Question about Bunn Coffee Grinder
I have a bunn coffee grinder that keeps on jamming up everytime you put coffee beans in it. I took the front part off to clean it out every time it jams,but it keeps on doing the same thing. The model bunn i have is g3hd,red
  • 35 Answers
It sounds as though your grind is out of adjustment. The grinder is probably set too fine. I have not worked on a G3 grinder but I would think it is like the Bunn G2. On the front knob you will find 2 small set screws and one larger adjustment screw (in the middle of the knob)
1. Set the selector knob to finest setting (Espresso or Turkish)
2. Loosen the 2 set screws about 2 turns.
3. Activate the start switch (you must activate the "bag switch" behind the chute)
4. With the grinder running, SLOWLY turn the center screw clockwise only until you hear a very slight whirring sound (this is the burrs touching).
5. Then, back off the center screw counter-clockwise about 1/8 of a turn, shut off grinder and re-tighten the set screws.
Check the grind in the "drip" setting by running a few beans through... the grounds should be about the consistency of sand. You should get a better flow through the machine with the grind adjusted properly. You may want to check the cleanliness of the hopper in the top... I have seen these dirty enough to impede the falling of the beans to the grinder.
Also, whenever you remove (for cleaning) the 2 larger screws that hold on the front "plate", be sure to put them back in evenly... kind of like one would with a wheel on a car- Finger-tight then slightly tighten each on a little at a time (back and forth) until tight.
Hope this helps.
Posted on Oct 29, 2010
Tip
Fix Saeco Magic De Luxe Not Grinding problem
If you leave the machine for a while, the residual ground beans in the grinder stick and clog the grinder.
- thus "timing out" with the "No beans" light.
After taking apart the grinder and cleaning it out, it still didn't grind. -
Then we ran some ground beans through it a couple of times, and then put fresh whole beans on top of the preground, and it took.
Worked great after that.
on May 06, 2009 | Saeco Magic De Luxe Espresso Machine
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
I have a Gaggia syncrony compact coffee machine and the coffee grinder has jammed for the second time. The repair agent employed by Gaggia inform me that they have been waiting for spare parts from Gaggia...
If the grinder jammed it might have been because the grind was too fine, try adjusting coarser then using the + or - lever to add more coffee for proper extraction. To clear jam remove brew unit and locate door to grinder chamber on left, vac out grounds, also beans in hopper. When clean run grinder and set to coarser, then add small amount of beans and test.
Aug 25, 2010 | Gaggia Syncrony Compact Coffee...
Cuisinart coffee grinder keeps clogging
Unplug first. Unscrew the top. You need a long thin screw driver Phillips head is the best. Pock around the exit and entrance where the coffee beans are ground. Remember, the better the coffee and you will get more clumping of the beans. I works great. It is pain. The Chicago Clout man exits.
Feb 06, 2010 | Cuisinart Supreme Grind DBM-8 Electric...
My Bunn Grinder sounds like it is jammed. I have power but no mov
First turn grinder to coarse setting and try grinding some white rice through it, that will clean out the coffee oils, if that does not work then the you will have to open the grinder and clean out the burr chamber and the spout for the grounds.
Apr 21, 2009 | Bunn Coffee Grinder
Coffee beans are not fine
Have you replaced your blades recently? If you will call contact customer service, we can send these out to you free of charge.
Mar 08, 2009 | Bunn Coffee Grinder
Not Coffee just Hot Water
runner, sounds like you've got a jam up! Remove all the coffee you can If you can, try to remove the burr and clean whatever you find out. Now, turn the unit upside down over the sink to remove everything messy. Then, turn the unit upside down over a newspaper and tap the unit a couple of times to dislodge what may be jamming it. Put it all back and you may be okay. Otherwise, you'll have to dig deeper into the unit to remove the coffee bean 'stuff' that is jamming it. You may even be able to flush it out with warm water. Be sure to air dry everything before reloading with coffee.
Nov 19, 2007 | Cuisinart Thermal DGB-600 Grinder
Coffee Grinder not working
the grinder is most likely stripped and needs to be replaced:-{
Jul 23, 2006 | Saeco Caffe Charisma Espresso Machine
Bunn Coffee Grinder Logo
155 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
zimcloud
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
