Question about Dell Inspiron 1525 Notebook
My hardrive wont boot my computer. Istart up repair wont fix it. I tred reinstalling the os with a disc. it gets 80% through the expanding files then suts down and doesnt restart. A screen before that show that I have several files on the hard drive. If I replace the hardrive is there anyway i can recover files from the old one? Pictures etc..?
    Master:
    Sergeant:
  • 381 Answers
Ok.
it could be a dodgy hard drive or the laptop memory, change either and then try the reinstall
Posted on Oct 15, 2010
When pressing F8 on a dell inspiron 1525 I can't get into setup for the advance boot options menu. I am trying to overcome a "NTLDR is missing" issue
HI,
If you're trying to boot from the DVD/CD(OS disc) try tapping on F12 to go to the boot menu and then choose your DVD/CD drive to boot from the OS Disc. From there, you can use the OS Disc to repair your computer. Here's the step by step instruction once you've booted from the OS disc:
1. Insert the Windows bootable CD into the computer. 2. When prompted to press any key to boot from the CD, press any key. 3. Once in the Windows setup menu press the "R" key to repair Windows. 4. Log into your Windows installation by pressing the "1" key and pressing enter. 5. You will then be prompted for your administrator password, enter that password. 6, Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
copy e:\i386\ntldr c:\ copy e:\i386\ntdetect.com c:\ 7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
If this does not resolve the problem, you might need to reinstall windows.
Hope this helps!
Sep 11, 2011 | Dell Inspiron 1525 Notebook
Can't boot OS because of file missing
You will need to reinstall the file from an OS installation disc. You may have to reinstall the entire OS. If you need to, you should be able to keep any documents and other data you have on the computer, so long as you are reinstalling the same OS. If you want to upgrade to a different one, however, I would recommend that you use another device to boot your computer (a cd, external hard drive, or flash drive with the same OS you have on you computer), and copy all the desired data from you computer onto another storage device before upgrading. It is complicated to just replace the file manually, and it still requires a resource with the file on it (such as the installation disc), so your best would be to just reinstall the OS, or changing the OS.
Mar 02, 2010 | IBM ThinkPad R30 2656 Notebook
Bootmgr is missing, possible loose cables
No. The files on the hard drive the make it boot the OS are corrupt or missing. You need an OS disc to try a repair install. A repair install will leave all you files intact and only repair the OS files. A fresh install or recovery disc will cause you to loose all your info.
Dec 10, 2009 | Toshiba Satellite L300D-ST3501 Notebook
Computer wont boot
You will have to repair this file using bootable Windows Xp cd.
This problem will be solve.
Insert bootable Windows Xp cd and then press any key for boot.
When option appear for repair and write there Repair=R then you should press ' r ' and then you should follow the instructions.
Good Luck
Sep 24, 2009 | E-Machines eMachines T3830 PC Desktop
'''c:\program filesa\ECSspecialisTfilter\shooter.exe'''
well im guessing that its a virus just wanting to cause you to get upset. deal is virus protection wont always...sometimes flat out wont work if you already have a virus creepin behind the scences!
i had this isssue once and all i had to do was use my RECOVERY DISC to set it to factory setting. Mine was 2 dvd discs and i had a dvd burner of course. but thats only when i bought it. it says you should make one and i did and i simply start it like the day i bought it! your harddrive will be erased but ensures that the virus wont be in the hard drive anymore. my computer has 2 70gb hard drives and i simply moved my favorite files to the other hardrive which doesnt have my OS on it!
So if you dont have a recovery disc then your best option is this! your number on you pc either near the back, side or front on a sticker has a code that is yours to keep for life.. if its Windows Xp home or xp pro or xp OFFICE then that OS is yours and now you need to either find a windows installer disc that has your OS.
So if you happen to have a windows disc with ur OS you can use that to reinstall ur OS with its NUMBER and it will WIPE UR HARDDRIVE CLEAN BUT FIXS ALMOST ANY PROBLEM> LIKE THE DAY YOU BOUGHT IT. some just start up while windows runs . some computers you need to put the disc in ur cd or dvd rom and then start restart ur computer and hit the commands at the begining! its either F2, F10 or any F set it says! either chose boot from ur DVD or CD rom and hit ok or enter. or for some users go to BIOS SETUP ]F2[ for most all comps then find where boot squence is and set ur DVD or CD rom as the first to boot from! but make sure when ur done installing ur os change it to ur hardrive. o make sure that you know you can transfer your key files you want to keep to a external device!
So if you dont have a CD or DVD windows installer if you have a CD or DVD burner you can downlaod a WINDOWS XP HOME ISO bootable image and use a A PROGRAM THAT LETS YOU BURN BOOTABLE ISOs TO A CD[ IPREFER CD DUE TO XP HOME OR XP PRO OR XP OFFICE IS ONLY AROUND 600MBS dvds may not work.. torrents can help you find ISOs here is home if that what u have
http://thepiratebay.org/torrent/5063617/Windows_Xp_Home_Edition
. BITTORRENT as spelled google it and then download install it then go to
http://www.bittorrent.com/btusers/download/?
thepiratebay.org and search for your OS then download it and chose bittorrent as the program to open and it will download and it will be in MY documents then downloads. use the cd burning program to mount the file the use it as a windows installer disc! sorry if this doesnt help! i hope this works out! remember ur download your OS and that ur hardraive will be erased to ensure a clean hardrive
Sep 02, 2009 | Microsoft Windows XP Professional With...
Black screen, computer will not boot up and start
try to boot the computer using the recovery disc in it, sounds like some operating system files are gone or corrupted, booting from the disc should reinstall the os, or the missing files, but it will check for hardware problems anyways......hope this helps...shia
May 28, 2009 | Toshiba Satellite A135 Notebook
Missing file on boot up
If you have the boot up OS cd..put it in before boot up..and Choose repair the existing the OS. This is a kind of Boot sector file which might have corrupted due to some viral activity. Reinstalling or repairing the OS may fix this problem.
Mar 28, 2009 | Acer Aspire 3610 Notebook
C_437.nls file is corrupted and windows cannot start, i also do not have the windows installation disc.
boot in safe mode and run system restore if you cannot boot in safe mode you will have to get a disc and reinstall unless you know how to use the repair panel
Dec 17, 2008 | HP Computers & Internet
Hard Drive problem SP0802N
try cahnging or reinstalling the OS
if it wo nt start up u can try changing the IDE cables connected to the hardrive remove it and connect to another similar type of cable
Jul 27, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
ON INITIAL BOOT UP
Does it give you a command prompt,example c:/?If so type chkdsc and this will scan the hardrive for boot errors.Let me know.
Feb 20, 2008 | Acer Veriton 5100 PC Desktop
Dell Inspiron 1525 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
