Question about Denon AVR-1907 Receiver
Can't get sound when in cd/dvd function
I just recently started having this problem. There is no sound when in cd/dvd mode. The radio has sound. I checked my toshiba hd dvd player and the dvd is fine with the tv.
  • mixjul Jun 02, 2008
    forgot, i have a denon avr-1907
  • 1,512 Answers
Hi mixjul
I would suggest you try a hard reset of the receiver by unplugging it from the wall to power it down completely for 30mins, then fire it up again. If it has just been a bit scrambled, then this should cure it.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 03, 2008
Unit has power and lights up. None of the buttons work and cd wont eject. The CD eject button turns the unit off but won't eject the CD. Cannot change the functions. Have reset the unit and checked th
Remove the face plate and clean the contacts on both the head and the radio. It sounds like a bad connection, The base and head use serial data to talk to each other(control).If one of these connections are bad the unit will not work properly.
Oct 06, 2014 | Sony MEX-BT2900 Bluetooth Car Stereo with...
Delayed Sound from Center Speaker
Go to this website, make an account, go to support, help center. Thenfollow the instructions and you might get your answer.
Hope this helps. :)
Jan 21, 2008 | NAD T762 Receiver
DVD changer is jammed on my Panasonic Sa-pt770 Receiver
if you have 2 tiny screw drivers, if not, the tips of a butter knife might be skinny enough, you can try to insert them a wee bit into both sides of the tray and pry outward, carefully of course, and unjam the tray
Mar 09, 2013 | Panasonic Sa-pt770 Receiver Only For...
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
Sony TA-AV521 I have had this stereo system with surround sound for years. Recently I am finding that the surround sound mode is not working right. There is a lot of fading in and out whether it is on...
CD's and FM radio are created in 2 stereo channels. To listen to them in Surround, artificial processing has to take place in your receiver, so artifacts and fading are quite common when you do this. When you turn the surround off, your stereo is processing the information properly and it will sound right.
Mar 02, 2011 | Audio Players & Recorders
How do we listen to aCD in 5 channel suround sound without having the TV on we can only get straight sound. We have a Yamaha RX-V365 av receiver.
Do you listen to audio CDs via a CD player or DVD player? Pure audio CD is only 2-channel, so either TV or the DVD player is doing the mix to 5 channels. But you can choose the sound mode via remote - there should be modes like 5ch/7ch stereo, where the same signal is going to all speakers (I you this mode for listening to radio sometimes).
Oct 27, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Little or no sound JVC RX6010V
i had the same problem but i went to adjust settings and it says right speaker left speaker and you have to set them on ten
Jan 02, 2008 | JVC RX-6010V Receiver
Programing Mode Backward
happy to help, just ask me here:)
regards
Graeme
Dec 04, 2007 | Onkyo TX-SR601 Receiver
Unable to hear dvd audio when dvd playing on Sony STR-DE575
Hi The first thing to do is disconnect the red and white audio cables from the back of the receiver, and plug them directly into the tv. If you then have sound from the DVD, then you have eliminated the possability of no audio coming out of the DVD player. If the DVD player checks out fine, then I would try plugging the jacks into another aux input on the receiver, and select that and see what happens. Also, if there is a "tape monitor" button on your Sony, make sure it is turned off. I'll assume the receiver has sound from other functions, so it would be rare for one of the inputs to just stop working, (but certainly not impossible), I'm not familiar with that model, and normally I would say it could just be a dirty selector switch, but since you mentioned having a remote, then switching between inputs is done by the microprocessor, not a physical switch, so if you cannnot get sound through using another input, then it could be expensive to repair. Hope this helps, and good luck!
Apr 30, 2007 | Sony STR-DE575 Receiver
Denon AVR-1907 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
