see what the Screen Resolution is.
Right-click on an empty area of your desktop screen> Left-click on Properties at the bottom of the list > Left-click on the Settings tab.
Screen resolution should be 1280 X 768
Use the slider to adjust it.
Color quality should be -> Highest (32 bit)
If you adjust either one (Or both), go to the bottom right, and click on Apply, then to the bottom left; and click on OK.
Please post back in a Comment.
Regards,
joecoolvette
Apr 08, 2013 | Toshiba Satellite 5105-S501 Notebook
LOST COLOUR: C29 F500DR The colour seems to have disappeared on my Wow by srs C29 F500 DR. I have a digital set top box attached. I cannot seem to restore colour. Any adjustment of the picture via remote...
I suspect that you have connected via componet I would check the red green and blue cables
you may have lost a one of the colors but check the cables first
is it b/w on it's menus?
if it is you have a color element out
Sep 22, 2008 | Hitachi Televison & Video
I have had this TV 6 months. Got it from a friend. The set worked perfectly in my house for 3 months. The color seems to have suddenly changed giving a gold tint to all cable channels, dvd's etc. I have...
I don't want to seem condescending in anyway but i would try checking all your cables to see if they are plugged in properly and if that doesn't help id suggest buying new cables and testing those to see if your old ones have died out. If it isn't the cables then return them but at the least we've figured out what it isn't. Other then that i cant really see of any problem other then an internal one.
Feb 28, 2011 | Mitsubishi WS-55411 55" Rear Projection...
TV suddenly lost the ability to project red
Reset the colors setting back to factory original setting.Should have all colors back to original.Not than ur main tuner signal board is dead,must replaced.
Jan 12, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Akai PT5499hd that has suddenly lost color alignment
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 23, 2009 | Akai PTH5498 54" Rear Projection...
LG DLP Flat screen suddenly lost its red color
The Lamp would not cause this problem. If you are using Componet Input only, I would look to see if the Red Signal Cable has pulled off the Input Jack or is bad. If you have no Red in any input and also do not have Red on the User Menue, It would probably be the Opical Engine.
I hope this helps,
Skyassoc
Aug 25, 2009 | Televison & Video
Colors on screen distorted - depending on position of subject
you may have some magnetic particle in the tub area if you feel skill full open up shell and dust out should be restored also verify you do not have a speaker ontop of the tv speakers have magnets and are not shielded
May 08, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
RCA 52" big screen tv
sounds like one of your tubes got weak, im thinking the red tube, needs to be adjusted manually
Dec 26, 2007 | RCA P52937 52" Rear Projection Television
Sylvania Model 6420FF Television - How Do you Adjust Color?
Hit menu on your remote - click on picture - scroll to color
If you need a copy of your owners manual please click here
Oct 21, 2007 | Televison & Video
Screen lost some colors
www.dg-kehao.com
please check this website you will get the replacement you are looking for.
if you want to ask something directly, please contact me: pda.lcd.china@hotmail.com
Aug 28, 2007 | Toshiba e740 Pocket PC
Toshiba TW40X81 40" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
