Question about GE (PSS26MSRSS) Side by Side Refrigerator
The ice cubes are soft. the refrigerator is not staying cold on any temperature setting. What do I do?
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 17, 2010
Samsung RS25H5111 ice maker in the door. Cube ejector arm gets stuck when it tries to eject frozen cubes.
There is a heater on ice maker that thaws the cubes to make them slide out of the tray easier. Check the temperature of the freezer and see how cold it is set to. If you can make it a little bit warmer that might help.
Jul 02, 2016 | Samsung 24.5 cu. ft. Side by Side...
Ice Box wont stay running
Hello Jeff;
My name is Peter. I am a retired field service refrigeration technician.
Ice Box? You must not be from the Glen Burnie, Maryland USA area.
Ice boxes or ice maker have several controlling factors. Some are repairable. Here is how they work:
1.) Your ice maker will harvest ice cubes 8 to 10 times within 24 hours.
2.) You have a control module in the front of your ice maker. This is like a small control board. It has a motor and plastic gearing system. It also control the lever system to fill your ice bucket.
3.) The control module tells the solenoid valve in the lower back right hand side of your unit to open and fill the ice cube tray.
Then you have a temperature sensor that tells the control the ice cubes are frozen.
4.) You either have a flex ice cube mold that will activate or a heater under the mold tat will turn on for a set period of time to release the ice cubes from the mold.
Send me the model number of your unit and then we can trouble shoot together.
Feb 13, 2015 | Refrigerators
How do I Prevent ice dispenser from freezing up? Ice is in the ice bucket but will not disperse.
The ice stays in the cubemaker tray for a set time and then empties into the bucket. If the freezer was too warm the ice wasn't frozen enough when the cube maker emptied it and it all stuck together. Now the fridge is cold again empty the bucket, make sure there is no ice stuck in the dispenser and try again. If it is a Samsung fridge do the above and turn it off for 30 seconds and back on again. Sometimes the controller and display freezes and reads the wrong temperature.
Nov 18, 2014 | Refrigerators
The ice maker is making 1 tray of ice a day
There are 3 things needed to make proper ice.
Water, cold, time.
Check the cubes that are being made, they should be the same size crescent shaped. If they are not solid and some are hollow or broken then you are not getting enough water to the refrigerator. This is usually caused by the little valve on your house piping that connects to the refrigerator being plugged with sediment.
If the the cubes are all solid and the same size check the temperature of the freezer, it needs to be below 10 degrees F and works best below 5 degrees F. If it is warmer than that it will only produce ice on a very slow schedule. If you do not have a thermometer ice cream is a good indicator of temperature. If ice cream is hard the temperature is below 5 degrees F, if it is soft you are not cold enough to make ice cubes either.
If all this checks out alright you may need to have the ice maker replaced. the modular ice makers are available for sale at most all part retailers.
Apr 19, 2010 | Kenmore 74822 / 74824 Top Freezer...
It's not staying cold. ice cube are not frozen, ice cream melted, frost on inside freezer on back wall.
something is wrong with your condenser fan motor or your evaporator Or your defrost timer which controls what temperature you put in.try serviving it
Mar 05, 2010 | Refrigerators
Water temperature from the water dispenser of our new refrigerator is equal to the environment temp.it is not cold at all.is it normal?the dispenser produces ice cubes but not cold water
You may not have filled the water reservoir when you hooked up the fridge. Run about 2 gallons of water through the dispenser. Then wait about 12 hours before you draw more water. This way the dispenser will fill and have time to cool down. It should stay cold after this.
Aug 29, 2009 | Samsung Refrigerators
Ice cubes not freezing completely before dumping
check evaporator fan if working or u may have a leak , or check condsr fan motor :)
Aug 28, 2009 | Amana ARS2464B Side by Side Refrigerator
My freezer is not staying cold.
may you be having problem with compresser.and for more info contact http://tinyurl.com/m7ghqz
Jun 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My ice maker is not making ice as fast as it use to
The freezer compartment may not be as cold as previously. Check the condition of the door seal of the freezer compartment or try setting a colder temperature. The Ice Maker has a Thermostat that senses cube temperature and controls a heater switch which turns the ice tray heater on to free the cubes for dump. The problem could be that this thermostat, if failing, is delaying the cycle.
May 03, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
