Question about Hotpoint 24 in. HDA3400G Built-in Dishwasher
DISHWASHER NOISE I HAVE A HOTPOINT DISHWASHER MODEL HDA3420Z02BB SERIAL # TT813162Y. IT IS ABOUT 10 YEARS OLD AND JUST TONIGHT DEVELOPED A CLICKING/ GRINDING NOISE AT THE BOTTOM OF THE DISHWASHER. I REMOVED THE LOWER COVERS AND IT APPEARS TO BE COMONG FROM THE MOTOR AREA OR I GUESS THAT IS THE PUMP ATTACHED TO IT. JUST WONDERED IF THERE IS A PATTERN FAILURE WITH THIS MODEL AND IF SO IS IT FAIRLY EASY REPAIRED?
  • 2 more comments
  • robertojs Jul 16, 2008
    I have the same problem! It makes the sound immediately when you turn the knob.
  • dz4516 Jan 08, 2009
    Same problem makes a Loud Noise as soon as you turn on the dishwasher and doesn't stop until its done with its cycle.
  • CJUB Jan 14, 2009
    Great solution BUT... How do I go about removing something from the motor-pump assembly?
  • joshuaalan80 Mar 24, 2009
    The dishwasher makes a loud squeeky & grinding sound from the bottom front end.
  • 126 Answers
A noise could be created by something getting down into the motor-pump assembly piece of glass, piece of bone, wire tie anything really. If this is the case and you can remove it before it causes further damage problem solved. At ten years old the problem may be the motor and or pump one thing to consider before putting money into it is disheashers average 7-10 years these days. Good Luck.
Posted on Jan 10, 2009
How old is my Hotpoint dishwasher, model HDA3400G02WW Serial SG8047194 is??? My dishwasher humms, but doesn't runs at ALL. What could be the problem????
The motor is stuck. If you remove the lower cover and see a square aluminum motor it is less than 7 years old. Make sure power is off at breaker and rotate the motor shaft
by turning the fins inside the motor.
If the motor is black and round you have to turn
the fan blade which is located in a slot between the metal pump and the plastic
pump. Also once freed, a light shot of silicone or WD-40 (silicone works better) at the
bearing ends. Also check pump for leaks around the drain solenoid (shiny shaft attached
to a plastic triangle). If it's leaking during pumpout, the seal has failed. The pump runs
around 100 dollars typically. Hope this helps.
May 30, 2011 | Hotpoint 24 in. HDA3400G Built-in...
Hotpoint aquarius wma34 washing machine - flooding and clicking
Sounds like it could be relatively expensive to put right.
Personally, I think you would be better in investing in a new washer, more so in view of the fact that is 7 years old.
There are numerous possibilities for the symptoms you describe.
Hope this helps you to come to a decision.
Dec 29, 2009 | Washing Machines
Dishwasher trips the fusebox.
You have a obvious short circuit.
Remove the lower panel and inspect the drain valve solenoid attached to the pump beside the motor.
These GE solenoids will stick and melt causing a short circuit.
If not that, open the front panel and inspect all wires for a break.
May 26, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Door on Hotpoint Diswasher BF1620 won't shut
To better assist you I need the Hotpoint Model n serial # look like this;
HDA3540NSA Hotpoint® Built-In Dishwasher HDA3500NWW Hotpoint® Built-In Dishwasher HDA3500NCC Hotpoint® Built-In Dishwasher HDA3500NBB Hotpoint® Built-In Dishwasher HLD4040NSA Hotpoint® Built-In Dishwasher HLD4000NWW Hotpoint® Built-In Dishwasher HLD4000NBB Hotpoint® Built-In Dishwasher HDA1100NWH Hotpoint® Built-In Dishwasher
Let me know wish one is yours.
Thank you
May 13, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Dishwasher running on a short cycle, not cleaning
It is hard to be specific without knowing the model number of your Hotpoint dishwasher and approximately how many years old it is...
If your dishwasher has a mechanical timer knob that you turn to get the dishwasher started, I would suspect that it is failing (not advancing after a certain point.)
Please report back with what you find, OK?
Apr 20, 2009 | Hotpoint Dishwashers
Hotpoint Dishwasher Problem
Certainly sounds like the motor is seized. If it is quite old it may not be worth fixing, you should call your local appliance parts dealer with the dishwasher model and serial number and get a quote for a new motor.
Sep 06, 2008 | Hotpoint Dishwashers
Rattle Noise in motor - DU920QWD
its not the hardest thing to do but is it worth it motor price you have to see the rest if its good maybe you invest $150.00 and up you still have that old washer check the price for part dont forget it gonna be rusty in there maybe other thing gonna break if it not cheap motor run it untill it drive you crazy buy a ney one it gonna be quiet and it will be energy star less electricity there not to expensive thank for using fixya pierre
Feb 05, 2008 | Whirlpool 24 in. DU920QWD Built-in...
Hotpoint 24 in. HDA3400G Built-in Dishwasher Logo
603 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
