Question about Samsung SF-5100 Plain Paper Laser Fax
Cr fuse error? - Samsung SF-5100 Plain Paper Laser Fax
CR Fuse Error Samsung 4016. Replacement toner cartridge threw this error, found small glass cartridge fuse on top-front edge of cartridge, swapped fuses with my old cartridge, voila. Replacement fuse was good, had continuity, but felt to me to be slightly smaller diameter than original fuse.
Posted on Jun 07, 2012
Message is Service call error 00010014 I have an Epson Stylus pro 9800 and I am getting a message saying: Service call error 00010004 error 00010004 SERVICE CALL 00010004DescriptionFailure of ...
Epson Stylus Pro 4400/4800/4880 Error Codes
Maintenance Request Codes:
• 0002 - CR Motor near end of life - Replace carriage return motor ASAP
• 0006 - Battery shut off - Replace RTC back-up battery
• 0040 - Cleaning unit near end of life - Replace cleaning unit ASAP
• 0080 - Date not set - Set the date through the printer control panel
• 0088 - RTC backup battery not installed - Install RTCbackup battery
• 0100 - RTC backup battery pressure is temporally low - wait for a while
• 0200 - The number of ASF paper feeding has reached predetermined value
• Service Call Codes
• 00000101 - CR Motor reached end of life - Replace carriage return motor
• 00010000 - PF encoder check error
• 00010001 - PF motor is out of step
• 00010002 - PF motor overcurrent has occured - Replace PF motor
• 00010003 - PF motor out of postion time-out error
00010004 - CR encoder check error - ensure enoder strip is clean & dust free
• 00010005 - CR motor out of step - click here for more info
• 00010006 - CR motor over current
• 00010007 - CR motor out of position time-out error - Replace the board assembley, main
• 00010008 - Servo interupt watchdog time-out error - Replace the board assembley, main
• 0001000A - Carriage home position detection error
• 0001000C - PG home position detection error
• 0001000F - CR motor PWM output faulty
• 00010010 - PF motor PWM output faulty
• 00010012 - CR overload (high sensitivity) error
• 00010013 - PF overload (high sensitivity) error
• 0001001B - Head Driver (TG) temperature error
• 0001001D - CR servo parameter error
• 0001001E - PF servo parameter error
• 00010020 - CSIC reading/writing error
• 00010022 - Ink type error (setting on printer body side)
• 00010023 - RTC analyzing error
• 00010025 - SCIS ROM communication error
• 00010026 - RTC communication error - click here for more info
• 00010028 - Head error - replace print head
• 00010029 - Unidentified NMI
• 0001002A - CR ASIC ECU error - Reinstall/update firmware
• 0001002B - PF ASIC ECU error
• 0001002D - Cleaning unit has reached end of life - replace cleaning unit
• 0001002F - 360 DPI writing time-out error
• 00010030 - Multi sensor error
• 00010031 - ASF phase detection error
• 00010032 - ASF drive switch error
• 00010033 - Eject phase detection error
• 00010034 - Eject movement error
• 00010035 - Pump phase detection error
• 00010036 - Type-B board installation error
• 00010037 - Head thermistor error - Replace print head
• 00010038 - Transistor thermistor error - Replace board assembley, main
• 00010039 - PG adjustment value incorrect overwrite error
• 0001003A - PG adjustment value outside range error
• 0001003B - Cutter installation error 1
• 0001003C - Cutter installation error 2
• 0001003D - Cutter installation error 3
• 00020000 - NVRAM error - Replace board assembley, main
• 00020002 - SDRAM error - Replace board assembley, main
• 00020003 - Boot program SUM error - click here for more info
• 00020009 - Flash memory SUM error
• 0002000A - Program load error
• 0002000B - The internal memory is insufficient
• 100000E0 - CPU address error (load)
• 10000100 - CPU address error (store)
• 10000180 - CPU reserved command code exception error
• 100001A0 - CPU slot undefined command exception error
• 100001C0 - The AC power is shut off
• 100005C0 - CPU DMA address error
• 10000xxx - CPU error
• 0003xxxx - Debug orode
• 0Dxxxxxx - An error code for debugging
• 0Exxxxxx - A time-lag of the RTC timer
Mar 24, 2018 | Epson Office Equipment & Supplies
Tip
Epson Stylus Pro 3880
ERROR CODES CAUSES AND SOLUTION
1101
CR life error The CR scan path counter has reached a predetermined level.
