Question about NEC VT470 Multimedia Projector
NEC VT470 projector - lamp won't turn on / red blinking status indicator
I have exactly the same problem, the status light is blinking red, 5 cycle, the manual says lamp failure, "wait a full minute and restart" , I tried it several times but it keeps doing the same. I tried pressing for more than 10 seconds the OFF and EXIT buttons on the remote as well, still no result. The lamp indicator is off. I have not used the projector for more than 1000 hours. Somebody suggested that it might be a ballast problem. What can I do? Have you solved this problem on your projector? Thanks!
  • Anonymous Nov 08, 2008
    Same prob;em for th HT 1100. Tried two new biulbs with no reults.
  • Anonymous Jan 04, 2009
    same problem.....
guide2u
  • 461 Answers
SOURCE: NEC VT470 Multimedia projector
Try to reset the projector. Turn the power off. remove the power supply cable from the main socket. Leave it for 30 min. Turn on again. Before turn on(Make sure) 1.0 power cable install correctly 2.0 Lamp cover install correctly. 3.0 No excessive heat around the projector All this can be refer to the user manual.
Posted on Sep 24, 2007
SOURCE: lamp won't light / status indicator blinking red
Replace the bulb.
Posted on Jun 10, 2009
  • 74 Answers
SOURCE: nec vt470 lamp does not come on. replace lamp,
If you replaced the lamp already, chances are the ballast is defective. When you power on the projector with the power button you should see a flicker of light in the lens, or an electrical sound. If you don't you ballast is bad.
Posted on Apr 21, 2010
SOURCE: I have replaced bulbs in 3 different types of NEC
I had the same issue, what I figured out was that I never removed the lamp door correctly, causing a small plastic piece to break off. To see if this is also your problem, inspect the back of the lamp door, top right corner, if it seems a rectangular plastic piece is missing, thats the problem. It presses in a small button nearby the lamp to let the projector know it's safe to power on.
Posted on Oct 14, 2010
heathgr
  • 442 Answers
SOURCE: I have a NEC VT470
steady orange means projector in standby mode
red light 6 times is a lamp error.
either the lamp is old and wont start up or the ballast power pcb is not working.
can you hear the sparking of the high voltage trying to strike the lamp.
if you can then the lamp may be dodgy.
can you borrow one to test it out
Posted on Mar 03, 2011
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...oid...
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib
www.manualslib.com > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
TV turned off by itself one day. I pressed reset, timer light blinked green for a minute, then I pressed power and it sounded like it wanted to boot up, but nothing happened and the status light turn
Two thoughts:
First is this is a DLP set and the lamp may have failed
Second is it should have the self check which reads error codes---most of these sets that is the same:
" After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
(then release both)
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
This is for a earlier Mitsubishi DLP but should be the same as your set as Mitsubishi rarely changes things like this.
If you get the lamp abnormal it is likely your problem.
Dec 06, 2012 | Mitsubishi WD-Y65 65" HDTV
RED FLASHING STATUS LIGHT
Possible lamp failure but lamp light not status should blink-I have suggestions but want you to try the self check first--if set has been unplugged plug it up and turn on and when it fails:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
33 = Air filtercover is open.
44 = DVI cablebetween FMT and Engine disconnected
Jun 11, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Status light is blinking red, power button orange nec vt700
Hello
Look at the number of blinks of the status light.
[1] If it blinks at one cycle (0.5seconds On and 2.5seconds OFF) : Lamp cover error or lamp housing error. Replace the lamp cover or lamp housing correctly.
[2] If it blinks 2 cycles (0.5 seconds ON and 0.5 seconds OFF): Temperature error. The projector is overheated. Move the projector to a cooler position.
[3] if it blinks at 4 cycles (0.5 seconds ON and 0.5 seconds OFF): Fan error. Fans sill not work correctly.
[4] If it bliks at 6 cycles (0.5 seconds ON and 0.5 seconds OFF): Lamp fails to light. Wait a full minute and then turn on again.
[5] If it blinks continous (Red): Lamp has reached the end of its life. Lamp replacement messege will be displayed. Replace Lamp with same type and number. After replacement reset lamp hour. OK.
Sep 10, 2011 | NEC VT700 Projector
Does a lamp error message (6 blinking red status lights) mean the lamp needs to be replaced? or could something else be wrong.
According to NEC technical support, if the status light flashes red six times, this could indicate a defective lamp. If a new lamp is installed and the project still won't turn on, the projector will need service.
Jun 15, 2011 | NEC NP400 Projector
I have a NEC VT470 Projector. The power light is steady orange and the status light blinks red 6 times.
Mar 02, 2011 | NEC VT470 Multimedia Projector
Nec vt470 lamp does not come on. replace lamp, when turned on status light turns red and get 3 beeps. lamp does not come on.
Apr 19, 2010 | NEC VT470 Multimedia Projector
I have replaced bulbs in 3 different types of NEC projectors: a silver, older model thta uses a VT60LP bulb, model VT595 and VT470. The lamp will still not work - the power and status light just continue...
Sep 01, 2009 | NEC VT695 LCD Projector
Nec Lt245 power light yellow - orange status blink red, no image, no light coming out of the projector
- Unplug the projector for a full 4-5 minutes.
- Plug it back in and wait for the ready light and try it again.
If the above fails, replace the lamp.
If that also fails, it is likely a bad ballast.
Thanks,
Tor
Aug 27, 2009 | NEC LT245 Multimedia Projector
NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
May 28, 2009 | NEC VT595 LCD Projector
NEC VT470 Multimedia Projector Logo
1,688 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
