Question about Ovens
Manual for microwave oven matsui m350tcc - Ovens
HOW DO I KNOW IF MATSUI OVEN IS SELF CLEANING?
If it doesn't come with a little maid type female with a scrubbing brush and rubber gloves, you have to clean it....
Jan 11, 2015 | Ovens
I just got an old microwave and don't now how to use it. Please is there a way to find a user manual? National Dimension3 Microwave/Convection oven
Try the Panasonic website below. National became Panasonic a number of years ago. I just went there and did a search for demension 3 under microwaves and it definitely has a few results for instruction manuals. You will need your model number (most likely on the back of the oven)
http://www.panasonic.com.au/Support/Customer+support/Downloads+and+documentation
Good luck :)
May 04, 2011 | Ovens
Can we use non stick pan in a microwave?
Non-stick pan I think may be surely made of metal. Its always
advised not to use metal pans, dishes, spoons etc inside the
microwave oven. Metals are mainly avoided due to the effect
of the microwaves on the metals.
These ovens uses the microwave radiations generated from a
magnetron. The microwave radiations are reflected off by the
metal surfaces. So if you use metal pans inside the oven, they
act as a microwave antenna that reflects back the radiations to
the magnetron and can cause damage to your oven. Another problem
with the metals inside the oven are due to arcing effect.
The atoms in the metal are ionized and the air gap near them lead
to a lightning like discharge of energy causing sparks. This can
easily cause a fire inside the oven since the food materials may be
easily ignitable under that temperature.
Alternatively you could check the manuals of your oven to confirm
the type of dishes that can be used to cook inside. If no
user manuals are available check manufacturer website.
Considering the safety, its a "No" to use metal pans inside the oven.
Dec 26, 2010 | Ovens
PRODUCT DETAILS For MSP60SS
Matsui MSP60 Stainless steel Built-In Oven and Gas Hob Package. Matsui MSP60 with Hob: 4 Burner Gas Hob, Fan oven, Minute Minderand B Energy rated top oven. Matsui MSP60 Stainless steel Built-In Oven and Gas Hob.
Product Features
•Dimensions (cm): (H)59.0 x (W)59.5 x (D)57.0
•Ovens: Fan oven
•Timer: Minute Minder
•Hob: 4 Burner Gas Hob
•Colour: Stainless steel
•Energy rated top oven: B
Hope this helps. Your generous rating will be much appreciated.
Oct 20, 2010 | Ovens
I need a manual for matsui oven model msp60ss
http://www.partmaster.co.uk/cgi-bin/downloads.pl?brand=Instruction+Manuals&criteria=MSP60SS
Aug 14, 2010 | Ovens
I am looking for a Manual for a Litton Microwave Oven Model 560
Try this site for your manuals.
www.laundrymanualsonline.com
Hope this helps.
May 19, 2010 | Ovens
MY KITCHEN SUPERBA MICROWAVE/CONVECTION OVEN BEEPING IS ANNOYING
Sorry, I have the same oven and the same complaint. The manual doesn't indicate anything. BTW- the service manual is inside the oven frame, between oven "lining" and the outside sheet metal.
Jan 03, 2010 | KitchenAid 27 in. Built-in...
Microwave Oven Manual
Why won't you help for free
Aug 08, 2008 | Ovens
Ovens Logo
241 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
