Question about GE DBXR463EBWW Electric Dryer
Dryer wont heat
My dryer wont heat everithing else works
  • 1 more comment
  • modads6 Jun 18, 2008
    My dryer is not heating. It tumbles and blows cold air but not hot. How hard is it to change the heating elements on this dryer.? Where can I go to buy the heating elements? How much does the elements normally cost?
  • Anonymous Jan 07, 2009
    i have the same problem
  • kneill7247 Jan 20, 2009
    Where is the heating element on a GE DBLR333ET0WW dryer?
    Novelist:
    Champion:
  • 244 Answers
Hi jimenez0512 this could be 1 of 2 problems 1 the heater element is down would need replacing 2 the lower heater element is down needs replacing which is the likelist problem it will be the first thermostat to the left should have a little ink dot on it when u buy the new thermostat kit it will come with both replace both u will only have to replace the higher stat within 2months anyway. Now if the thermostat has a little button on it press it and it should re-start the stat these are at the back of the dryer behind a shaped panel let me know how u go m8 peter
Posted on Jun 04, 2008
WHY MY HEATING ELEMENT DOES NOT STAY ON
may kink hose or cycling thermostate
Oct 15, 2014 | Dryers
My dryer wont heat
Not sure of my brand, but when my dryer would continue to run without heating, I replaced one small fuse in the back using Google to find the right part (What Causes Gas Dryer to Stop Heating) and a youtube video to walk me through the process. Instead of a $75 maintenance visit or purchasing a new dryer, I solved the problem for $2.50.
This video worked for me, but you could search for other brands.
May 06, 2012 | Whirlpool Dryers
Dryer don,t start . just stop and nothing happen, it is connected , there is power and everithing look good? but simply do not work!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 16, 2011 | General Electric DBXR300GGWS Dryer
Heats up shuts off wont heat back up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | Whirlpool LGR3624JQ Gas Dryer
My dryer wont heat up. The ignitor coil glows but it only heats up on occasion.
heatman101
Aug 19, 2010 | Whirlpool Dryers
My ge dryer wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
Jul 08, 2010 | GE DWSR483GB Gas Dryer
Everithing works only the heater not work
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be with the heating coil.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Oct 20, 2009 | GE Profile Harmony DPGT750EC Electric...
Wont heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
kllk
Aug 03, 2009 | Roper RGX4634KQ Gas Dryer
Dryer wont heat up already replaced thermal fuse
You gas coils are probably old and weak. check this out
Gas dryer works and quits
Apr 11, 2009 | Whirlpool Dryers
Kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Feb 25, 2009 | Kenmore Dryers
GE DBXR463EBWW Electric Dryer Logo
108 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
