Question about RCA G2G Gear 5" TFT Game Kit
My g2g main screen thats on my player is blank but i have sound and the side monitor works fine i have no manual its model no. dvd708, sept 2003 708032750 can this be fixed
  • 11,896 Answers
I did a little investigating, and learned that Hasco was the exclusive US distributor for G2G products in the US. However, it looks like Hasco is no longer distributing or selling the product line. According to their site, you can still get technical support information by calling this toll-free number: 1-866-607-8867
http://www.hasco-sales.com/pages/1/index.htm
Sounds like bad ic chip or possibly a capacitor if not just a setting.
Posted on Oct 15, 2010
My pioneer avic-n1 screen was working fine and then the next day the screen went blank but, everything still works
it sounds like the flexible cable that goes from the main board to the monitor might be bad.
Dec 16, 2010 | Pioneer AVIC-N1 Car DVD Player
Turns on (fans spinning, HD clicking), blank screen, no sounds
hi this issue is with ribbon cable it is connect between the mother board and your LCD screen. the cable required change. if you can change it OK other wise take it to nearest service center.
Jun 15, 2010 | Acer Aspire One Netbook 8.9" Notebook
Samsung 913v Self Test fine but screen goes blank in seconds
Its your VGA cable that runs from the monitor to the computer and u may also have a bad power chord
Jan 25, 2010 | Samsung SyncMaster 913V 19" LCD Monitor
Blank screen no picture
connection between the dvd output and screen has broke link somewere. pull it apart and check it out
Jun 05, 2009 | Philips Magnavox DVD/VCR Dual Player
Player works fine, speaker works fine but screen is blank...
This dvd player is having a problem with the video input /output circuits. This could be a minor problem with a loose connector or some over expanded solder joints. It could also be a problem with the video ic have a problem with its circuits. The connector problem and the possible cold solder joint problem can be repaired. The dvd player must be taken apart and the connection cleaned and repaired. If the problem is with the video solid state components, you will have to have it repaired by a service center. The video has a main ribbion connector that connects the laser lens to the main board video inputs. This ribbion cable usually will run under the laser transport mechanism. It is connected to the main board and laser transport by clamping connectors. You can look and see if this connector is loose or bent and has lost its function. Try cleaning the contacts points of the connectors and the connectors on the main board and laser transport.Also look for bad or cold solder joints in the areas of the connectors. Try to resolder these points.Use new solder to insure a good connection. Remember to only work on these dvd player with all power disconnected. Always wear anti-static wrist bands and gloves when working on the dvd player to prevent further damage. If the cleaning and repairing the of the possible cold solder joints do not repair the problem, you probably have a bad video chip and should replace the dvd player.I hope this information helps you with your problem.
Mar 21, 2009 | Mintek MDP-1815 Portable DVD Player
I have a ViewSonic Monitor, model number Vs11307. The screen is all blurred and the screen isn't adjusting properly. The screen is shifted to the right and I have a blank rectangle at the left side. I...
I had the same problem same model. The image was off center to the right and it couldn't be fixed by the auto-image adjust or the manual adjust.
My solution was really simple, I moved a video player (RealPlayer) onto the monitor and maximized the screen, then pressed auto-adjust once. It worked.
Jul 14, 2008 | ViewSonic Computers & Internet
I have a G2G DVD-708 player and the video on the primary screen attached to the player unit is not showing a picture. The picture comes on fine on the second, remote screen. The volume control and remote...
The problem with that unit is an easy fix. Simply take apart the upper half of the unit (the screen). Its two screws on front, four on the back. Carefully seperate the unit and note that the wire set that runs across the bottom of the screen has come unplugged. Reconnect the wire to the circuit board and reassemble. This is common due to the rotating screen. Email me if this helps at xtremediesel_1980@yahoo.com
Jun 27, 2008 | Televison & Video
RCA G2G Gear 5" TFT Game Kit Logo
88 people viewed this question
Top RCA Video Game Consoles & Games Experts
James Wishart
Are you a RCA Video Game Console and Game Expert? Answer questions, earn points and help others
