Question about Dell Inspiron 530 Desktop Computer
Power save mode cant start normal mode - Dell Inspiron 530 Desktop Computer
    Master:
    Sergeant:
  • 381 Answers
Save all you stuff via safe mode then reinstall or restart recovery using f8 or f11 keys
Posted on Oct 15, 2010
Why am I getting a blank screen after login?
In case you are using Win OS try to start in save mode. First the Bios is activated after pushing the power button. If you see the screen from the Bios start pushing F8 which brings you to the save mode start up. When your PC starts you can shut it properly by leaving the save mode. Try to start up the pc again in normal mode. I hope it will fix you problem
Aug 26, 2014 | Toshiba Satellite Computers & Internet
Tip
Copiers Sharp AL-1631 AL-1641CS DESCRIPTION OF SPECIAL FUNCTIONS
Toner save mode
Reduces toner consumption by approximately 10%.
Power save modes
The unit has two power save modes of operation: preheat mode and auto power
shut-off mode.
Preheat mode
When the unit enters the preheat mode, the power save indicator will light up
and other indicators will remain on or off as before. In this condition, the fuser in
the unit is maintained at a lower heat level, thereby saving power. To copy from
the preheat mode, make desired copier selections and press the start key
using the normal copying procedure.
Auto power shut-off mode
When the unit enters the auto power shut-off mode, the power save ( ) indicator
will light up and other indicators except the ONLINE indicator will go out. The auto
power shut-off mode saves more power than the preheat mode but requires a
longer time before starting copying. To copy from the auto power shut-off mode,
press the start key. Then make desired copier selections and press the star key using the normal copying procedure.
Auto clear
The unit returns to the initial settings a preset amount of time after the end of copy, or
scanner job. This preset amount of time (auto clear time) can be changed.
Stream feeding mode
For description of the stream feeding mode, see "Stream feeding mode".
Resolution of AUTO & MANUAL mode
You can set the copy resolution used for AUTO and MANUAL ( ) exposure
mode.
on Mar 14, 2010 | Office Equipment & Supplies
Cant get power saving mode off
Step 1:
Sleep Mode b> Sleep mode is primarily used with home computers (desktop computers). Sleep mode is designed to save the current work, programs, and settings of your computer using your computers memory, while using very little power. b> Hibernate Mode b> Hibernate mode is primarily used with laptop's. Hibernate mode is designed to save your computers current state on to the hard disk, then turn off your computer to stop using power completely. This mode is usually used when you do not plan on using your laptop for an extended amount of time. Benefits b> Using Hibernate mode is more power-efficient, but files may become fragmented over time by using this mode frequently. Sleep mode does consume more power, but the advantage that Sleep mode has over Hibernate is that it does not take as long to resume your computers former state when you are ready to continue using it.
Feb 23, 2013 | Lenovo 3000 Computers & Internet
Acer pc and lg monitor blank screen says power save mode on start up, anyone know how to fix this?
Actually during start-up there is a slight delay before the HDD & OS is detected by the CPU. Normally all monitors slip into power saving mode within 10 secs of inactivity of either mouse or keystroke. This inactivity is read by the monitor which promptly switches to power saving mode. However the moment the HDD LED starts blinking, the monitor wakes up & starts displaying. This power saving mode in most of the flat screens is only associated with movement of mouse or keypad. This does not register till the CPU starts up & thats why the monitor switches over to power saving mode till it starts receiving signal from the CPU.
It is a normal behaveour, so don't get worked up over it, plus you can always hit the Auto set feature on the monitor after booting the PC completely. ( I think the time out for the monitor to enter power saving mode is only 10 secs). Hope this helps.
Oct 08, 2012 | Computers & Internet
My laptop dont start up
Let it boot in Safe Mode, then shut it down like you are supposed to by clicking Start/Shutdown or in this case Restart. Then it should come up normally.
Apr 01, 2012 | Computers & Internet
My 19 " LG Monitor
If you have a problem getting into safe mode using windows Vista or 7, boot up your computer. As soon as it tries to start windows turn off the power. When you try to start it again it should come up with a menu asking if you want to use safe mode or boot normally. Select safe mode.
Dec 14, 2010 | LG Flatron L1750S 17" LCD Monitor
Monitor went into power save mode and would not come back on
If your monitor is stuck in power save mode then first of all check all the power cables connected to monitor and your CPU.
After checking the connectors start the monitor if it does not come back from power save mode then lets move towards to second step.
2 . First unplug all the power cables to avoid power shock. After unplugging the power cables open the cabinet and look for the video card on *********** board.
Take the video card out and clean it with a normal eraser.Rub it on the golden pins and clean it.
Place it again at its place.
Close the cabinet and then start your monitor and your problem will be fixed.
Thanks for using Fixya.
Nov 13, 2010 | Computers & Internet
My computer stars in safe mode. and i cant start it on the normal mode. how can i start it in the normal mode?? tell me please!
Hi, if you are only able to start in safe mode, this indicates a problem has occured with your operating system. To resolve this you will need to insert the operating system cd and perform a system restore. You will not loose any save data by performing this.
Aug 21, 2010 | Computers & Internet
When i apply power to my PC, it goes right into power save mode.
At boot up press F8 and boot in Safe Mode. Once booted then go to Start->Control Panel->Power Options. Here you will be able to set it up correctly to not go into power save mode immediately. Save and reboot - normally this time.
HAPPY HOLIDAYS
Dec 25, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
How do i get out of power saving mode on pc
try hitting F8 at stert up and click on start windows normally
Jan 22, 2009 | LG Flatron L1750S 17" LCD Monitor
Dell Inspiron 530 Desktop Computer   Logo
137 people viewed this question
Alun Cox
