Question about Nikon LS 2000 Film Scanner
Connecting a Nikon LS200 slide scanner to a PowerBook G4
Is there a way to connect a Nikon LS2000 Slide Scanner to a Mac PowerBook G4
Yes - get hold of an Adaptec USB2XCHANGE SCSI-USB cable and download Vuescan software (www.hamrick.com). This works perfectly on LS2000 - Macbook Pro combo.
Posted on Oct 05, 2008
  • sharaku Mar 02, 2011
    HaveRatoc USB2 UltraSCSI Converter for Win7 and VueScan, does not work.
Here's an update on fixing a Nikon LS-2000 scanner that wouldn't work. I am using VueScan software (www.hamrick.com) a Macbook Pro, and a Ratoc FR1SX SCSI to Firewire adapter (available from amazon.com).
After spending a lot of time on Google, I figured that the problem was most likely the rails needed lubricating. I took the scanner apart, and first of all cleaned the mirror - it was very dusty. There's a good website with photos and directions on how to clean the mirror, and the basic instructions for taking apart the scanner:
http://www.vad1.com/photo/dirty-scanner/ls2000-cleaning/
Then I went further and took apart the slide rails on which the scanner runs. It's actually not much more work to do this (after you've cleaned the mirror). Apparently this is a common problem, and probably the main reason people stop using their LS-2000 scanners. The LS-2000 needs to be serviced by lubricating these slide rails. If this isn't done, it won't run freely and after a while just gums up, the original oil dries out and actually seizes up the scanner. I followed some of the general instructions on the following website (it's actually for a different Nikon Coolscan III scanner, an LS-30, but the principles are the same).
http://www.vad1.com/photo/dirty-scanner/nikon-ls-2000-lubrication-guide.pdf
The key to this is cleaning off the slide rails with rubbing (isopropyl) alcohol, and then lubricating with teflon lubicant (any bike shop should have this, get a small bottle of lubricant with P.T.F.E).
Once I'd done this, it worked beautifully right away. That's it.
There is also someone in Missouri who will service the LS-2000 for $109, he advertises on eBay:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=260609293354&ssPageName=ADME:X:RTQ:US:1123
Terence in BC, Canada
Posted on Mar 31, 2011
  • 611 Answers
Scanner doesn't recognise their is a slide loaded in the slide holder
The first thing I'd try is to run the scanner with the Nikon software. When you power on the scanner it goes through a variety of checks, and finally you should have a silent scanner with a solid green light at the front. Start the Nikon software and wait until it finds the scanner, if it doesn't you have a hardware problem with the scanner.
If it goes well to this point insert a card or plastic mounted slide and hit Preview. The scanner should then create and image you see on screen. Next step would be to make a scan. If the slide you're trying to scan isn't card or plastic mounted you'll need the Nikon made carrier.
Hope this helps.
Mar 22, 2014 | Nikon CoolScan V ED Film Scanner
Hello, my mute button is locked on since last upgrade, I've rebooted, what do I do?
Go to the Apple menu (top left) System Preferences > Sound click the Output tab at the bottom there is a Output volume slide bar, slide the blue upside down house all the way to the right (max volume) make sure the Mute checkbox is unchecked.
Dec 06, 2010 | Apple PowerBook G4 Mac Notebook
I HAVE A NIKON 35MM FILM SCANNER LS-40-ED SERIAL NUMBER ;228462 AND I REQUIRE THE APPROPRIATE SOFTWARE TO LOAD ONTO MY APPLE MAC G4 DESKTOP COMPUTER (OPERATING SYSTEM X TIGER.)VERSION 10.4.6...
Hi
Download the Nikon scan application here: Nikon Scan
There is also a firmware update for this model. After installing the Nicon Scan software that includes the scanner driver (ensure that scanner is recognized), do the firmware update.
Follow instructions on site and do not interrupt firmware update procedure, or that may damage the scanner.
Coolscan IV / LS40 1.2.0 firmware update
Aug 20, 2010 | Computers & Internet
My LS-2000 film scanner has just stopped working
I read this forum entry and it solved my problem also:
http://www.pcreview.co.uk/forums/thread-1936922.php
Dec 03, 2009 | Nikon LS 2000 Film Scanner
I need to connect a Nikon LS2000 Slide Scanner to a Power Mac G4
I originally had the same problem but with a G5. Since Nikon never updated the software for the LS2000 to work with Apple I ended up buying a FR1SX adapter from RATOC Systems: http://www.ratocsystems.com/english/products/FR1SX.htmlwhich connects the SCSI pins to a Firewire cable. Then I purchased the VueScan software from http://www.hamrick.com/vsm.html. The scanner worked for several years with this combination.
Dec 17, 2008 | Nikon LS 2000 Film Scanner
Can I connect a Nikon LS200 to my Mac PowerBook G4
Nikon supports mac. You'll want to go to nikon.com for more details.
Jun 04, 2008 | Nikon LS 2000 Film Scanner
Drivers for Nikon LS 1000
I believe that's a SCSI-interface scanner, making its setup more complicated than there's room for here. Here's what Nikon says about SCSI setups: <http://tinyurl.com/2wxp7p> and the Nikon software for the LS2000 and LS3000 (but maybe it'll work for the LS1000 too) is at <http://tinyurl.com/2qko5e>. There's a good set of detailed installation instructions under cineman's entry at <http://hardware.mcse.ms/archive47-2005-6-203500.html>. Good luck!
Lenny
Feb 11, 2008 | Photography
NIKON LS2000 SCANNER
this scan works with SCSI interface not provided by default in PC. So scan uses to come with SCSI board .. you need to install it into your PC .. yes
Nov 19, 2007 | Nikon LS 2000 Film Scanner
LS 2000 w/SCSI connection
does the nikon scan sofware recognise the scanner ?
Sep 20, 2007 | Nikon LS 2000 Film Scanner
Firewire. USB2
Either or is my understanding- the scanner will accept either. I can see no need for both.
Sep 01, 2007 | Nikon Super Coolscan 8000 ED Film Scanner
Nikon LS 2000 Film Scanner Logo
1,041 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
