Question about HP Photosmart 8450 InkJet Printer
Which cartridges go where? (left, middle, centre)
    Master:
    Sergeant:
  • 381 Answers
All cartridges will be labelled 1,2, 3 and the size also indicates where they are supposed to be inserted
Posted on Oct 15, 2010
Brother MFC-3220C. I need to change the printer cartridges but I cannot get the cartridges in the middle of the printer in order to access them--they seem stuck on the left. Help?
Turn off the power. Turn it back on again and listen to the sound of the carriage moving. When you hear it then pull the mains lead out the back. the carriage will now be unlocked and there should be no resistance to you pushing it into the centre of the machine. If it is jammed at the left end then its possible that one of the cartridge locking arms has popped up and is fouling the case. A bit of jiggery poo with a screwdriver should push it down while you try and pull the carriage to the centre.
Good luck.
Jul 20, 2011 | Brother MFC-3220C Plain Paper Inkjet Fax
I am trying to change the print cartridges for my father without a user guide and the head will not come into the middle. Can you tell what buttons to press.
go to your printer on your computer , select the ink supply levels and your program should instruct the printer to bring the cartridges to the centre
Sep 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Ink cartridge stuck on left side in cradle and will not release
Take the cradle out of the printer, using a flat blade screwdriver prise up on the left corner of the toner cartridge and pull toner cartridge from the right hand side.
the problem is cause when the toner cartridge in install incorrectly, inserting at an angle to the leftside first and so the toner trap door does not rotate.
The correct way, is to place the cartidge on the cradle and press from the centre down on the toner body.
May 27, 2009 | Kyocera FS-2000D Laser Printer
Tape has been left on new cartridges loaded and can not move cartridge carrier to take tape off.
You don't state the make/model of printer, but by opening the cartridge door, the cartridge carrier should centre.
Apr 25, 2009 | Office Equipment & Supplies
Cannot install ink cartridges
The manual may talk about a button (or combination) to press to get the cartridge to the centre. Some CANON printers do this.
Mar 04, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Carrier jam on 926 dell printer
go to page 59 of the manual ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf" if you don't have it) look for code 1200 in the middle of the page. good luck!
Feb 13, 2009 | Dell 924 All-in-One InkJet Printer
Out of ink. Can't get cartridge to stop in middle to change
hi turn off the printer open lid move cartridge carrier to the middle, this should allow you to change the cartridge, then close the lid and turn on printer this should reset carrier to home position.
Jan 15, 2009 | HP DeskJet 810c InkJet Printer
Lexmark 2300 Printer/Scanner
SNAP the cover up...literally....SNAP it up...gently lifting it into place does NOT activate the cartridge alignment. Make sure the power is on...LIFT UP THE LID QUICKLY SNAPPING IT INTO PLACE...the cartridge then moves into the middle..
Sep 22, 2008 | Lexmark X2470 All-In-One InkJet Printer
Torque and sequence to Intake Manifold for 3.3L Nissan Xterra 2000
Hi El Faraon,
I believe that you're dealing with 12 mm bolts and nuts....THESE ARE NOT THE SPECS FOR YOUR ENGINE, but I believe that if you use them you'll be close....Tighten in three stages up to 22nm....choose the bolts from the centre of the manifold and circle outwards until you reach the last one.....It may be a good idea to draw an overhead or plan view of the unit, marking out the bolt positions.....Start at the centre and mark the sequence and follow that....What is important is starting at the centre, so that nothing becomes warped....
Hope this helps,
Regards, Johngee10
Sep 06, 2008 | 2000 Nissan Xterra
HP Photosmart 8450 InkJet Printer Logo
20 people viewed this question
Seeker5211
Seeker5211
