Question about Crosley CR87CD CD Shelf System
My Crosley CR87CD console does not power up. I could be the power switch or is there a fuse of breaker inside? Are relacement tuner/CD modules avaialble to put in this cabinet?
    President:
  • 2,992 Answers
It very well could be the power switch. I have repaired two of these where the on/off switch has gone bad, and the original part isn't available.
First, does the switch seem to be operating correctly? That is, does it feel like a definite click when you turn the control, or does it seem "mushy" in its operation? If the switch doesn't feel normal it's certainly at fault. It may still not work correctly even it feels normal, though. You can test it by connecting a jumper across the switch terminals while the unit is unplugged, and then plug it back in. If the power comes on you know the switch is bad.
The trouble, as I said before, is that the original part isn't available. My fix in both cases has been to install a new power switch on the rear panel and wire it to the circuit board inside, and solder a jumper wire across the bad switch terminals. The rear panel has ventilation holes that are convenient for putting in a small switch, and it's easy to reach. It's a little less convenient than the original, but it's a cheap and simple fix. For someone with a little soldering experience it's just a few minutes' work.
Thanks for using Fixya!
Posted on Oct 15, 2010
Where and witch fuse is for power window, 2004 Buick rendezous
All of the power windows don't work ? There isn't a fuse , a circuit breaker powers the windows !
PWR WDWS CIRCUIT BREAKER #35 30amp. located in the fuse block center console .
Fuse Block - Center Console
Inside of console, behind the right console access panel
Sep 04, 2016 | 2004 Buick Rendezvous
Windows and mirrors inop, fuses OK, no fault codes
Depending on the make , model an year vehicle You won't be able to communicate with door module an not all vehicles have door modules ,what makes you think yours has door modules An it depends on scan tool , has to be factory or professional grade scan tool . Your probably have broken wires inside the rubber boot from the body to the door . An power windows usually have a circuit breaker not a fuse .
Jul 23, 2016 | Cars & Trucks
My crosley electric dryer won't start, model cde4205ayj
Many things can cause this problem . Main timer , door switch,over heat thermal fuse , broken belt ,main power breaker
Nov 04, 2015 | Crosley Dryers
I have tried everything , check breaker, check fuse nothing helps why wont my dryer turn on?
check your cord or plug ,
check the dryer switch,
or check the fuse inside of your dryer.
Mar 07, 2011 | Crosley CDE6000 Electric Dryer
Where do i find a fuse box diagram for a 1994 Grand Cherokee Laredo?
There are 2 fuse blocks. The Power Distribution Center is under the hood along the passenger side fender and has fuses and relays in it. The other is on the passenger side of the dash and has fuses and circuit breakers.
....1994 Jeep Grand Cherokee Laredo
...(Fuse Block - Passenger side of Dash)
.....1........5........9........13........17........21........25
.20 A...15 A...20 A...20 A....7.5 A....15 A....30 A
.....2........6.......10.......14........18........22........26
.15 A...15 A...10 A...20 A.... 15 A....15 A....30 A
.....3........7.......11.......15........19........23........27
.20 A...15 A...15 A....3 A......15 A....15 A....10 A
.....4........8.......12.......16........20........24........28
.15 A...15 A...15 A...20 A.....10 A...7.5 A....30 A
1)Trailer Tow Relay
2)Brake Lamps
3)Hazard Lamps
4)Security Lamp
5)Interior Lighting
6)Security Alarm Module
7)Security Alarm Relay, Security Alarm Module, Flash-to-Pass
8)Overhead Console, Keyless Entry, Radio Memory/Clock
Memory/Chime Module, Power Locks, Power Mirrors,
HEVAC and VIC
9)Rear Wiper
10)Radio
11)Cigar Lighter
12)Parking Lamps, Automatic Headlamps
13)Horn Relay
14)Power Lock Relays
15)ABS Module and Relay
16)Turn Signals
17)Heating and Air Conditioning Module
18)Airbag Module
19)Interior Mirror, Auto Headlamps, Overhead Console,
VIC/GDM Module, Heated Rear Window Relay Coil,
Illuminated Entry Relay and Chime Module
20)Heated Rear Window Switch, Overdrive Switch, Speed
Control
21)Security Alarm Module, Lamp Outage Module
22)Airbag Module, Speedometer, Tachometer, Telltales and
Gauges
23)Heated Mirror Feed, Heated Rear Window Switch
24)Instrument Panel Illumination
25)Power Seats
26)Power Windows, Power Sunroof
27)Security Alarm Module and Front Wiper
28)Heated Rear Window Relay
Aug 01, 2010 | 1994 Jeep Grand Cherokee
Fusebox diagram
hi, this is courtesy of ask me help desk...
FUSE PANEL INTERIOR
1 - 20 Amp (Yellow)Power Antenna Relay, Trailer Tow Relay.
2 - 15 Amp (Blue) Brake Lamps.
3 - 20 Amp (Yellow) Hazard Lamps.
4 - 15 Amp (Blue) Security Lamp.
5 - 15 Amp (Blue) Interior Lighting.
6 - 15 Amp (Blue) Security Alarm Module.
7 - 15 Amp (Blue) Security Alarm Relay, Security Alarm Module, Flash-To-Pass.
