Question about Fisher Paykel EcoSmart GWL15
My washer, model # GWL15, hums and vibrates when not washing anything. I now have it unplugged and it started doing it again.
  • hunterhampto Oct 16, 2010
    The power is off the machine is *unplugged* there is no power going to it and it's humming and vibrating.
  • Fisher Master
  • 713 Answers
Hi just read your posting.From the information in your posting when the machine is not being used and the power at the power outlet is turned on your machine hums and vibrates until you turn the power off,Is this correct?Please verify that I understood the information in your posting by replying back and I am sure I can help you rectify this fault.Looking forward to your reply.
Posted on Oct 16, 2010
  • luisa_sgro Oct 17, 2010
    Hi HUNTERHAMPTO, just read your posting.In my 13 years of servicing FISHER@PAYKEL washing machines I have never seen this fault before.Alright, the only 2 places that would make any noise in the machine after it has been unplugged from the wall is the inlet hoses or the drain hose.1st thing to do is to turn off the cold and hot taps to the machine.Then remove the hoses from the tap ends noting which hose goes to the cold tap and which hose goes to the hot tap.Does the humming and vibration stop after removing the hoses?If it does not stop then reply back and let me know where the drain hose is draining to,Is it draining into the laundry sink or some place else.Have no fear as I will keep helping you until this problem is rectified.I am looking forward to your reply on how you got on.Good luck.
My machine had been giving E20 error code - cleaned out filter and pressed start button and it started again ok. During wash it jammed and all lights went on (except spin speeds) and it wouldn't...
E20 is a general error code to get to the real problem try this.. Reading ErrorCodes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
Not lit up to show power
You may have overloaded your washer. Some washers have a safety trip feature that activates when the motor is overloaded. Try unplugging the washer and removing the clothes. Once you have done this, go ahead and start the washer again. If you that doesn't work, you made need to check if you have blown an internal fuse or call a qualified technician. I hope this helps. Good luck.
Jul 23, 2010 | Fisher Paykel EcoSmart GWL15
We are using model #gwl15 fisher and paykel top load washer. When it gets to the rinse cycle it justs beeps. It won't go any further. It is not unbalanced. I've taken all of the clothes out of the...
Hi just read your posting.Now when it beeps and stops do any lights flash or come on?If they do they will be on a row of 8 lights.Starting from the far left which lights are on or flashing?Are they the 1st and 4th light or 3rd and 6th --etc--?Please look underneath the machine and look to the front right of the machine You should see your pump which should have a red or black fan on it.Turn this fan a few times and hopefully this will loosen your pump if it is jammed.If you have the pump without the fan please reply and I can guide you throe unjamming it.I think with your symptoms you have described, you might have a jammed pump.Please reply for further help.Hope this helps.
Jun 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer won't go past the wash cycle
YES !! check out the DRAIN MOTOR PUMP it could be clogged , AJ
Dec 18, 2009 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel Ecosmart will Wash but not Rinse/Spin
You have too many clothes in the washer. Take some out and try again
Sep 09, 2009 | Fisher Paykel EcoSmart GWL15
Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisherpaykel gwl15 washer will not pump down
remove as much water as possible lean washer back against wall ..pump twist locks into bottom of tub remove clamps with fingers pump will twist out no tools needed!!!! clean pump and retry
Sep 09, 2008 | Fisher Paykel EcoSmart GWL15
Fisher Paykel EcoSmart GWL15 Logo
42 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
