Question about Canon BJC 2100 InkJet Printer
New ink cartridge, parents gave printer to me, ink does not print on paper but it goes through all the steps. Hasn't been used for awhile.
  • Ikhlaq Hussain Oct 15, 2010
    how long is awhile?....most likely the ink has dried
    Scholar:
  • 192 Answers
Couple things.... Could be dry.... Take a cottonball or q-tip and dip in alcohol and wipe it on the cartridge and also the intake well on the printer, that will loosen any dry ink and let the ink flow. If this does not work, the cartidge is very possibly dried up. they will dry in less than a month if not sealed in a zip lock baggie.. Please let me know if this does not fix it, we can dig deeper into the problem. Pleasure to assist today.... Guy :)
Posted on Oct 16, 2010
States "Right Cartridge incorrect"
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 30, 2010 | Dell 922 All-In-One InkJet Printer
Lexmark X1270 All In One Printer not printing.
If the printer has not been used for a while the catridges my have dried ink on them. Sometimes you can get them to work if you touch an alcohol wipe to the cartridge where the ink comes out. note: only touch the wipe to the cartridge for a second or two each time. I would try this for about 3 or 4 times to see if the ink will come out. Put the cartridge back in after each try to see if it works. The other option is to replace the cartridges.
Mar 09, 2010 | Lexmark X1270 All-In-One InkJet Printer
Won`t recognize new ink cartridges. Still insists black is empty, other colors low, although all have been replaced. Any way to reset or override? Thanks
Hi there
There are only a few steps you need to do to reset a Brother printer ink cartridge and once you do it, you will be up and printing in no time. There are actually two things that a Brother printer uses to detect ink and you can manipulate one or the other.
Instructions
Things You'll Need: · Black electrical tape, masking tape or duct tape
1. Step 1
Identify the printer If your printer uses memory, you can tell which printer you have by looking at where the cartridge goes in, if you see two "eyes" and a part of the cartridge goes in between them, follow Step 3. Otherwise, continue with Step 2.
2. Step 2
Clear the memory by taking the cartridge out and unplugging the unit for 30 seconds. Then, plug it back in and put back in the cartridge. You may need to do this five times, as the memory holds the last five cartridges.
3. Step 3
If the Brother printer has "eyes" where the cartridge goes, you will need to block in between them with a piece of tape so that it thinks the cartridge is always full. Simply put a piece of tape on the piece of the cartridge that goes in between the eyes to block the path of the infrared beam
Mar 03, 2010 | Brother MFC-230c Printer
My Lexmark 8300 is making a rumbling noise and it seems like the print cartridges are getting stuck on the left side. The black ink cartridge is low but it is not printing light so I haven't switched it...
Hello there
Mar 03, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
Tried 2 new genuine Canon 3e Cartridge. Won't print the black, just the other colors. Jammed print head? I LOVE this printer!
Hello there
Feb 20, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Will not print. e 2 flashes on screen
ERROR CODE CANNON MP150/MP160
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 - Ink cartridge is not installed
E16 - Ink remaining is unknown
E19 - Failed to scan head alignment sheet
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
You can gave it a good clean out try.
Feb 13, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Nothing prints out on paper.
Did you remove the little sticky tabs from each new cartridge? They allow air in, and ink out.
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Light blinking
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Jun 02, 2008 | Epson FX 1170 Matrix Printer
Black cartridge not printing
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Jan 15, 2008 | Lexmark X75 All-In-One InkJet Printer
Balck ink not working
Mar 16, 2007 | Canon S 330 InkJet Printer
Canon BJC 2100 InkJet Printer Logo
old marine
old marine
