Question about Bryant /murray Bj2200 Main Circuit Breaker 200amp
Breaker keep flipping offf is this normal. What do I need to do. IIts Hard to flip back on.
  • 843 Answers
No, that's not normal. It could be a problem with the breaker, or (more likely) it's tripping for a legitimate reason --- something's wrong with the wiring or something plugged into the circuit. You should call an electrician, but you can do a little trial and error. If this is the main breaker, then turn some of the branch breakers off to see if you can isolate the conditions under which it occurs.
Posted on Oct 15, 2010
My 2015 viking spa circuit breaker keeps kicking off when i flip the switch, what do I need to do?
There is a capacitor on or near the motor that is most likely bad or the centrifugal switch inside the motor is intermittent. Service tech is needed
Sep 14, 2017 | Heating & Cooling
The power went out and when it came back on our stove is not working. No lights on the display. The stove is dead. Is there a way to reset the oven???
Did you trip a breaker. Try to flip the breaker switch that goes to the oven. You may have to flip all the switches and flip them back on to get the correct breaker switch.
Jun 14, 2017 | Kitchen Ranges
Rug shampoo machine keeps blowing breakers now will not power on
It sounds like you have a dead short. Check the wire, it quite often will break at the point that it comes out of the machine. The power is going straight back to the panel before it gets to the motor and that flips the breaker. It probably needs the whole wire replaced. If you can take it apart, check with an ohm meter to see which wire it broken. Do not have it plugged in while doing this.
May 10, 2015 | Vacuums
The drum is turning but not heating up why?
It could be a bad heater, thermal fuse or if an electric dryer possibly one leg of your power is tripped and needs resetting at the circuit breaker on the house. Try flipping the ganged power breaker both off real hard and flipping them back on real hard and see if that restores the power to the dryer. If a gas dryer then the igniter or flame sensor could be bad.
Apr 28, 2015 | Dryers
Power went out. Is there a way to reset it?
If all the power went out in your whole house, then you need to flip the main breaker switch off then back on again. This should restore power.
If only frig went out, then which secondary breaker switch is "triggered" and flip off then back on.
Dec 31, 2011 | Refrigerators
Breaker keeps flipping off
Resetting the breakers please...don't.... it may cause a fire or the like... The Breaker is tripping because there is some fault to earth... IT is VITAL you get a Registered Electrician & get him to check it over. DO NOT TOUCH IT WHILE THE POWER IS ON! It could be LETHAL..
Feb 02, 2010 | Ovens
No heat but dryer works normal otherwise...
motor only needs one breaker to work element needs both they may look on but flip them off hard then on 3 times.... I know you say the motor is running... JUST DO IT IT if no heat then check element
Aug 12, 2009 | Dryers
KitchenAid elec. dryer not heating
check and make sure your breaker isnt part way flipped .... dryer will run on 110v but wont heat unless it gets 220v ,,,, break may look to be on but not ,,, turn off breaker, wait 30 sec and flip back on hard / larryyb
Dec 05, 2008 | Dryers
Bryant /murray Bj2200 Main Circuit Breaker 200amp Logo
183 people viewed this question
Top Bryant Electrical Supplies Experts
Steve
john h
Gene Haynes
Are you a Bryant Electrical Supply Expert? Answer questions, earn points and help others
