Question about Whirlpool Washing Machines
I have a two year old whirlpool top loading washing machine and the tub is exetremely loose it rocks back and forward and when is spin cycle is make a loud clanking sound similar to an unbalance load but it's alot louder and occurs at a slower pace. I am guess it's the counter weight spring but i really don't have any idea. help please
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
The problem is the glides that your tub is sitting on. Get these replaced and your good.
Sgt 48
Posted on Jun 03, 2008
Maytag Neptune tl- about 6 years old. Wont finish out the final spin cycle on any setting and also sounds like tub/drum is hitting against side of machine. It also rocks like crazy. Shows the code for...
You have a Clutch malfunction common problem with the FAV6800A and FAV9800A TL's. Owners very seldom report all the conditions of wild tub swings. You are on the ball with info feedback.
See if this post Clutch Fix will get you started.
Post back if you have questions or need help.........Rich
Jul 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Rattles like rocks in it when going to spin cycle! Less than 2 yrs. old
Your load is uneven, try spreading the load evenly before spin cycle.
Nov 19, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Tub gets off balance during spin cycle
also,shorten front legs,lean washer forward,and reset back legs.level.
Feb 17, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Excessive lateral travel of tub in spin cycle
there are springs that keep tub centered.also some small glides that can wear.most common prop.spring.most models can look thru bottem .the spring that fails most is towards the back,left rear,goes from washer to body.check that out God bless,tom
Jan 03, 2009 | Whirlpool LXR6432JQ Top Load Washer
Rooper washing machine- unbalanced spin - rocking agitator
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jan 03, 2009 | Roper RAS6233KQ Top Load Washer
Whirlpool washing machine, top load
hi without further investigation its a bit hit or miss , does the whole tub tilt or is it just the inner drum ?
if its just the inner drum then it sounds like the bearings are on there way out
if its the whole tub then it could be one of the springs that it hangs from or the shock absorber underneath that may have come adrift
hope this helps
paul
Jan 30, 2008 | Washing Machines
Spin cycle noise
pull up and down on your basket to see if it has up and down play in it
kind of rock it side by side too
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Drain/Spin won't work unless lid is lifted up
Curdy, it almost sounds like your lid switch is loose or fractured and the lid actuator is not making the switch. Check this out first and post back...Catriver.
Oct 19, 2006 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