8 - 15 Amp (Blue) Overhead Console, Keyless Entry, Radio Memory, Clock/Chime Module, Power Locks, Power Mirrors, HVAC & VIC.
9 - 20 Amp (Yellow) Rear Wiper.
10 - 15 Amp (Blue) Radio Accessory.
11 - 15 Amp (Blue) Cigar Lighter.
12 - 15 Amp (Blue) Parking Lamps, Automatic Headlamps.
13 - 20 Amp (Yellow) Horn Relay.
14 - 20 Amp (Yellow) Power Lock Relays.
15 - 3 Amp (Violet) ABS Module & Relay.
16 - 20 Amp (Yellow) Turn Signals.
17 - 7.5 Amp (Brown) Heater & Air Conditioning Module.
18 - 15 Amp (Blue) Air Bag Module.
19 - 15 Amp (Blue) Interior Mirror, Auto Headlamps, Overhead Console, VIC/GDM Module, Heated Rear Window Relay Coil, Illuminated Entry Relay & Chime Module.
20 - 10 Amp (Red) Heated Rear Window Switch, Overdrive Switch, Speed Control.
21 - 15 Amp (Blue) Cluster, Security Alarm Module, Lamp Outage Module.
22 - 15 Amp (Blue) Air Bag Module, Speedometer, Tachometer, Telltales, Gauges.
23 - 15 Amp (Blue) Heated Mirror Feed, Heated Rear Window Switch.
24 - 7.5 Amp (Brown) Instrument Panel Illumination.
25 - 30 Amp Circuit Breaker Power Seats.
26 - 30 Amp Circuit Breaker Power Windows.
27 - 10 Amp Circuit Breaker Security Alarm Module, Front Wiper.
28 - 30 Amp Circuit Breaker Heated Rear Window Relay
Nov 27, 2009 | 1993 Jeep Grand Cherokee
My Crosley dryer not drying
You will have to ensure the tub belt is not broken or off the motor pulley. Also, you may have a bad push to start switch or door closed switch. Open door and manual hold in door switch and have someone to push the start button if there is any sound or attempt to start these switchs are most likely good and your problem is with the belt. Hope this helps God Bless
Sep 18, 2009 | Crosley CDE6000 Electric Dryer
1999 cadillac seville sts driver side master control pannel dead
The same circuit breaker feeds the driver door as well as the passengers doors . The wires inside the rubber boot from the body to the door are probably broke ,power or ground wire .Or the door module is bad . Are your familiar with electronic control modules ? The door functions ,windows , lock's , memory etc... are controlled by DDM - driver door module .
Door Control System Operation
This vehicle has five modules capable of performing door system control functions. Vehicle door system components (windows, locks, mirrors, etc.) are controlled directly by these modules. There is a door module located inside of each vehicle door:
• Driver Door Module
• Passenger Door Module
• LH Rear Door Module (LRDM)
• RH Rear Door Module (RRDM)
• LH Front Power Window Switch
Simple Bus Interface (SBI)
Each Door Module communicates with the other Door Modules on the SBI. The driver door module is the only Door Module that is capable of communicating over the Class 2 Data Line as well as the SBI.
Driver Door Module
The driver door module directly controls the LH Front door lock actuator, power window motor and the outside rear view mirror. The driver door module sends and receives messages received from the LH Front Power Window Switch to the passenger door module, LRDM and RRDM modules over the Simple Bus Interface (SBI) line. Also, the driver door module sends and receives message from other vehicle system modules via the Class 2 Data Line.
Pulling the door panel off an checking B+ voltage and ground for the module would be good for you to do , since you probably don't have a $6,000 factory Tech 2 scan tool to see if the DDM is communicating .
The driver door module has two main power feeds (high and low current), and two main grounds. The low power feed (battery 1) is used to provide power for the driver door module's logic and internal driver operation. The high power feed (battery 2) is used to provide power for systems that draw higher amounts of current (motors, lights, etc.). Operating current at the driver door module's battery should not exceed 3.0 amperes at battery 1, and 7.5 amperes (for 2 seconds) at battery 2 while the driver door module is awake, and 2.5 milliamps when the driver door module is asleep. For most driver door module functions, the driver door module will operate properly with a system voltage of 9.0-16.0 volts. If system voltages exceed 16.0 volts the driver door module will provide protection by disabling certain functions that may damage due to higher than normal system voltages.
What kind of manual do you have ? The info above is from a factory repair manual .
The fuse's ,circuit breaker for the door module are located in the rear fuse box , not under hood . PWR WDO circuit breaker 30 amp. , DRVMDL fuse 10 amp. The rear fuse box is located under the back seat . Watch this video ,different type vehicle but probably the same problem .
Dodge Grand Caravan No Power Window No Power Locks CAN Trouble
Jul 23, 2017 | 1999 Cadillac Seville
Yamaha RX-V461 receiver audio
Disconnect the unit from the mains at the wall socket. Leave powered down for 5 mins to ensure a good reset and turn unit on again and see what happens. If there is still no life. Check for failed fuses inside amp. ALWAYS RELACE FUSES WITH THE SAME RATING AND TYPE.
Dec 15, 2007 | Audio Players & Recorders
Crosley CR87CD CD Shelf System Logo
147 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
