Question about Gateway Computers & Internet
MA3 won't boot up. the disc and hard drive lights flash and it sounds like it's got a 'flat tire' sound inside,
    Master:
    Sergeant:
  • 381 Answers
Most likely a motherboard problem or the vga card
Posted on Oct 15, 2010
PACKARD BELL LJ71 WON'T START UP
can you be more specific as to the actual text? Also you should press F2 or whatever key is your bios hotkey and check your boot order. Make sure that the hard drive is your first boot device. it actually kind of sounds like you have a cd in the drive and it's trying to boot from it. please physically verify that there are no discs in the drive.
Feb 26, 2012 | Packard Bell Computers & Internet
HP Mini 1000 VT won't turn on, lights flash when plugged in
This is a common issue when the unit has been dropped or jarred really hard. The click is more than likely the hard drive trying to read the disk but can not access information.
With that in mind, try this: Remove all USB, SD, or any cards and attachment from you computer. If you have one at hand, connect an external monitor to the pc. Power on. If you get an image on the external monitor, restart pc and press F8, select "Enabel-low-resolution video" and move forward. If you get a picture after this, your video drivers need updating. BUT......
The clicking sound is a major concern because usually the hard drive is the only hardware part that have moving parts. (other than the optical drive or if you have a solid state hard drive.) If you have a dard drive the same size or close with an operating system on it, replace your hard drive with the GOOD drive and retry. If it boots, you need to replace the hard drive. (and hopefully you have a backup of your data)
Worst case, you may need an authorized HP agent to service your pc.
Good Luck
C2Soluitons
Feb 14, 2012 | HP Mini 1000 VT series PC Notebook
My hard drive has just stopped being recognised by my computers.The computer knows when i plug in but the hard drive does not show up in my computer. The green lights flashes internittently but not...
I had the same problem, This is what I did to fix. get a recent copy of a live disc from linux, run and boot from live disc, I used puppy linux as is small and can run from ram completely, after puppy is up and running you can mount the drive your trying to get photos off, find the photos and copy the not move, to either a portable flash drive or to the c drive acceses through puppy mounting utility, after copying all the photos you require then formatt the drive in linux puppy to ntfs, after this is done shut down puppy remove puppy disc and restart copmuter back to windows and the drive should be accessable once again, I hope this helps
Feb 13, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Unit will not boot up. The Vaio logo and Intel logo will briefly flash on the screen and then the screen will go blank for good. The power indicator light and battery light are both on. The fan is on and...
It sounds like you have corrupted files in windows, or you have a problem with the hard drive. Remove the hard drive and re-seat it back in place, start up the computer! If no change, use the original recovery disc if you have one and reload the operational system, if that fails have the hard drive tested for bad sectors at the computer repair store.
Jan 22, 2011 | Sony VAIO PCG-K23 Notebook
My hp dv2000 will not start or boot
What happens when you just boot the computer without the hard drive installed?
Jun 15, 2009 | Computers & Internet
My computer wont boot up
Sounds like your hard drive partition is bad. Trybooting from the disc and do a repair
Jan 07, 2009 | E-Machines eMachines Desktop PC
My Laptop Wont Even Boot Up
If you can here a slight clattering sound, like two discs bing clashed together the hard drive platelettes are damaged or the parking head is damaged, you will need to replace the hard drive, they are fairly inexpensive to buy, but if you are not familiar with laptops take to a qualified repairer.
Sep 11, 2007 | Acer TravelMate 2355LCi Notebook
Computers & Internet Logo
70 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
