Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
How do I clean (find) drain on my Whirlpool refrigerator which is leaking water into the refrigerator.
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 17, 2010
Water leaking and freezing in bottom of freezer and leaking on the floor it is a whirlpool gold series model #GI6SARXXF04
sounds like your defrost drain is clogged up. it can be cleaned by taking off the metal or plastic panel and cleaning out the defrost drain hole. a steamer works best.
Dec 20, 2016 | Whirlpool Refrigerators
Leaking water
Did you inspect if the hole in the drain inside the fridge at the bottom is not blocked? Try to clean it with a swab. Sometimes this causes a "leakage" of condensed water.
Dec 14, 2013 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
All items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Kenmore Refrigerators
Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
May 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Refrigerator leaking water
Try cleaning out the hose (on the exterior rear). This is the drain from the condenser to the evaporator pan.
May 12, 2009 | Whirlpool 18.8 cu. ft. Top Freezer...
Water leaking inside the refrigerator
Hi
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Apr 17, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Whirlpool Refrigerator Model # ET21PKXGN00
HI thanks for your question. the problem is with the drain tube, from freezer to the drain pan ,located at the back, by the compressor. to repair. turn fridge off, for 24 hrs. pull fridge away from the wall. clean all the coils. locate the drain tube, by the drain tray. get a small plastic hose, shove the plastic hose up the drain tube. and blow, to dislodge any debris clean the tube thanks the appliance doc.
Oct 15, 2008 | Whirlpool Refrigerators
Leak water on floor once a month
This likely a defrost cycle issue. Your drain tube is likely clogged. Get under there and clean it, clean your condenser while you're at it. Cut down door openings, open liquid in the fridge.
Jan 03, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
114 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
