Question about Nokia 3230
Joystick., T_T i would just like to ask., is it possible to remove the rest of the joystick on the top board and replaced it with a new one.? the rest of the joystick meaning the WHOLE chip.,it includes those that must be pressed to move the cursor., tnx.!
    President:
  • 2,712 Answers
It should be..but it all depends on whether or not the service shop has the required parts, and if they actually do the replacements :)
You will have to enquire around locally to find out more details.
Posted on Jun 02, 2008
Everything works fine but won't manually turn off, but will time itself off.
There are two possible likely problems here: the joystick "key" or contact on the printed circuit board is bad/worn or the joystick is defective. The "key" is the rubber button pad that you press to turn the PWC on and off. This keypad is carbon embedded rubber that makes contact on the printed circuit board underneath. When these age or get moisture, the contact on the board oxidizes and the rubber becomes de-carbonized resulting in a poor contact when the key is depressed. Cleaning the contact with rubbing alcohol and a light scraping tool works sometimes. Replacing the keypad is a must.
If these don't work then you have a bad circuit board in the joystick. Either replace the joystick or the PCB within it. PCB replacement must be done by a properly trained electronic tech or Curtiss\PG Drives who makes the joystick.
Mar 16, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
Tip
How to Replace Analog Joystick on PSP-2001
If your PSP's joystick won't go in a certain direction -- or characters walk by themselves, this part needs to be replaced. It is sold at the website all the way at the bottom for $16.95 and they can do this repair job for $18 more! However, it's not very difficult. Here are the steps:
Step 1. Open PSP. There are 2 screws on the top of the PSP.
Step 2. There are 4 screws behind the PSP and one on the bottom, as circled in the picture.
Step 3. Remove the faceplate and locate the PSP 2001 Analog Assembly. It is held into the console by 1 black screw, as circled in the picture.
Step 4. Remove the black screw and pry the joystick out of the PSP as shown below.
Step 5. It is important that you remove this clear silicon piece from the old joystick and install it into the new one. Its purpose is to communicate the movement of the joystick from the assembly to the motherboard. It sits between the assembly and the motherboard.
Step 6. After you transfer the piece, pry the motherboard slightly up as you slide the new assembly back in place as pictured.
Step 7. You will need to pry this piece up to slide the assembly into place so that it is seated. Replace the black screw and close it back up.
RELATED ITEMS
PSP-2001 Analog Joystick Assembly
Precision Screwdriver Set
to open PSP, PS2
PSP PSP-2001 Motherboard Silicon/Rubber
on Apr 14, 2010 | Sony PlayStation Portable (PSP) Slim...
Hi! I'm just going to ask regarding the joystick of my n73. I'm having problem with it, since I can't use it already. It seems like it is already pushed, like if I'm using it, I can't...
Hello there,
The problem with the phone is that the joystick is weak and is not sitting anymore on the phones board, it need to be replaced. That is what you have to do, they sell the joystick in stores or you can get a phone that no longer works and use the joystick.
You will have to take out the joystick by disassembling the phone, and reaching for it,then replace it with new one. That works all the time,if not the phone will be out of controll as the navigation button is what shows its functions.
Hope this helps
Goodluck
Elect_Comp
Aug 10, 2011 | Nokia N73 Cellular Phone
My Nokia 3230 joystick is not working properly. It selects the first option even if i try to move it up, down, right or left. Please tell me the solution. Thanks in advance.
your problem may cause a damage joystick or the top board of your may be damage or loosing connection try to dismantel it properly then remove and put back again all the connection of the top board.
Jul 30, 2011 | Nokia 3230
Pilot Joystick is fried Type # D49637/8A. Can I get replacement? What is the cost? Guy
The Pride Jazzy 1115 originally came with the Pilot controller (Pride part # CTLDC 1030) and it has served you well. The manufacturer,Penny and Giles, is no longer manufacturing the Pilot. Fortunately, Pride is providing a new VSI controller 4 key 50 (70) Amp for the Jazzy 1115 (Pridepart number CTLDC1270 ) (manufacturer P & G part #D50148) for a retail cost of $1607. The new VSI controller will also need a new joystick mounting bracket assembly part #FRMASMB 4767 retail $30.
It is possible to have your Pilot controller rebuilt. There are many rebuild facilities that will sell you a reconditioned joystick (VSI or Pilot) for about $500 that will work on your unit. You can opt to send in yours for repair or reconditioning or purchase a reconditioned unit. Try MonsterScooterParts.com, TheAftermarketGroup.com, Wheelchair Wizard in Citrus Heights, CA.
