Question about Kirby Ultimate G Bagged Upright Vacuum
Utlimate g vacuum appholstery attachment
How do I get the vacuum to blow instead of ****??......I have the appholstery gun all set up and attached to the hose attachment which is attached to the vacuum but when I turn the vacuum on it only **** and does not blow the soap out....I have done this before correctly so I know i have all the parts but my manual disappeared in our last move. Please help me???
  • 357 Answers
Hi!
You need to take the power nozzle off and attach the thing that looks like a little plastic cup with two hooks on it. This is the intake guard. Attach it to the front. Now remove the cloth bag and put the hose on the hole where the bag was. You'll have to line the arrow on the hose up with the notch on the Kirby and push the hose arm toward the Kirby until it pops on. If you need to, lube up the edges of the hole with a wee bit of vaseline or hand lotion. This makes the hose engage easier.
Since you lost your manual, you may want another. They are available in DVD, VHS or book format. Check it out!
http://stores.ebay.com/CLICK-HERE-FOR-GREAT-DEALS_KIRBY-OWNERS-MANUALS_W0QQcolZ4QQdirZ1QQfsubZ7656839QQftidZ2QQtZkm
Hope this helps...
Marci
Posted on Jun 22, 2008
My hoover upright started blowing instead of vacuuming; it blows out of the attachment connection also when I try to use that.
Is this a bagless vacuum? Some Hoovers work in the opposite from conventional designs; the dirt is blown into dirt cup instead of sucked into a paper bag. If you have this type of vacuum, check the HEPA filter (and any prefilter, if applicable) and gently clean it so as not to damage the filter media.
If this does not help, please resubmit your request with a model number.
Good luck from Detroit, MI.
Jul 19, 2011 | Hoover Vacuums
How do i hook up the upholstery cleaner attachment up and use it?
First the bag assembly and head (or hose) must be removed. The hose fits onto the motor outlet in place of the bag. You will see a small arrow on the motor end of the hose. Line the arrow up with the "bump" on the metal fan housing and turn it clockwise to snap it in place. Be sure it is fully in place, or the motor will not run. Your attachment box contains an air intake guard which goes on the front in place of the head. Remember - the motor also will not run with the fan exposed. Turn the motor on and blow any dust out of the hose before putting the spray gun on the end of the hose. To make foam, the small foam screen must be attached to the spray gun outlet.
Feb 08, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Vacuum only turns on in reclined position/pull out hose broken
Per the Dyson Web Site I found the solution. Although I cleared all the filters/possible clogs the vacuum had over heated disabling the pull out attachment and power button except when in the reclined position. After clearing the filter and waiting an hour for it to cool it was back to working like normal.
Jul 10, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Bissell proheat blowing out air instead of sucking in air
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
vm,v
Feb 16, 2009 | Bissell 1699 ProHeat Clear View Upright...
How do I attach upholstery parts?
Remove the main head and put on the air guard.
Take of the bag assembly and attach the hose.
Mix up the solution in the "Suds o gun".
Attach this to the end of the hose.
When you switch on, foam will dispense from the gun.
Gently sponge this into the furniture.
Please leave feedback
Feb 14, 2009 | Kirby G4 Bagged Upright Vacuum
How to attach Kirby Heritage Suds-o-gun?
To use the suds-o-gun you need to convert you Kirby to blower mode. First remove the carpet head.
If you have all of the standard kirby attachments there should be a plastic cover to go over the front of the kirby where the carpet head attaches. Its round with square holes in one end. If you don't have this no biggie. Just leave the carpet head on the machine and rotate the belt to the off position so the brush rool bush on rotate. Remove the bag for the machine attach the hose where the bag was use the same end that attaches to the front on the machine. There are notches on the inside of the hose connector the fit over the tabs on the bag port. Fill the suds gun tank with shampoo and water. Attach the suds gun to the kirby hose. The suds gun nozzle is funnel shaped with wire mesh on the end. This helps to make the suds finer. Also the suds gun should have a knob to set how much suds come out when you pull the trigger. Turn on you kirby and suds away.
I hope this helps.
Feb 05, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Attachments hose won't **** but blows out
the polarity on the motor mite change with use or low suctoin
Dec 20, 2008 | Bissell 3576 CleanView II Bagless Upright...
How do I use the Kirby G6 shampoo attachment on upholstery?
Hi!
You need to take the power nozzle off and attach the thing that looks like a little plastic cup with two hooks on it. This is the intake guard. Attach it to the front. Now remove the cloth bag and put the hose on the hole where the bag was. You'll have to line the arrow on the hose up with the notch on the Kirby and push the hose arm toward the Kirby until it pops on. If you need to, lube up the edges of the hole with a wee bit of vaseline or hand lotion. This makes the hose engage easier. This makes the vacuum blow out to power the suds gun, which should be a part of your attachment set. I like to use half water and half Kirby shampoo in the jar. Place the nozzle on the sprayer for foam. Since you lost your manual, you may need belt change instructions as well. Here is a link to my online guide that will show you how....
http://reviews.ebay.com/CHANGING-THE-BEL...
Hope this helps...
Marci
Nov 25, 2008 | Kirby Vacuums
Kirby Ultimate G Bagged Upright Vacuum Logo
55 people viewed this question
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Roger Potts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
