Question about Minka F603-WH Ceiling Fan
Confirmed that power is going to my MinkaAire fan. However, my remote control with new batteries will not turn on the fan or the light anymore. I do not have the owners manual and do not know the model. The fan is white, has five sharply angled blades and has a dome shaped light fixture without pull chains. Please resolve. Thank you.
  • rjfp60 Oct 15, 2010
    There is no receiver inside the fan mounting bracket next to the ceiling, only wires from the ceiling connected to wires from the fan. Again, I do not know the model so am wondering about the "F603-WH" designation and if it applies to my particular fan. The receiver is evidently inside the motor housing. How do I access it and how do I test it?
  • rjfp60 Oct 16, 2010
    Third comment without response from you: The receiver is not located at the ceiling...only electrical wires from the ceiling connected to the fan. I assume the receiver is in the motor housing. How do I get to it, how do I test it, how do I replace it, where can I get the part? Thank You.
  • 2,382 Answers
Hi, you have a problem with either the transmitter or the receiver. The transmitter is the remote and the receiver is located inside the fan mounting bracket next to the ceiling. Most times, it's always a receiver problem which needs to be replaced.. If you want to replace it, make sure to set the dip settings on the new receiver exactly as they are on the old one. Wire the new receiver exactly as the old one is wired if it was working before
Posted on Oct 15, 2010
  • Tunde Autos
    Tunde Autos Oct 15, 2010
  • Tunde Autos
    Tunde Autos Oct 17, 2010
    You need to change the receiver inside the fan. It is located in the top canopy of the fan. The receiver can be purchased at any electronic parts store around you.
Why did fan and lights stop working?
If you are controlling lights and fan only with the remote - no problem. Once you start flipping switches, the remote control loop is broken. You can restore remote control by setting the wall switches to off, turning off power at the circuit breaker (or fuse), and waiting for a few minutes during which you will be removing the battery from the remote and pushing all buttons, then reinstalling the battery. When time is up, restore power and try the remote. If no luck, check to be sure the wall switches are set to off and repeat the routine.
Jan 28, 2016 | MinkaAire F715-STW Sterling Walnut Napoli...
How do I program a MinkaAire R211 remote?
How do I program a MinkaAire R211 remote? - Fixya
www.fixya.com/support/t26033435-program_minkaaire_r211_remote
2 hours ago - I have set the wall mount, hand held R211 remote and the fan receiver to the same frequency. 1 & 2 ON and 3 & 4 OFF. But the remote still wont ...
[PDF]Universal Hand Held Remote System - Minka Group
minkagroup.com/sites/default/files/product.../RC212-English.pdf
NOTE: The RC212 Universal Hand Held Remote Control System is equipped with a learning frequency function which has 256 code combinations to prevent ...Missing: r211
Minka Aire Remote Control RCS212 and Wall ... - YouTube
? 0:56
https://www.youtube.com/watch?v=359xzOXynxI
Jun 14, 2013 - Uploaded by Del Mar Fans & Lighting
Del Mar Fans & Lighting's Minka Aire specialist provides tips for using these innovative ceiling fan controls ...
Jan 01, 2016 | Dryers
WHERE IS THE FUSE BOX IN THE REMOTE FOR MINKAaIRE
Why are you yelling, typing in all caps is yelling. What articles, news papers, magazines, do you read that are all caps, none. Also, all caps is more difficult to read.
Nov 30, 2014 | MinkaAire F510-BS 3 Blade 26" Flush Mount...
My ceiling fan/light can be controlled only by the remote control. our remote is not responding with the fan anymore. it has new batteries and has power, it's just not corresponding with the light/fan. it...
Turn the power off to the fan / light by flipping the breaker or pulling the fuse and keep off for 10 seconds then turn back on, it should reset the contol receiver in the fan.
Oct 27, 2009 | Hampton Bay 24002 Ceiling Fan
Remote will turn on the light, but not the fan.
I have a white Westinghouse tv and can not programs the code in a Rca universal remote control
could you give me the code for the tv. Thank you
Nardin
Jul 02, 2009 | Universal Remote Control Hampton Bay...
Fan and remote not working
make sure the main switch is on ,also the chain switch on ,before using control remote!!
Dec 23, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
MinkaAire RC120
Fiddling around with the wall switch and remote control settings caused the receiver to suffer a mental breakdown. You may have to purchase a replacement receiver and reprogram from scratch. In practice, you generally have to decide whether to use the wall switch or the remote control, but not both.
Nov 22, 2017 | Minka RC120 Remote Control
If you haven't already done so, replace the remote's battery with a brand new one . Make sure the replacement battery is NEW AND UNUSED, AND WAS PURCHASED RECENTLY, SO IT IS FRESH. Make sure it is installed properly, making good electrical contact, and the proper polarity is observed. Was the remote dropped, sat on or stepped on? Was a liquid spilled on it? Did your pet chew on it? Are any of the buttons loose or stuck? If the remote seems ok, try removing 120 volt power from the fan by turning off the circuit breaker or fuse an your homes main electrical service box. Wait 30 seconds, then turn 120 volt power for the fan back on. This may reset the speed control in the fan unit. If it does not cure the problem, consult a professional electrician, or replace the fan, whichever is more cost-effective.
wait 30 seconds and turn 120
Jul 13, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Minka F603-WH Ceiling Fan Logo
122 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