The Pilot controller was a very robust unit but very expensive for Penny and Giles to manufacture. The new replacement VSI controller actually performs better and is more streamlined and smaller. The VSI pushbutton overlay (4 key) is very easy to use, The pushbuttons control on/off/speed increase/decrease. The replacement is easy to do as long as you remember to order the new mounting bracket assembly with the VSI because the old Pilot bracket will not work. All it takes to install is 2 screws to mount the control on the bracket, 2 plugs to connect, and 2 cable ties to secure the wiring. You may want to spray electrical contact cleaner into the plug receptacles on the electronics tray to clean them before plugging in the new parts. Hope this helps.
Nov 14, 2010 | Electric Jazzy 1115 Power Wheelchair
On/off just stopped working on joystick.
dhastings The bottom of the on/off switch has a metalic coating that makes contact on the circuit board to turn the chair on/off. If that gets worn then you have to replace the faceplate. You can contact your provider and ask if they can order a faceplate from Pride for your joystick. Now if you are mechanically able you can remove the top cover of the joystick and glue a small piece of foil to the bottom of the on/off switch and it should work until you can get a new faceplate Hope this helps
Oct 17, 2010 | Pride Jazzy Select 6 Indoor Power...
Need to replace keyboard in HP Pavilion dv6626us Entertainment Notebook PC. thanks
Turn the computer off and close the computer lid.
Remove the battery and the AC power supply.
1st we need to remove the switch cover or keyboard bezel. This is plastic strip that runs above the keyboard.
Turn the computer upside down with the front panel towards you.
Remove the three Phillips screws that secure the switch cover to the computer.
Turn the computer display-side up with the front toward you.
Open the computer as far as possible.
Lift the rear edge of the switch cover and swing it forward until it rests on the keyboard.
Release the zero insertion force (ZIF) connector to which the LED board cable is connected and disconnect the cable from the LED board.
Remove the switch cover.
Now remove the panel directly above the battery compartment and remove the 2 keyboard screws there and another 2 screw in the battery compartment (they should me marked with icons of keyboards)
Turn the computer display-side up with the front panel towards you.
Lift the rear edge of the keyboard until it rests at an angle.
Slide the keyboard back to disengage the tabs on the front edge of the keyboard from the top cover.
Swing the keyboard forward until it rests on the palm rest.
Release the ZIF connector to which the keyboard cable is connected and disconnect the keyboard cable from the system board.
Remove the keyboard.
Just reverse the procedures to replace everything.
Good luck.
Sep 17, 2009 | HP Computers & Internet
I recently purchased logitec extreme 3d pro joystick and a user manual did not come with it. How do I get one?
Did you purchase it open-box or second-hand? If so, you shouldn't be surprised at the lack of a manual. If you bought it new, it may not have come with one.
I personally have one of these joysticks, but I bought it so long ago that I can't remember if it came with a manual or not.
Either way, there really isn't much need for a manual for this joystick. It doesn't have any very advanced features that would require a manual. It's very simple to use:
  1. Plug it in to an open USB port on your computer.
  2. It should be automatically detected by your operating system. If not, you may have a defective joystick or a defective USB port. Try the joystick in another USB port. If the problem persists, check Logitech's website.
  3. In Windows, click Start->Control Panel->Game Controllers. You should see the joystick listed. Select it and click Properties.
  4. It should open a new window to the "Test" tab, where you can make sure all the buttons work. I suggest you click on the "Settings" tab at the top left.
  5. Click "Calibrate..." and follow the prompts. It'll ask you to keep the joystick centered and press a button on the joystick (use one of the side buttons such as 11 or 12 so that you don't inadvertently move the joystick from center).
  6. Then it'll ask you to move the joystick in complete circles. Do this several times and advance to the next step.
  7. It'll ask you to move the throttle slider up and down. Do this several times and advance to the next step.
  8. It'll ask you to set the "Z-rotation," which is the left/right twist of the handle. Do this several times.
  9. It'll ask you to center it and press a button. See step 5 above.
Now the joystick should be calibrated and ready for use. If you have multiple game controllers, you may want to click the "Advanced" tab back in the Game Controllers window and make sure the Logitech Extreme 3D Pro is selected as the preferred device.
Now start whatever game you want to use it with. You'll probably have to configure what you want the buttons on your joystick to do within the game; follow the instructions that came with the game.
Pretty simple, and like I said, there are no advanced macro functions or anything like that for this joystick.
Apr 10, 2009 | Logitech Extreme 3D Pro Joystick
3230 joystick
Well you'll have to take the whole thing apart so that you can gain access to remove them both and the next thing is that the availability of new chipset.I don't think it is easy to find one for your model.
Goodluck..
Jun 02, 2008 | Nokia 3230
3230 joystick
piles sir i am request my mobile 3230 joystick up down no waking piles help emijate
Nokia 3230 Logo
44 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
