Question about Pyle PT1200 Amplifier
My new Pyle Pro PT-1201X amp has a continuous protect(fault light after just 2 uses. The amp will still pass a signal, but it has to be turned almost all the way up. I checked the audio circuit for shorts but no joy!! The protect light remains when removed from the circuit. Does anyone know where to find schematics for this amp, or has experience with fixing this issue? I need to fix this pronto. Unfortunately there is no return policy or warranty for this amp. Any help would be appreciated.
    Sergeant:
    Champion:
  • 387 Answers
Its possible that the (((amps the components on the main circuit)) is short this is why you need to turn all the way up, or the pre amp unit.
you need to be more experienced to find this problem
if you want to fix the amp let me know
ecrdn@yahoo.com
Jack
Posted on Oct 21, 2010
Amp on but no sound
Double check all of your fuses and make sure they are the corrects AMP. Other than that it sounds like the speaker wires came loose somewhere along the line. check on the subs and behind the deck. hope this helps
Apr 22, 2013 | Pyle PLA2678 POWER SERIES BRIDGED MOSFET...
Hello, What is the proper way to connect an Ashly XR1000 Crossover and a Pyle Pro PTA1400 power amp to my Peavey XR8600 so I can use 2 subs? The subs are not powered, but do have a passive crossover...
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00513220_7.pdf I didn't look at the manual for the crossover but this is probably the way I would do it. Look at page 13 in the manual : Come out of the Main out (31 in the diagram) into the main in of your crossover. Go out of your crossover Hi and Mid out setting back into Power amp In 1 (labelled 32 in the diagram). Hook your speakers that you normally use to the output jacks on the back of the Peavey. Make sure you match the output impedances. Go out of your crossover low output into the Pyle power amp and out of the Pyle into your subs. Make sure the impedance ratings of all your speakers match the output impedances of your amps. You will only be running in Mono mode as that is the signal output of the Peavey mixer. You can run faux stereo by using the Main monitor Out as 1/2 the pair and the Main Out as the other 1/2 to both channels of the crossover but you won't be getting a true stereo pan mode.
Aug 22, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
Pyle Academy 2300 watt amp not working =(
wrap a striped speaker wire around the back of the rca out put on your cd player and for the record that aint a 2300 watt amp its like a 300 watt amp
Mar 30, 2010 | Pyle PLAM2300 Car Amp
I got a pyle 1800w amp and a 1500w kenwood subs but as i increase the volume in the headunit it goes on protect mode why the other problem i got is as increase the volume in the headunit the bass of the...
The protection modes in these units ****. Most new units have them. What I do is turn down settings on deck and turn up amp as much as possible. Then the protection won't turn on because you won't have to turn it up as high.
Sep 30, 2009 | Pyle PLA1200 Car Audio Amplifier
PyLE PT2000 Power Amplifier' { is it worth it??}
People talk alot of **** about Pyle amps, all I can say is that,
I have two PT-2000 & PT-1800 power amps that I have set in bridge mode, one for each speaker and they are powering two Altec-Lansing 18" inch subs, one amp per speaker, no hiss, line noise or anything and the system kicks. I tried the Pyles on a whim because I got tired the trouble I was having with the QSC and Crown power amps, could not go a year without having something go wrong always sending back to dealer for some kind of fix! So now I have 2, QSCs, 2 Crowns & 4 Pyles driving my system
Apr 27, 2009 | Pyle PT-2000 Amplifier
Replacement parts for Pyle power amp PT-2000
VU meters are generally illuminated by small bulbs at the back of them. It's unlikely to be a powerfull bulb perhaps 12 volts perhaps around 200ma at the most. Most electrical shops should sell something that should suffice. It could be an LED though!
Apr 15, 2009 | Pyle PT-2000 Amplifier
Amp goes into protect mode after volume is turned up
Not enough juice, check the power and ground connections, another possibility is to have dc in the input, try to use in line filter available from radio shack to cut the dc, also test the with one speaker at the time, you could have a bad speaker (shorted) too.
Apr 08, 2009 | Pyle PLA4240 Car Audio Amplifier
Amp Issues
1800W peak output at 2 ohms
975W peak output at 4 ohms
600W RMS (continuous) at 2 ohms
325W RMS (continuous) at 4 ohms
Variable LP crossover adjustable 35-250Hz
4 AWG power/ground inputs and RCA pass through
Low-pass filter
Bass boost 0-18dB adjustable remote punch bass EQ
Signal-to-noise ratio: >80dB
Line-level input
It is going into protect mode for a reason.
Disconnect the subs and turn everything on again. If the light comes on, the problem is internal and will need servicing by a technician.
Dec 22, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
Protection light stays on no output
i have the same amp and have that same issue before. yes you are correct that if you take off the RCA cables on the input there will be no light. either you have plug the remote line on the 12v or a grounded sub. it should be 12v/remote/ground from the corner. good thing im just fixing my sub earlier. it is no problem if you have hooked the remote line on the 12v, it is the same supposed to be. to check if your amp is working, short the 12v/ and the remote line and play your stereo and see if your sub is working. by the way, what sub are you using? i just blew my sub and need a new one.
Feb 02, 2008 | Pyle 1800-Watt 2-Channel Bridgeable MOSFET...
Amp protection mode
Try swapping the "bad" fuses for the "good" ones and see if that helps. That will tell you if the fuses are the problem. I doubt that is the problem. You never said what kind of problem you were having with the left speaker. If your friend dropped a drink into the amp then I would discontinue using it until it was checked out and don't be surprised if you have one channel that has some parts that need replacing, like some of the output transistors/MOSFET's. That might explain why your fuses appear to be melted. Maybe they are. In any case, get someone who knows what they are looking at to have a look see at your amp.
Jan 17, 2007 | Pyle PT-3200 Amplifier Car Audio Amplifier
Pyle PT1200 Amplifier Logo
166 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