(The end of life of the Ink Supply Tube)
Replace the Ink Supply Tube (INK, SYSTEM, ASSY) and reset the counter using the Adjustment Program. In addition, check the statuses of the CR motor (MOTOR ASSY.,
CR), the driven pulley, the Carriage Unit, and the Head FFC, if any abnormal noise or wear is found, replace the corresponding part(s) along with the Ink Supply Tube.1120
CR lock error The CR encoder failed to read the CR scale during a predetermined time period. Replace the CR encoder (BOARD ASSY., ENCODER, CR).
Replace the CR scale (SCALE, CR).The carriage unit does not operate due to a CR motor failure or some reasons. Move the carriage unit manually to check if it moves smoothly, and fix any abnormality.
Replace the CR motor (MOTOR ASSY., CR).1121
CR reverse error An abnormal operation (reveres movement) of the carriage was detected a predetermined number of times. Check the CR scale (SCALE, CR) for incorrect attachment, scratch, dirt, and fix any abnormality. Replace the CR scale (SCALE, CR).Replace the CR encoder (BOARD ASSY., ENCODER, CR).
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
on Feb 23, 2016 | Epson Stylus Pro 3880 InkJet Plotter...
Pls I need your help as the cover to my fuse box panel is missing therefore can't locate the audio fuse. Model: CR-V RD 1 1997-1998.
There are two: 10A RADIO FUSE 28 in the underdash fuse/relay box and 7.5A BACK UP, (RADIO) FUSE 47 in the underhood fuse/relay box.
Nov 29, 2016 | 1998 Honda CR-V
Fuse diagram 2001 honda crv
On this website, you find fuse box diagram and description Honda CR-V (2000 -2001)
Honda CR 2000 2001 fuse box diagram Auto Genius
Oct 14, 2012 | 2001 Honda CR-V
Honda crv 2003 brake light fuse
For a 2003 Honda CRV, disconnect the horn fuse (#7), located in the under hood fuse box. This will also kill the rear lights. My underhood fuse box did not match glvenu's pic above, didn't have the 2 fuses circled together. The #7 fuse in my CR-V is located below the single fuse circled in the pic above.
Jun 28, 2012 | 2003 Honda CR-V
I need a detailed diagram for the fuse boxes on a 2002 Honda cr-v
On this website, you find fuse box diagram and description for Honda CR-V (2002-2004)
Honda CR 2002 2004 fuse box diagram Auto Genius
Nov 29, 2011 | 2002 Honda CR-V
(Honda CR-V 2002 Mod. AUT) My problem is that the car starts but stops after three / four seconds. MIL light is on. When my mechanic is using the Scan Tool, he gets the code "P1298 unknown...
P1298 is a result of a alternator wire short. check fuse 6 in the driver's under dash fuse panel and see if it is blown. If it is check the black/yellow wire of the alternator and see if it is shorted to ground. repair the wire and replace the fuse. Also you might get the O2 sensor code as a result of this fuse being blown also.
Mar 19, 2011 | 2002 Honda CR-V
Need to know what fuse controls Cruise Control on the 2003 Honda CR-V.
There's two fuse:
1. Fuse#4 (10amp) fuse box on top driver feet behind trim cover.
2. Fuse#7(15amp) fuse box under hood.
If you're having problem with cruise control and horn act funny at time. You might have a bad cable reel. located in steering wheel.
good luck
Dec 16, 2010 | 2003 Honda CR-V
CR motor error prompts
CR Motor Errors are bad. Check to see if there are any bent or misaligned componenets on the carrier.
Mar 21, 2009 | Alps MD 5000 Thermal Printer
Horn fuse
look under the hood the fuse should be there.
hope this helped.
please rate good.
Mar 01, 2009 | 1997 Honda CR-V
Samsung SF-5100 Plain Paper Laser Fax Logo
93 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
