Question about Kenmore 44103 Side by Side Refrigerator
Need info for a kenmore side by side refrigerator model#59652673202 it it not cooling nor freeszing ; the light works and the fan works but not cooling any side please help me
    President:
  • 1,218 Answers
Good day,
With that amount of info it would be hard to try to pinpoint it. Here's a list of items that can cause a refrigerator to not cool.
Items that will cause a refrigerator not to cool.....
1. Defective thermostat
2. Defective freezer fan motor
3. Defective defrost timer
4. Defective defrost thermostat
5. Defective defrost main heater.
6. Defective condenser fan motor
6. Defective compressor overload protector
7. Defective compressor start relay
8. Defective compressor start/run capacitor (some models only)
9. Defective compressor
10. Restriction in refrigeration sealed system
11. Loss of refrigerant (leak)
12. Excessively dirty condenser
13. Broken wires, bad wire harness connectors, ect.
14. Defective fan motor switch (some models only)
As you can see it could be one of many,many items. If your handy with a meter you might want to start at the bottom back of the machine where the compressor is located.
Sounds as if it is not running, or running without refrigerant in the system.
Also, if it has a cooling fan motor in that area, make sure it runs, since all fan motors are wired to run at the same time.
Posted on Oct 15, 2010
Kenmore coldspot 106.53769202 will not cool fridge, have deg=frosted,vacuumed underneath and emptied drip pan, no air blowing into fridge. Had gnats inside while power was off for over a month.
Does the compressor run? Does the small tube get warm? is the inside fan working? does it have an outside condensor fan? Is power getting through the thermostat due to gnats between the contacts? Does the inside light work? need more info.
Oct 16, 2013 | Kenmore 50522 / 50524 Side by Side...
Where is the defrost timer on a kenmore side by side model # 106.58904801
What you should be looking for its a dead fan motor. The condenser fan motor cools the refrigerant and allows the compressor to stay cool with the returning cool refrigerant. If the fan motor is working intermittently then the fridge will do the same. Usually the fan will work for a wile but when it gets hot the lubrication to the bearings becomes poor and the bearings get worn ant the shaft will fall and the rotor will lock up. Condenser fan motor is usually located on the bottom backside of the fridge. Do not run the fridge until the motor is replaced, you can create a whole lot of other problems that will need to be taken care of by a professional. Good luck
Sep 08, 2012 | Kenmore Refrigerators
Wont stay cool
does it cool and then stop when it does this is there frost in the fzr compartment or ice build up. Does the fans run at all do you hear the compressor and compressor fan running. Just need more info
Aug 17, 2010 | Kenmore 57029 Side by Side Refrigerator
Fridge not cooling or freezing
You can start with replacing the start capacitor and relay to see if the compressor will run again, but you have about a 50 -50 chance that the compressor has gone bad and will need to be replaced....
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 12, 2010 | Kenmore 52673 Side by Side Refrigerator
Moved working Kenmore refrigerator now it does not cool,
moved refridgerator now not working only light on??
Oct 07, 2009 | Kenmore Refrigerators
My Kenmore 596.50692001 side by side stopped working last night. The fan was not working at first. It eventually came back on and the unit seems not to be cooling. The compressor was a little hot???. The...
replace your fan,cause is no cooling the compressor,and check if the compressor didnt burn out to.if my info was of any help to you please leave me a comment ,thankyou.
Sep 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side, fan on, lights on, compressor hot, no cool.
You probably have a bad overload/relay on the compressor . The piece which plugs onto the compressor . Or a bad fan which cools the compressor (condensor fan motor ). Also check the coils to make sure they are clean . Would need the first 3 numbers before the ones you gave , to be able to give you the part number for the o/r .
Jul 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrigerator not cooling and lights out
is the compressor hot? same as last job. unplug ref. clean the condenser coil, install new 3n1 start relay on compressor.
Nov 04, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerator stopped cooling
The most common problems for refers not cooling is a condenser fan motor (the one that cools the compressor) is out. This can be caused by either a mouse has tried to jump trough the fan and it came on or a loss of grease or oil. There is no way to oil them so they have to be replaced. That is the problem especially if you unplugged the refer and it worked for a while then quit. If the fan doesn't cool the compressor it will overheat and shut down coming on intermittently then shutting off again. As for the refer that still doesn't cool when everything else does you may have an burnt overload also. Check the compressor area for burnt or stalled components ex. fan motor, relay, overload. If your compressor is out plan on spending from $300.00 to $500.00. But check the suggested components first. And beware there are appliance shops out there that will find one of these problems and give you an estimate for a compressor. Find someone reputable.
Jun 18, 2007 | KitchenAid Superba Architect KSCS25INSS...
Kenmore 44103 Side by Side Refrigerator Logo
171 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
