I want to print a paper size 8.50" x 5.50" in this printer, but it does not show this size. I just created in Server Properties.
    Genius:
  • 1,018 Answers
What kind of printer are you using? How are you communicating to the printer to change to this page size? What is the printer language you are trying to use (PCL5e, PCL XL or Postscript)?
Posted on Oct 15, 2010
Custem size paper are not creat
am using an Epson LX-300+II dot matrix printer in Windows XP. I am
trying to print checks that are tractor feed 8.0" x 3.66". I added the cusotm
paper size in the print server and it is saved correctly, however, when I try
to print, the print properties dialog does not show the paper size. In fact,
there are many paper sizes in the print manager that do not show up in the
list of available paper sizes.
Apr 13, 2010 | Epson LX-300+ II Matrix Printer
How can i add paper size of tally printing in lx-300
if you want change page setting in your printer ..... to get the all settings of your printer press font button and switch on the printer (before take setting make sure that you printer loaded with paper ) goes through the instruction printed in the paper to change the settings ........ change paper size.....
you can map your tally printer paper size in system .....go to printer and faxes ... file..>server properties ...>select create a new from ...> change the name as you wise and change the paper setting and click ok ........
while you give print change paper size to your created paper size and check
Dec 19, 2009 | Epson LX-300+ II Matrix Printer
Sir, I, have developed my application on windows 98 but now a days everywhere set the WindowsXp but my printer Epson LQ-2090 have not a Custom paper setting. Please tell me how I can solve this problem for...
have you created same paper size as per windows 98 custom paper size ..... if not create as same please create the same and select the printing area also in the server properties ...... in the printing preference change page size to your created page size in layout tab advance option and in paper/quality tab advance option ... and check it ....
Nov 20, 2009 | Epson LQ-2090 Matrix Printer
For printing us std fanfold size in msp 345
right click on the printer driver and select the properties ....> printing preferences ....> advance .....> change the page size to fan fold size ...> ok..>ok ...>ok
if you want to set your own paper size then open the printer and faxes ..>file ...>server properties ...> in forms tab ..>select create new form
Nov 18, 2009 | Computers & Internet
How i can copy the custom paper size for oki 591 to other computer
you can not copy the custom paper size to other computer ....you ca nconfigure same paper size in other computer..........
  1. open printers and faxes
  2. From the File menu select "Server Properties" (Print server properties)
  3. Forms tab
  4. Click "Create a New Form" and add information that you want
  5. Click OK
Oct 08, 2009 | OKI MICROLINE 591 Matrix Printer
Paper size settings
Thanks for your reply,
Here are the things you might want to try:
1. Go to Printers and Faxes in your Control Panel
2. Right click on the white area and select SERVER PROPERTIES
3. From the FORMS tab, check the box that says CREATE A NEW FORM
4. Enter a Form Name
5. Manually input the specific paper size you want.
6. Press OK
7. To verify if you are successful in creating a new form, right click on the icon of your LX and select Printing Preferences
8. Click on the ADVANCE Button
9. Check under PAPER SIZE
That's supposed to be all, however take note that if the newly created paper size is not showing up, its possible that the paper size is not supported.
Hope this will help
Mar 16, 2009 | Epson LX-300+ II Matrix Printer
LX-300 Printing Problem
go to the printer properties and set the correct paper size. printer and application paper size must match.
Nov 20, 2008 | Office Equipment & Supplies
Printer is not recognizing the new custom paper size
You also have to create a form the same size in "server properties".
Click on "printers and faxes"
Click on "file" top left of screen, choose "server properties"
Click on "create new form"
type in width and height of paper
(my HP printer will not recognize any paper less than 5' in height and less than 3" in width)
If your create a form less than 5" in height ' and/or less than 3" in width - chances are that's why your printer won't recognize new form. Height HAS to be at least 5" and width HAS to be at least 3"
type in name of new form
save form and close
It should now be in your printer paper options.
Nov 17, 2008 | Office Equipment & Supplies
I have a Stylus photo printer R1900
There are two different ways to create a custom page size within the Epson printer driver on Windows 2000 or XP. The method you need to use will vary depending on what type of driver is installed.
CREATING A CUSTOM PAPER SIZE IN SERVER PROPERTIES
This method will create a new page size accessible by all printer drivers installed in Windows.
1. Open the PRINTERS (2000) or PRINTERS and FAXES (XP) window.
2. Click on FILE, then select SERVER PROPERTIES.
3. On the FORMS tab, place a check beside CREATE A NEW FORM.
4. Input a new name for the paper size. Enter the desired height and width, following the existing format (#.##in).
5. Click SAVE or SAVE FORM to add the new form size to the list, then close SERVER PROPERTIES.
6. Right click on the printer name and left click PRINTING PREFERENCES.
7. Look for PAPER SIZE. (Depending on the driver in use, this will be found on the MAIN tab, the PAPER tab, or under the ADVANCED button). Select your custom paper size from the list.
8. Click APPLY to save this setting, or OK in Windows XP.
NOTE: If your new custom size is not available on the list of preset paper sizes, it indicates that the new size is either too large or too small for the driver in use.
CREATING A CUSTOM PAPER SIZE WITHIN THE EPSON DRIVER
This method will create a custom size within the Epson printer driver only.
1. Open the PRINTERS (2000) or PRINTERS AND FAXES (XP) window.
2. Right click your Epson printer name and left click PRINTING PREFERENCES.
3. On the MAIN or PAPER tab, select USER DEFINED from the PAPER SIZE drop down box.
4. Enter the new custom size and give it a name. Click SAVE to save the new size and OK to return to MAIN.
5. Click APPLY to save the changes (OK in Windows XP).
NOTE: this method is not available when using printer drivers resident within Windows itself. If your printer driver name ends in "ESC/P2" you will need to use the first method to add the new size in SERVER PROPERTIES.
Aug 05, 2008 | Epson Stylus Photo 2100 InkJet Printer
Printing on 4x8 cards
Oct 12, 2007 | Epson Stylus RX580 InkJet Photo Printer
59 people viewed this question
jasbo
jasbo
