Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Black and Decker MM525 hard wiring diagram
I have the same mower as the picture above. I removed the saftey handle and I am trying to by pass the switch (hard wire straight to a new cord I purchased. I am done with running up-stairs to flip the breaker. Can anyone tell me what wires to match up to my cord? Thanks in advance.
Bud Man 73
  • 5 more comments
  • KIA1111 Jun 07, 2008
    Did you bypass the switch? If so, how did you do it with the leads for the brake (white and red leads)? I would like to do the same.
  • BudMan73 Jun 09, 2008
    I am trying to hard wire it without the switch.
  • BudMan73 Jun 25, 2008
  • BudMan73 Jun 28, 2008
    Still looking for help.
  • BudMan73 Jul 07, 2008
    HELP
  • phatypaul Jul 13, 2008
    Im having the same problem trying tofigure out what all the wires are for!
  • BudMan73 Jul 25, 2008
    The solution posted on July 19th was a VERY BIG HELP. Thanks Man 4 the help.
I have the same mower and same problem. (I have already spent over $75 replacing the burned switch annually. ) The black wires carry the power. The orange wire is the common. The red and white wires are used to stop the motor quickly when the switch is released. To bypass the switch, connect the two black wires together with a wire nut. Disconnect and tape off the red and white wires. Now the mower will run whenever it is plugged in. It will take a few seconds longer for the blades to stop turning when unplugged. See this thread for a detailed discussion of the switch wiring. There is a picture of it near the bottom:
http://www.ridgidforum.com/forum/showthread.php?t=8535
If plugging and unplugging gets too annoying, I may look for a plug-in switch I can plug between the extension cord and the mower plug. Until then, happy mowing!
Posted on Jul 19, 2008
The connection the are not right. top left side is for white wire.buttom left side is for red wire. top right side is connected to black wire from motor. buttom right side is for is going to the
extension terminal. good luck
Posted on Jun 05, 2008
I have a Black and Decker Electric Lawn Mower MM525. Trips breaker when I start it.Was working great,Started it again and now it trips breaker. Mike
the brushes in the motor may be shorting out. check or replace the motor brushes. be sure cord is not the problem.and check the plug also. good-day !
Oct 16, 2011 | Black & Decker 19" Electric Lawnhog...
Mm850switch for black decker wher do wiring go
Here is a picture of where the wires go on the switch.
Jul 06, 2010 | Black & Decker 19" Electric Lawnhog...
WIRING DIAGRAM? FOR BLACK AND DECKER ELECTRIC LAWN MOWER MM 850
looking down at the terminals, rotate push-button to the right. the wiring sequence is R, W at the top, then Black (in, from power source) , Black (out, to motor).
Sep 27, 2009 | Black & Decker 19" Electric Lawnhog...
My B&D mm525 electric mower won't start.
Motor brushes are wearing out.
Aug 27, 2009 | Garden
Need wiring diagram for black and decker mower 8000 type 8
Try goggling by " wiring diagram Make Model #" and check the differnt sites. Usually you can come up with a downloadable manual
Jun 28, 2009 | Black & Decker 19" Electric Lawnhog...
I have a black & decker lawnhog mm875 lawn mower that just stopped working. the power to the mower is good. can you help
I had the same problem. Its the switch.
When you pull the plastic handle up, it pushes down a button switch located in the handle. Over time (and with use) the parts begin to wear and the handle is no longer aligned properly with the button. So, ........ when you pull the handke up the button is not pushed in far enough to start the mower.
I want to bypass the handle and hard wire the mower but I can't find a wiring diagram.
May 04, 2008 | Black & Decker 19" Electric Lawnhog...
Saw your post about Black and Decker MM525 Lawn Mower
Most lawn mower mfgs offer a mulching kit which usually consists of a metal plate to block the discharge opening and a mulching blade which just has a longer sharpenned cutting edge.
With a little labor you can make your own.
Johnww1422@aol.com
Apr 19, 2008 | Black & Decker 19" Electric Lawnhog...
Electric Mower not working
yes of course. this mower model mm525 has a motor not engine. if you need parts diagram see toolpartsdirect.com & look for the Black & Decker.
Jan 16, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
1,926 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
