I DONT HAVE A DISPLAY ADAPTER - Computers & Internet
  • 32 Answers
If you have onboard video hookup you do. lol look up the mainboard here http://www.motherboard.cz and get your system drivers. if you have a video card lying around, plug it in and see that your monitor actually works. A lot of boards also have a jumper setting for onboard or say..agp video. check your manual for the board which you can also find at the same site mentioned earlier.
Posted on Oct 15, 2010
Dont work display and no sound boss me-5
You have described a power problem. the unit is not coming on.Are you using the proper PSA adapter on this thing? If using a generic one, make sure the polarity is correct. Most of these things are wired backwards as compared to other types of devices. Does it work with batteries? This is where to start on a diagnosis. If it does, the wires from the batteries go through the socket where the adapter plugs in. Try spraying contact cleaner into the socket in case it is dirty or stuck in an open position. One more thing, IF a generic adapter was plugged into it that was opposite polarity, it may have burnt a diode on the circuit board. (a microscopic one at that)
Mar 31, 2013 | Music
Acer aspire graphicscard prob
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
you might uninstall the display adapter restart your computer then reinstall the display adapter and its
If you computer came with a motherboard disk the drivers could be on it
If you dont have the motherboard disk you might need to download them
if you need more help with this post a reply with more information on the problem
Will Bobby find his way out?
good one
hope it helps
Jun 25, 2012 | Acer Aspire 7745G-9823 Notebook
I need a driver for my LG Flatron W1642S LCD Monitor
Most monitors are plug and play meaning that they dont need a driver. If you are looking for your display driver you will need to get it from the display adapter
Jun 05, 2011 | Computers & Internet
I dont a cd drive is it possible to down load a the information online so that my bluetooth micro adapter micro 2.1 usb can work.............
http://www.iogear.com/support/dm/driver/GBU211#display
or
http://drivers.softpedia.com/progDownload/IOGear-USB-Adapter-with-Bluetooth-wireless-technology-GBU211-Driver-10-Download-21387.html
here is the manual
http://www.iogear.com/support/manual/GBU211-GBU311%20Manual.pdf
Aug 21, 2010 | IOGear (GBU211) Bluetooth Wireless Adapter
My dv6000 dont start . i have black screen with one long beeb and two short beebs
That code means that the display adapter is bad. Replace the display card.
Mar 23, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
Ineed to replace my display card for to get a
Try this. Make sure you are at the desk top screen. Right click your mouse click on properties. When the display properties comes up select the settings tab. Now you will see the display properties and you can adjust tho get a higher resolution screen. Hope this helps.
JimmyC
Sep 27, 2009 | Sony VAIO Digital Studio PCV-RX540 PC...
Samsung samtron 55v display problem
assuming that u r a professional..
i guess there is no problem with ur monitor, it sounds like itz due to graphic adapter..either the adapter on ur system main/mother board/agp/pci/pcie is damaged or itz simply 'driver corruption'..
don't panic..check for driver update/download n reinstall graphic/display driver..
however, 1st make sure that the Screen Resolution (1024x768 or as applicable) and Color Quality (32 bit or as applicable) is correct..from Display Settings->Settings tab..
always better to contact system admin/vendor....
Dec 30, 2008 | SAMTRON 55V 15" CRT Monitor
Monitor driver
you can set a resolution of 1440*900..
option 1) open device manager,, update the drivers for standard vga card.. locate ur video drivers folder,,(do it manually even if u have it on cd)...
option 2) this one is bit risky.... open add new hardware wizard and add ur correct video adapter, no matter ur standard display adapter is already installed. after you finish, update ur original standard display adapter and this time, it will pick the correct drivers.. now you can remove your dumb display adapter and restar pc .
risk is- be very careful, u dont want to remove your physical adapter by mistake, resulting no video after a restart.
Oct 17, 2007 | Microsoft ChiMei CMV938D 19" Widescreen...
I have two lg monitors on spreat dispaly adapters
You don't need a driver for the monitors, the native plug and play driver in XP usually works as well as any manufacturer supplied driver. What's happened is XP doesn't recognize the onboard display adapter. If this is a name brand system (you didn't mention what type it is) download the XP display driver from the manufacturer's web site. If it's a custom built system, there should be a motherboard CD that came with the system that has the display driver on it. When all else fails, download System Information for Windows from http://www.gtopala.com/ It will tell you what type of onboard display adapter the system has.
Oct 04, 2007 | LG L1717S-BN 17" LCD Monitor
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
